Bilstein 6112 settings to level?
Discussion in 'Suspension' started by Ming15237, Nov 23, 2018.
  1. Dec 15, 2018 at 10:13 PM
    georgiey22
    georgiey22 SW Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    6112 set at #3 clip which is 1.9” and 5160 in the rear. Tire is 34" x 11.50” and is a Ridge Grappler.
  2. Dec 18, 2018 at 3:26 PM
    mojojo
    mojojo New Member
    2018 Cement SR5 CM
    Does that front tire rub? Do you have mud flaps on the front wheels?
    georgiey22[QUOTED] likes this.
  3. Dec 18, 2018 at 3:33 PM
    georgiey22
    georgiey22 SW Idaho
    I removed the front facing mini mud flap and spent 20 minutes with a heat gun doing a little bit of reshaping to the larger mudflat. Truck goes in for an alignment on Thursday and then I’ll reassess if there is any rubbing occurring.
    Rica25 and mojojo[QUOTED] like this.
  4. Dec 19, 2018 at 8:49 AM
    georgiey22
    georgiey22 SW Idaho
    Question: Did you do the differential drop brackets? If so, which brand and model did you purchase? I'm on the 1.9" setting and thinking about adding this just to .e sure my CV's are always happy, they're a pain to change and would rather they last. Thanks/
  5. Dec 19, 2018 at 9:01 AM
    georgiey22
    georgiey22 SW Idaho
    Last Saturday I installed Bilstein 6112 @ 1.9" and added no lift to the rear but did install Bilstein 5160. There is something gratifying about doing the work yourself, although my old hands were a tad sore for a few hours after the install. I was incredibly impressed with the build quality of the 6112 and matching coil. The shock body had no manufacturing flaws, all bolts needed were included, the KYB top hat bearing installed without a concern, and the assembled coil/shock system installed with very little fuss. I've only put about 200 miles on the system thus far but initial on road impressions are positive. The ride is firmed up no doubt, but confident in many ways. Most noticeably for me is rebound, the truck now manages rebound with ease. My truck feels balanced and firm but comfortable.
    I have King coilovers all the way around on my wifes 2016 4Runner 4X4 and a few things came to mind when I was driving it for an hour last night. The Kings on road ride plush and off road when we push them they chew up almost everything we've done on trails in 2 years, as they should at a cost of $2500+ dollars. For the cost difference I'm thrilled so far with the 6112/5160 combos but the real test will come on the trails.
    What are your experiences on the trails with this combo?
    GELCW, Bob_Wiley and justfortun like this.
  6. Dec 19, 2018 at 9:57 AM
    NjPro
    NjPro New Member
    Tom
    Nj
    2017 Trd Pro Tundra cement
    Magnuson supercharger, Sprint booster, CB TRD PRO kit, 295/70/10 terra grapple G2, Black TRD shift knob, Rhino shackle hitch, Lund Tri-fold bed cover, 1.25 Spidertrax wheel spacers. TRD rear sway bar. Bud Built cross member. Arb Diff breather. Grab handle installed. 2012 DC SR5 TRD Supercharged, Gone but not forgotten.
    Beautiful truck.
  7. Dec 19, 2018 at 4:54 PM
    BRTundra
    BRTundra New Member
    Tony
    Baton Rouge, LA.
    2017 Tundra Platinum 5.7L CM
    No didn't do the diff drop kit. I was told no need for lifts under 3 inches. Hope this helps.
    OR18TRD and georgiey22[QUOTED] like this.
  8. Dec 19, 2018 at 8:47 PM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    My set up is 3/1.5” lift with 37” tires and love it. For the front, I’m using 6112 at very top setting with a CB shim and optional JBA UCA. For the rear, I’m using Toytec shackles with 5160.
  9. Dec 19, 2018 at 8:52 PM
    Opus5150
    Opus5150 Terminal Lance
    Live Free or Die
    2017 Tundra
    My two cents on the shim for the lean. Give it a week to settle after installing the 6112's. Mine had it at first, but after a few days of driving, it settled even. Not everyone has those results, I guess I was just lucky.
