Bilstein shocks
Discussion in 'Suspension' started by Bdk437, May 17, 2023.
  1. May 17, 2023 at 8:00 AM
    Bdk437
    Bdk437 [OP] New Member
    Bruce
    2019 Tundra SR5 2wd Crew cab
    5000 series Bilstien shocks TRD sway bar
    I have a 2019 Tundra 2wd TSS …
    I was looking into changing shocks to a recommended Bilstein 5100.
    I was told the truck already has Bilstein on it stock???
    Must be a cheaper Bilstein if that true.
    I’m 65 and don’t need a lift or bigger wheels just a better shock that’s not to stiff…
    Avi8or likes this.
  2. May 18, 2023 at 11:09 AM
    Sleeper16plat
    Sleeper16plat New Member
    Near Vancouver
    2016 Silver Platinum
    TRD Rear Sway Bar Bilstein 6112/5160 Pop Lock, Kenwood MX 1057 XR, Pioneer amp/speakers/subs, Tech12Volt dual sub box
    I believe stock are Bilstein 4600's.
  3. May 18, 2023 at 11:14 AM
    AZBoatHauler
    So.Arizona
    Those (blue and yellow) are on the TRD off-road package trucks. They’ll be a little stiffer than the standard OEM black shocks.
  4. May 18, 2023 at 12:00 PM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    The 5100 is a better version of the Bilstein shock that your truck came stock with. Your OEM shock is a "version" of the 4600. That said, a Bilstein 4600 is generally a little better than you OEMs as well, but definitely not an upgrade in my opinion.
    Oey12 likes this.
  5. May 18, 2023 at 12:06 PM
    Larly5000
    Larly5000 Local Scumbag
    NV
    07 Crewmax
    Feels like im in the minority but was never impressed with 5100’s. As a matter of fact I thought they rode like shit. That was on the lowest setting.
    6112’s were a huge improvement in ride quality. Know they are more expensive but buy once, cry once.
  6. May 18, 2023 at 1:18 PM
    Bdk437
    Bruce
    Larly5000…
    The ride seriously is better not just a stiff race shock? Thanks!!
  7. May 18, 2023 at 1:32 PM
    Larly5000
    NV
    07 Crewmax
    Naa…6112’s are a solid street set up IMO. I don’t do anything off-road with my truck other than a dirt road or something to get my rzr’s to a spot…im sure they are fine off-road too. Better than stock/5100’s anyway.
    They are a good medium. Im sure you can dial in a Fox/King/ADS etc much better but 6112’s aren't stiff nor do they ride like a boat.
    I’ve got 50k on a 6112/5160 set up. Lowest setting(stock replacement). I’ll do it again when they need replacing.
  8. May 18, 2023 at 1:33 PM
    AZBoatHauler
    So.Arizona
    I’m also running 6112 / 5160 combo and agree 100%. Great go anywhere do anything shock that will outperform anything near its price.
  9. May 20, 2023 at 10:10 AM
    Ebrperk
    Ebrperk Old member
    South Central Kansas
    2018 1794 MGM
    Tinted windows, go rhino D6 side steps and shorty antenna, Bilstein 5100's rears, 6112's fonts set to 2.5" Rocktrix RT111 18x9 -12offset NItto Terra Grapplers G3's 275/70 R18's. Amp from James @ Tech12volts FRAC Harness
    Sounds like the direction I would like to go, 6112/5160 combo. Where did you all order your Bilsteins from
    BillyB likes this.
  10. May 20, 2023 at 10:32 AM
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    Check with @memario1214 , I believe he has them in stock.
    I also had that combo on my other Tundra. Hard to beat for the money.
    memario1214 likes this.
  11. May 20, 2023 at 11:26 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Last time I check most people said 5100 and 4600 are basically the same shocks only different is 5100 have groves for lift. If you ain’t looking for lift and want better ride, I’ll go 6112/5160 or try something else.
  12. May 20, 2023 at 12:28 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    @memario1214 In stock / price?
  13. May 20, 2023 at 12:44 PM
    memario1214
    Colton
    Missoula, MT
    OHwendTrd[QUOTED] likes this.
