Bilstein 6112s?
Discussion in 'Suspension' started by hockeyjake94, Dec 30, 2017.
  1. Dec 30, 2017 at 10:44 PM
    hockeyjake94
    hockeyjake94 [OP] New Member
    2017 Black Toyota Tundra TRD
    Hi Everyone,
    First time poster and new to the forums. I am looking to upgrade my suspension on my 2017 double cab TRD offroad tundra. Ultimate goal I see for my truck is to level it, create a more aggressive stance, some ko2s and call it a day. My truck spends 90 percent on the street and about 10 percent beat to a pulp deep in Baja or local mountains.
    After some research and combing through the forums I was wondering if installing the Bilstein 6112s are the best bang for my buck for my price range and where I will be going with my truck.
    My budget is about $1000 and any input would be greatly appreciated!
  2. Dec 30, 2017 at 11:45 PM
    agentcox000
    agentcox000 "Skin that smoke wagon and see what happens"
    Corey
    Buckeye, AZ
    '16 White CM 4WD
    See Signature
    I'm in the same boat as you. After reading a ton of threads here I've decided to go with 6112's set at the 1.9" setting, then putting 5100's out back. Plan on stuffing 295/70/18 under her to round out the look. Seems like a good compromise between aggressiveness and practicality.
  3. Dec 31, 2017 at 12:21 AM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    2017 Super White 5.7 SR5 TRD off road
    Welcome from Ohio
  4. Dec 31, 2017 at 3:52 AM
    Welcome from CO. Best bang for the buck? Old Man Emu "triple stage" NitroCharger Sport shocks and custom assembled OME coil overs from ToyTec. http://toyteclifts.3dcartstores.com/OMETUN07CL--Complete-lift-for-07-Up-4x4-Tundra_p_254.html Check out the OME suspension specs and engineering on ARBs website. http://store.arbusa.com/Suspension-Systems-C16.aspx Each OME shock is Aussie engineered and manufactured expressly for the vehicle they're going onto. Also you get to chose which coil spring rate is best for your setup. OME doesn't get enough mention here. Quality Aussie products. These aren't in the same league as rebuildable resi's but the next best thing engineering wise over 2 stage shocks like Bilsteins which are quality shocks. Several of us here went the OME route and might chime in. The ride is not as smooth on the street as OEM street setup but off road the ride is just fine. At least in my case. No complaints.
    showtime240 and Casper3 like this.
  5. Dec 31, 2017 at 4:40 AM
    MistrRoboto
    MistrRoboto '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
    Yep, I think so. 6112s at $700, 5100s in the rear at $165, or 5160... and a few hours of your time. Great option for you!
  6. Dec 31, 2017 at 4:41 AM
    MistrRoboto
    Virginia Beach, VA
    Toytec Boss also seems really nice, but starts to creep out of your price range.
  7. Dec 31, 2017 at 4:42 AM
    The ToyTec Boss system is a kick it up a notch kit which is great but above $1K . Boss is around $1250. There should be a ToyTec member discount too.
  8. Dec 31, 2017 at 5:42 AM
    mgtundra
    mgtundra New Member
    Joplin mo,
    2015 mg tundra
    6112 bilstein coilovers,5160 remote resivor,camburg upper arm,sway bar,Trd pro skid plate,Trd pro mg grille,high flow air intake
    EC8008AA-1E61-41B3-A84E-237C85E87927.jpglove my 6112/5160 setup
    MistrRoboto likes this.
  9. Jan 23, 2018 at 10:51 AM
    showtime240
    showtime240 New Member
    +1 on the OME Set up (Old Man Emu)
    Great product and very well engineered.
    So far 30k on my OME 614s with zero issues.
  10. Jan 23, 2018 at 12:30 PM
    pschiller86
    pschiller86 2017 SR5 CrewMax
    Paul
    Temecula, CA
    I just bought the 6112 assembled from boss4x4s for $699, bought 5100’s for the rear on Amazon for $70 each.
