Bilstein 6112 at top setting!
Discussion in 'Suspension' started by geno0506, Mar 12, 2017.
  1. Mar 12, 2017 at 11:07 PM
    geno0506
    geno0506 [OP] New Member
    Michael
    Maybe a dumb question,
    If I bought a set of 6112's and set them at the highest setting with the coils they are assembled with, would they be harder on the coils and on the 6112's at the highest!
    I'm thinking of a 3" or below lift and maybe shackles in rear with 5160's. Still deciding what set up but curious about the highest settings and wether its more harder on the 6112 and the 650lb springs they come with!
    Any advice thanks
  2. Mar 13, 2017 at 3:27 AM
    3RsDad
    3RsDad New Member
    Roger
    17 Tundra TRD OR
    I think what you are asking is about the ride harshness? The top setting will get the lift your wanting and the 650 lb. Spring is actually a touch lighter than stock and will give you a better ride. From what I've read, the dampening on the 6112 is better than stock in the lifted position. That is the direction I'm going when I replace mine btw
    geno0506[OP] likes this.
  3. Mar 13, 2017 at 5:13 AM
    Pvarela07
    Pvarela07 New Member
    2014 Silver Tundra SR5 TRD Off-road 4x4
    Just getting started
    I went with 6112 at highest setting with one coachbuilder shim per side to get 3" lift on the front. On the back I went with 5160s and +3 coachbuilder shackles and the back sits about 1/2" higher than the front which is exactly what I wanted.
    It rides extremely well, I don't see any issues going with the highest setting at all. I actually thing it rides much better than stock.
    Skew12, Joeshaker, rons23 and 3 others like this.
  4. Mar 13, 2017 at 5:44 AM
    Pvarela07
    CM-LENNY, rons23, YotaDan and 4 others like this.
  5. Mar 13, 2017 at 6:45 AM
    Basskrazee
    Basskrazee Pop
    Joe
    Indianapolis, IN.
    2016 Tundra SR5 /TRD
    AFE mass air intake TRD rear anti sway bar Headwaters seat covers TRD Pro grill Bilstien 6112 coil overs Bilstien 5160 rear shocks Consol vault
    Pvarela07
    What are the wheels that you have?
    Andrew4776 likes this.
  6. Mar 13, 2017 at 6:56 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Looks like blacked out stock TRD's
    Correct me if I'm wrong @Pvarela07
    geno0506[OP] and SouthBoundSteve like this.
  7. Mar 13, 2017 at 7:01 AM
    HBdirtbag
    HBdirtbag New Member
    Walnut Creek, CA
    2017 limited cm
    I went with 6112's highest setting and 5160's rear in stock height. Drives great. Have about 800 miles on it already and they are softening up slightly. Very happy
  8. Mar 13, 2017 at 7:21 AM
    Basskrazee
    Basskrazee Pop
    Joe
    Indianapolis, IN.
    Law
    That's what im thinking to.
    geno0506[OP] and Law323 like this.
  9. Mar 13, 2017 at 7:37 AM
    ej63090
    ej63090 New Member
    Eric
    McHenry, Illinois
    2017 White Crewmax SR5
  10. Mar 13, 2017 at 7:55 AM
    Pvarela07
    I got a great deal on TRD Pro wheels and I have a set of Nitto Ridge Grappler 295/70R18 on them.
    It was rubbing a bit on the Camburg UCAs I installed so added 1.25" Spidertrax spacers. Love the look and drives great, those tires are supper quiet for the aggressive thread they have.
  11. Mar 13, 2017 at 8:08 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I've got the same set up as HD and it rides great.
  12. Mar 13, 2017 at 8:22 AM
    Basskrazee
    Basskrazee Pop
    Joe
    Indianapolis, IN.
    Truck looks great
  13. Mar 13, 2017 at 10:05 AM
    Basskrazee
    Basskrazee Pop
    Joe
    Indianapolis, IN.
    Which Camburgs did you buy and why?
  14. Mar 13, 2017 at 10:25 AM
    Pvarela07
    Thanks, I'm changing the grill and bumper ends this weekend.