  14. May 20, 2023 at 12:59 PM
    Ebrperk
    Ebrperk Old member
    2018 1794 MGM
    memario1214, yes, please PM me as I have some questions
  15. May 20, 2023 at 1:11 PM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    memario1214[QUOTED] likes this.
  16. May 20, 2023 at 4:02 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    I didn’t get the TRD suspension off the lot, my stock shocks are the black one. So anything is gonna out performing it. When I order my shocks, the bilstein was back order and no one have a time for it, so I went with the fox 2.0 and never look back.
    A few weeks ago I just installed the RAS spring and it took out all the floats over bumps feel. It does make the truck more firm but not jarring uncomfortable, I rather have a solid feel than the truck just floating non stop on interstate.
    I was going for the bilstein 6112/5160 as everyone praised them for the price/performance.
    Sierradevil likes this.
  17. May 20, 2023 at 6:11 PM
    Avi8or
    Avi8or New Member
    Johann
    MO
    2020 Limited Crewmax
    I’ve posted this around.
    I ran 5100s front and rear for about 20,000 miles. Recently switched them out with 6112/5160. Both fronts sets were set to second position from bottom. 1.57” on 5100s and 1.3” on 6112s. However both lift the front the same amount.
    My estimation is the 6112/5160 combo is 10% less stiff and 50% less harsh than the 5100s. Do with that what you will.
  18. May 20, 2023 at 6:25 PM
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    5100s on my 2019. For the price I am very happy.
  19. May 25, 2023 at 8:38 AM
    malveman
    malveman New Member
    New jersey
    2022 Limited long bed MGM
    When u guys put in the 6112 was that shock only or shock and new spring thanks
  20. May 25, 2023 at 8:43 AM
    memario1214
    Colton
    Missoula, MT
    An order of 6112s come as an unassembled shock and spring. You get the whole enchilada (shock/spring) if you order 6112s.
  21. May 25, 2023 at 8:53 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Get the one that pre-assembled and ready to install if you gonna DIY.
    Ebrperk and MedCityMoto like this.
  22. May 25, 2023 at 12:34 PM
    malveman
    malveman New Member
    New jersey
    Thank you memario 1214
  23. May 25, 2023 at 2:06 PM
    Sleeper16plat
    Near Vancouver
    and do you re-use the factory top hat?
  24. May 25, 2023 at 2:51 PM
    memario1214
    Colton
    Missoula, MT
    By plan, yes. Bilstein sells them unassembled and then it is expected that you will disassemble your OEM equipment and move the top hat and isolator over. Some retailers (like us here at Hotshot Offroad) will offer assembly services where we get your desired ride height info and vehicle specs and send them out to you assembled with brand new top hats. That way you don't have to mess with the disassembly process on your own.
  25. May 26, 2023 at 12:24 PM
    Bdk437
    Bruce
    I called a place locally and he said he can get Rancho 5000 or Monroe. Rancho is a good choice isn't? Anybody try a set?
  26. May 26, 2023 at 2:18 PM
    memario1214
    Colton
    Missoula, MT
    If you want a "better" shock then Monroe and Rancho are not it. They are perfectly acceptable replacements, but unless they're pushing something like the Rancho RS5000X it's not what one would consider an upgrade.
  27. May 26, 2023 at 2:25 PM
    Bdk437
    Bruce
    He said the rear was RS5000X. is the X model a worthy upgrade?
    sorry I’m not familiar with it
  28. May 26, 2023 at 2:49 PM
    memario1214
    Colton
    Missoula, MT
    Having never messed with them personally they seem to be a decent strut
  29. May 27, 2023 at 7:46 AM
    EddieBolt
    EddieBolt New Member
    David
    2020 CM SR5 4x4
    Bilstein 6112/5160 for sure!
    BillyB likes this.
  30. May 27, 2023 at 8:47 AM
    Dirtfiend
    Dirtfiend New Member
    So.OC
    2019 SSM 5.7 Crew Max 4x4
    Bilstein 6112 front (2.5")/5160 rear Total Chaos UCAs Toytec Shackles 1" Method Roost 18x9 Falken Wildpeaks 295/70 R18 Carven Cat Back Exhaust Baja Designs Squadron Fogs (Amber) Stubby Antennae Blackout Badges/ Tailgate Insert Front Tint (20%) K&N Air Filter Gate King adjustable lift gate Color matched grille/bulge
    It can be easy to start overthinking all of this. Been there done that. Run the 6112/5160 setup and you’ll be happy with the ride quality.
    Sleeper16plat, BillyB and OHwendTrd like this.