    I realize its a spendy PITA to put a shim in after the alignment, but I waited a bit before pulling the shim trigger. Glad I did.
    Ktate and Stormtrooper81 like this.
  10. Dec 19, 2018 at 9:09 PM
    georgiey22
    georgiey22 SW Idaho
    Franco those are some beefy tires. Can you share a few detailed photos of your wheel well? What trimming or likely cutting did you do to keep the tires from ripping off your fenders?
  11. Dec 20, 2018 at 6:15 AM
    matictundra
    Franco
    AZ
    Trimming circled in green. I also had my alignment guy shove the LCA as far forward as possible while staying within toe and camber specs.
  12. Dec 20, 2018 at 6:17 AM
    matictundra
    Franco
    AZ
    I also modded the liners and flaps for stock look, lol.
    Rica25, mojojo, justfortun and 2 others like this.
  13. Dec 22, 2018 at 6:50 PM
    georgiey22
    georgiey22 SW Idaho
    Side shot with 6112 set at 1.9” still having a little rubbing issue on the front most, front fender. Not sure what else to do to get rid of the issue. Any suggestions?
    Cavalry!
  14. Dec 22, 2018 at 6:54 PM
    Cement_Trd
    Cement_Trd New Member
    2018 Cement TRD offroad
    Cement color match (dechrome), Tyger Side steps, TRD rear sway bar, Black badging (dechrome), TRD dual exhaust
    3rd setting
  15. Dec 23, 2018 at 7:12 AM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Your truck looks awesome! As for the front, it looks like you already removed the little front flap. I removed entirely the front plastic liner. There's a thread on here that shows how to cut and re-drill holes on the front plastic so that it will fit in more flush and inward on the bumper. I intend to do that one day when I'm not feeling so lazy. Unfortunately, I can't find that thread at the moment, but I know it includes some really good photos on exactly where to cut. Hope this helps!
    Dgjman, Rica25 and georgiey22[QUOTED] like this.
  16. Dec 24, 2018 at 2:44 PM
    fuguchan
    fuguchan New Member
    Jeff
    St. Mary's County, MD
    2018 Tundra 1794 Edition Smoked Mesquite
    ARE-Z Cap, Bed Rugs, Husky Mats
    Here's a Youtube clip to check out, just start at 16:44 and John Bednarz shows you that you can leave the front mud flaps on and move the front bumper forward with spacers / washers. Looks good to me. His friend Georgi has a nice truck.
    https://www.youtube.com/watch?v=mnNK4gy9B_4&t=2s
    Bigolbaddy likes this.
  17. Dec 24, 2018 at 3:18 PM
    georgiey22
    georgiey22 SW Idaho
    Cleaver idea. I’ll give that a good look next week. Appreciate you sending this idea over.
  18. Jul 3, 2019 at 12:03 PM
    Rogue_Tundra
    Rogue_Tundra New Member
    Brandon
    Colorado Springs, CO
    2019 Tundra TRD Sport 4x4 CM
    Fox Racing 2.0 Suspension SCS Ray 10 Matte Dark Bronze 275/70/18 Nitto Ridge Grapplers Carven Exhaust BAKFlip MX4 Bed Cover Weathertech floormats 15% tint, 50% windshield
    I’m new here, just came from a 2017 Tacoma trd off-road and purchased my 2019 trd sport tundra two weeks ago. I really want to do the 6112s and 285/70r18 on some Ray10s like you but I am worried about the rubbing. I’m in love with your setup and I was wondering if you solved your rubbing issue and how? Thanks in advance I love you're truck man!
  19. Jul 3, 2019 at 1:30 PM
    #49
    georgiey22
    georgiey22 SW Idaho
    Welcome, it’s nice forum of Tundy enthusiasts.
    Yes, solved the problem and 0 rubbing. Purchased @Coachbuilder1 front bumper shims for around $80 or so. This provides around 1/2” of clearance and no rubbing at all. This is definitely the route you want to take, Buy quality parts and your truck will out live you!