  15. Mar 13, 2017 at 10:32 AM
    Pvarela07
    I have the Camburg 1.5 Uniball UCAs, not sure if I really needed them but I got them due to everything I read and suggestions I received regarding the alignment.
    Apparently if you go more than 2.5" in the front, you might have a difficult time getting the truck aligned, plus I'm already spending a lot of money, might as well go all out :) plus they look bad ass...
    TXMiamiFan, J4RR3N4, AKJ78 and 7 others like this.
  16. Mar 13, 2017 at 12:09 PM
    geno0506
    Michael
    WOW,
    Thanks for all the great feedback, great forum! :oldglory:
    TXMiamiFan and SouthBoundSteve like this.
  17. Mar 13, 2017 at 12:14 PM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    those are sexy, how much furrther did it push out the tires?
  18. Mar 13, 2017 at 12:19 PM
    geno0506
    Michael
    will do, thanks
    SouthBoundSteve likes this.
  19. Mar 13, 2017 at 1:37 PM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    upper control arms don't push the tires out further but they do allow the truck to regain proper caster. some also allow another inch of upward wheel travel.
  20. Mar 13, 2017 at 1:50 PM
    YotaDan
    YotaDan New Member
    Grants Pass, Oregon
    Looking Good!
  21. Mar 13, 2017 at 7:18 PM
    Pvarela07
    Thanks YotaDan, it's still a work in progress but pretty happy with it so far!
    YotaDan likes this.
  22. Mar 13, 2017 at 7:21 PM
    Pvarela07
    @geno0506 when are you doing the install, looks like you are not going to go wrong with the 6112s on any of the settings.
    Keeps us posted!
  23. Mar 13, 2017 at 7:45 PM
    Joeshaker
    Joeshaker New Member
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Bilstein 6112/5160 trd sway bar and ride rite bags. Black and burnt orange wet okole seat covers.
    Pvarela, have you had any issues with the trac on yours with the 295's? I have 285/70/18 exo grapplers and stock trd wheels. 6112's on top setting. Stock ucas, no spacers. Trac goes off at the exact same angle and speed. Really stumped as to why, seems like all the guys with even bigger tires have less of a problem. I've got 1" Toytec shackles, 5160's, trd sway bar and bags on the back. The truck drives great except for the dang trac!
  24. Mar 13, 2017 at 7:54 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Hmm, I'll have to ask Lotsoftoys about that Steve. That's the first time anyone has said that. I wonder if toyota recalibrated the trac on 3rd gens because people were having problems.
  25. Mar 13, 2017 at 7:56 PM
    Pvarela07
    No issues with with trac lights at all.
  26. Mar 13, 2017 at 8:10 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Steve I believe that with the 2nd gens you want to have some rake. Talking with Dave over @ Ekstrom, he recommended going with +2 shackles in the rear. I was just gonna go with 5100's in the rear with nothing. It has something to do with the Yaw, which if you are completely level it throws the computer off. Me personally I want a little bit of rake.
  27. Mar 13, 2017 at 8:16 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Amado! Try the shackle at 1.5"!! Maybe that's it!!!!
  28. Mar 13, 2017 at 8:27 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Yeah, I should be ok on rake with 2.5 front and 1.5 rear. I had Lotsoftoys do the zpc, didn't change anything. I tried adding rake back in by pumping up the airbags and it made it worse. It's gotta be the tires. No issues what so ever before. Maybe if I had gone up to 35" instead of 34"? But that doesn't make sense!
  29. Mar 13, 2017 at 8:36 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    I had the shackles at 1.5 before the bags went on. Tires were on before that. I dropped the shackles down to maintain 1.5. But the truck didn't have the 3" rake when it was bone stock. So at 2.5 and 1.5 it only has about .75 now with 250 lbs in the back. I'll try airing up the bags a little more and see if that helps. I'm going to have to get airbag cradles so they don't get jacked with the lift when the axle droops. So, if putting another .5 works, I'll put the shackles back to 1.5
  30. Mar 13, 2017 at 10:48 PM
    geno0506
    Michael
    Thanks
    I had the money :frusty: but have to wait a little more, the money went to house priority! :ohsnap:
    I'll keep you posted buddy!
    Thanks :oldglory:
