Bilsteins front and back with firestone airbags
Discussion in 'Suspension' started by sundance, Jun 4, 2019.
  1. Jun 4, 2019 at 10:12 AM
    sundance
    sundance [OP] New Member
  2. Jun 4, 2019 at 10:17 AM
    monaco730
    monaco730 New Member
    16 Inferno Tundra
    Fox shocks, TRD Exhaust, TRD grill, TRD shift knob, weathertech floor/bed liners, ARE topper, FrontRunnerOutfitters cargo rack, Relentless cargo bars, color matched front bumper/side mirrors, fuel wheels, nitto RGs, K&N intake
    Yes. I have airbags with my adjustable suspension.
    sundance[OP] likes this.
  3. Jun 4, 2019 at 10:23 AM
    sundance
    Thank you!
    Do you lift the rear any? I've noticed that running 5lbs or so in the bags pretty much lifts the rear about an 1/2 to 1 inch. Which is what you get out of these rear shocks.
    How much did you lift the front?
    Is the ride better?
    I appreciate the help.
  4. Jun 4, 2019 at 10:30 AM
    monaco730
    16 Inferno Tundra
    I have fox 2.5s in the front at 3". I have coachbuilder +2 shackles in the back which gives me 1.25" of lift but will be replacing those with pro form 2" shackles for more rear lift/rake. I don't know what PSI my bags are right now but I would guess 20 psi. I base it more on the rear height cause I like a little rake. With the higher lift of the new shackles I will air down the bags. No complaints with the ride. It rides great with what i have them aired up with. I have a topper and decked system.
    sundance[QUOTED][OP] likes this.
  5. Jun 4, 2019 at 10:54 AM
    sundance
    Thank you sir!
    monaco730[QUOTED] likes this.
  6. Jun 4, 2019 at 11:10 AM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    I think you will be happy with that Bilstein setup.