  20. Jul 3, 2019 at 2:14 PM
    #50
    Rogue_Tundra
    Brandon
    Awesome! Thanks for the welcome and quick response. I’ve been doing so much research trying to pick the perfect setup for my needs and I think this one fits the bill. I do have two more questions for you. Are you running any cb strut shims? If not, did you notice the Toyota lean after installing the Bilsteins?
  21. Jul 3, 2019 at 2:37 PM
    #51
    georgiey22
    georgiey22 SW Idaho
    That’s a good q. I did not install strut shims. My truck has a slight lean but it doesn’t bother me a bit, I prefer it actually and unsure why. :) The truck leaned when I got it new and I’m running with it. Drove to Big Bear Lake today and the the suspension proved itself again. It’s smooth.
  22. Jul 3, 2019 at 2:59 PM
    #52
    Rogue_Tundra
    Brandon
    Great, thanks again for the info! I came into this forum thinking I was going to do a 3/1 spacer kit with 295/70r18, but now I am definitely going to be running the 6112s at 1.9 with the 285/70r18 RG! Thanks to you and that beautiful rig of yours.
  23. Jul 3, 2019 at 6:33 PM
    #53
    georgiey22
    georgiey22 SW Idaho
    Enjoy your truck and I wish you many years and hundreds of thousands of happy miles of ownership. It’ll look fresh once you install that 6112 system.
    Rogue_Tundra[QUOTED] likes this.
  24. Jul 6, 2019 at 7:29 PM
    #54
    Mdjamesd
    Mdjamesd New Member
    2015 Silver Sky Crewmax
    Not to threadjack, but, has anyone had any experience running the 6112 at 1.9', and 29570/18 toyo open country at II on the stoch trd offroad wheels? Didnt know if the tires would fit without rubbing the UCA's without spacers
  25. Oct 10, 2019 at 8:19 AM
    #55
    evans7
    evans7 New Member
    Cypress, Tx
    2016 2WD Tundra TSS
    Bilstein 6112 front struts and 5100 rear shock absorbers
    I am getting my 6112’s and 5100’s installed next week and I want to put the 6112’s at the top setting (2.5ins). I have read that it either sits level or has a bro lean. I want it so be level so should I wait to see how it sit or just go ahead and buy some shackles to be prepared?
  26. Oct 12, 2019 at 7:40 PM
    #56
    MICKs18yota
    MICKs18yota New Member
    Ohio
    2018 Tundra SR
    I think if you go 2.5 you’ll be nose high I’m sitting 1/4 higher in the rear with 6112’s set at 1.9 and 5100’s rear no lift maybe someone sitting at 2.5 can confirm what rear shackles they went with. I’m running Yokos M/Ts 285/70/18s (33.9 x 11.4) not sure what size your gonna run. Hope this helps
    NoRcptn likes this.
  27. Oct 14, 2019 at 7:21 AM
    #57
    Yotalou
    Yotalou New Member
    Lou
    2019 cement grey tundra
    . What did u get for the rear ? Do u have a link ?
  28. Nov 2, 2019 at 8:19 PM
    #58
    soobahru
    soobahru New Member
    2015 tundra 5.7L double cab 6.5ft 2019 tundra 5.7L limited crewmax
    Just got the 6112s (highest setting) and 5160s installed. Diy'ed it and took around 6 hrs. Pooped. Feeling very accomplished.
  29. Nov 3, 2019 at 4:13 PM
    #59
    justfortun
    justfortun New Member
    James
    Boston
    2016 SR5
    :worthless:
  30. Feb 6, 2020 at 11:46 AM
    #60
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    Installed 6112 at the 1.3 setting and 5260s rear- no lift. Truck measures level with exception of driver front lean; probably should have put a shim on - I have 3 shims in the box... as well as a CB =2 shackles. I started out with the 6112s at 1.9 and had them reset to 1.3 - trying not to second guess myself. The ride is way better and I love it.
    Next are Method 701 17's with 0 offset. Wondering if I can fit 295/70/17 or 285/70/17s and perhaps 305/65/15s? -Don't mind trimming a little.
