Bilstein 6112 Settings for 2wd Crewmax
Discussion in 'Suspension' started by sobro716, Sep 13, 2021.
  1. Sep 13, 2021 at 6:24 AM
    sobro716
    sobro716 [OP] New Member
    My front struts are starting to leak and need to be replaced. Want to level it out with 6112's if I can find them. I have a 2wd truck. Looked high and low in the forums saw lots of 4wd settings but not 2wd.
    Any assistance is greatly appreciated, the wife is getting made cause I'm leaking all over the driveway.
    Also if anyone knows where they have 6112's in stock that would also help!
    Semper Fi,
    Mark.
  2. Sep 13, 2021 at 6:35 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    First post needs a hearty welcome Devil Dog... Welcome from Central Penciltucky
  3. Sep 13, 2021 at 6:41 AM
    YotaTruckLtd
    YotaTruckLtd Secret Squirrel
    2014 MGM Limited CM
    Bilstein 6112/5160 Boss 4x4 shims Boss 4x4 shackles Fuel Off-Road Vector wheels 20X9 Nitto Terra Grappler G2 35" tires SPC UCAs OEM TRD Pro Grille OEM 2020 LED headlights and OEM LED fog lights OEM color matched mirror caps and door handles OEM black exhaust tip Ecoological color matched front and rear bumpershellz V3 Go Rhino RB20 running boards XPEL Prime XR Plus ceramic tint 30% front 15% rear 70% windshield BAKFlip MX4 tonneau cover Dasaita 13in Vivid Headunit AJT interior chrome delete black kit AJT climate control black knobs AJT V3 shift knob TVD exterior emblem black inlays 3BMakers Yota hitch cover Husky front and back floormats K&N Select engine air filter GTR Lighting Armor Series LEDs Reverse lights Cargo lights 3rd brake light License plate lights
    Here's some information directly from Bilstein.
  4. Sep 13, 2021 at 8:50 AM
    sobro716
    Oorah!
    toyofan87[QUOTED] likes this.
  5. Sep 13, 2021 at 8:56 AM
    sobro716
    Appreciate the info. Looking for a real-world install and how level it would be. I mostly see folks setting em at 1.9" but those are all 4x4 installs.
  6. Sep 13, 2021 at 9:01 AM
    timsp8
    NY
    You can probably expect yours to be a little higher at the same clip setting due to less weight up front. You might get the actual advertised numbers where a 4wd will sag a little. I’ve noticed no 2 trucks are the same though.
  7. Sep 13, 2021 at 9:58 AM
    Pomp_Cat115
    Pomp_Cat115 New Member
    Los Angeles, CA
    The 4x2 settings in the chart are spot on for me, at the top setting I got 3.3" and lowered it 1 down and got 2.7". The driver side will be a little lower though because of weight.
  8. Sep 13, 2021 at 1:08 PM
    sobro716
    So location 3 is where you ended up?
  9. Sep 13, 2021 at 1:24 PM
    Pomp_Cat115
    Los Angeles, CA
    yes
  10. Sep 13, 2021 at 3:55 PM
    BoxersBrew
    BoxersBrew New Member
    Thomas
    Northern Virginia
    2020 Black Tundra Limited Crewmax TRD
    Dealer installed TRD dual exhaust system and tonneau cover. Personally installed TRD Pro grille and surround, side mirror caps, and TRD shifter.
  11. Sep 13, 2021 at 4:16 PM
    sobro716
    Did you install a spacer on the drivers side?
    big thanks!
  12. Sep 13, 2021 at 4:27 PM
    BoxersBrew
    Thomas
    Northern Virginia
    They go on Thursday. I didn't order a spacer so hoping it doesn't need it. I asked at the installer shop and they didn't seem to think it would need it.
  13. Sep 13, 2021 at 5:52 PM
    Pomp_Cat115
    Los Angeles, CA
    No, but a lot of other members install shims with it to level it out
  14. Sep 14, 2021 at 3:19 AM
    BoxersBrew
    Thomas
    Northern Virginia
    I'm not an expert. I would follow what they are telling you then. I'm having a RL kit removed and dropping it down for towing, so it won't be level. Not sure if that matters. It'll clear my NRG 275s and give me a slight rake.
  15. Sep 14, 2021 at 10:05 AM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
  16. Sep 15, 2021 at 9:39 AM
    Pomp_Cat115
    Los Angeles, CA
    My bad, I should've explained it better, the shim is to level out the front passenger and the driver side because the drivers side always leans more.
  17. Sep 15, 2021 at 9:50 AM
    BoxersBrew
    Thomas
    Northern Virginia
    Understood. That would mean all trucks come from the factory with the lean! Anyone know if this affects all cab styles as well as all fuel tank sizes? Seems there would be some differences depending on these different configurations.
  18. Sep 15, 2021 at 10:25 AM
    pursuit2550
    Not all come with a lean bad enough to put a shim. Mines was like an 1/8 off from one side to the other. A shim in my case would have not fixed anything and made it worse. None of the 3 tundra I have owned, 2 DC and 1 CC, have had a lean bad enough to add a shim. As for configurations is concerned, only differences I would see that makes a difference is the larger glass tank.
  19. Sep 15, 2021 at 4:44 PM
    BoxersBrew
    Thomas
    Northern Virginia
    Thank you!
  20. Sep 16, 2021 at 8:53 AM
    Kfrog
    Kfrog New Member
    2016 Tundra SR-5
    The driver side springs are a little heavier to compensate for the driver and fuel in tank but what happens when the tank gets low on fuel. I just got a fat girlfriend and feed her accordingly.
    sobro716[OP] likes this.
  21. Sep 16, 2021 at 1:31 PM
    BoxersBrew
    Thomas
    Northern Virginia
    OK. I know, not the most popular setup but got 6112s on the front today at second clip or 1.3. 5160s are on the back. Tires are Ridge Grappler 275/70R18s. No rubbing or trimming. Best I can tell it has a 1/8 inch driver's side lean, however my gas tank is full, if that matters.
    AZBoatHauler likes this.
  22. Oct 17, 2021 at 11:04 AM
    sobro716
    Got ‘‘em installed. Ordered from wheelers took about 2 weeks to get ‘em.
    Need advice now on new tires. Would like to keep my stock 20” platinum wheels though
    SHAKA U F4KA likes this.
  23. Nov 5, 2021 at 3:17 PM
    sobro716
    Bumping for advice on tires that will fit my stock wheels
