Bilstein 6112/5160 Settings
Discussion in 'Suspension' started by greatpennstater, Apr 7, 2017.
  1. May 17, 2017 at 7:15 PM
    geno0506
    geno0506 New Member
    Michael
    Do you have shackles in rear or blocks!
  2. May 18, 2017 at 11:21 AM
    judge
    judge New Member
    2017 Black Limited 4x4
    Line-x bed liner, bilstein 6112 front/ 5160 rear, Century Royal Cap, 3m crystalline tint, Weathertech rear mat (large), Yokohoma G015 AT 275/60R20
    2" Blocks. I wanted to keep the truck level. And the 6112's I have set to lift the front 1.75". Bilstein said that setting (#2) would give the best on road ride. And frankly it still does great on any dirt, gravel, washboard etc. that I come across, but unlike some I almost never go offroad. Changing the tire lifted another inch.
    MegaTronda and geno0506[QUOTED] like this.
  3. Jun 15, 2017 at 6:42 PM
    eyoung71
    eyoung71 New Member
    I've read through this thread several times but I'm still a bit confused. I've made a lot of progress in at least deciding that I want to do the 6112/5160 setup!
    What I don't understand is some have 6112s on middle (1.75") on the front and 5160s on the back with nothing else. Others have 5160s on the back but with 2" shackles or blocks in the back and also consider this to be level. What am I missing?
    On a separate note, what's the reason for doing 5160s on the back in the first place?
    I'll be adding this to a brand new off the lot 2017 CrewMax.
    TacoWuzzaTurd likes this.
  4. Jun 15, 2017 at 7:51 PM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Better shocks with 1.5 inches more travel.
  5. Jun 30, 2017 at 7:42 AM
    judge
    judge New Member
    The 6112's all LIFT the front of the truck. There are 5 settings from around 1" to 2.5". The different settings make the shock work differently. For offroad (the main purpose of this shock) you would likely want the highest setting (more ground clearance and more shock travel). But lifting the front of your truck will change the angles of the tires and suspension. Plus just lifting the front can lead to a nose high look, which I hate. I actually choose this entire shock package, not for offroad, at all, but for on road. My truck came with 20"s rims and really stiff shocks and it was brutal. It made my organs hurt. (and I'm only 45!) So I called Bilstein, spoke with the Toyota shock design people and said, What is the BEST setup you can sell me for a smooth On-road ride? They said 6112/ 5160. And to use position #2 on the 6112's which are adjustable. So that's what I did. I didn't need a 50k truck that I hated to drive. I read on here about other peoples problems with lifting just the front and decided blocks sounded like they had fewer problems than shackles and got some installed at the same time they put the new shocks on. With the new shocks the truck rides soooo much better. And when I hit a gravel road or the like I can tell these shocks have so much potential that I'm not touching. But that's ok. Now I like my trucks ride! I also went on to change out tires for Yokohoma AT G015's with a 60 sidewall which lifted the truck another 1" or so, but more importantly gave me more sidewall and air between the rim and road. It helped my ride another bit. Now my truck rides almost as well as my 05 and 06 Tundra's, which were Smoooooooth. (You can see that I too have a 2017 Crewmax.) I was never after lifting my truck almost 3"s but I have to say... I love the way it looks. And adding the cap/ bedliner/ shocks/ blocks and tires only changed my fuel economy about 0.5 mpg. However I recently added a custom aluminum ladder rack which DID change my fuel economy... about 2 mpg's (and that is with a fairing!)
    tdcate likes this.
  6. Oct 12, 2017 at 4:09 PM
    saadi996tt
    saadi996tt New Member
    Saadi
    Bakersfield, CA
    2014 CM LTD
    Limo Tint (all around), Weather Tech Floor Mats, Morimoto XB LED Fog Lights, Nerf Bars, Paragon Bed cover (Paint to match), Bilstein 6112’s (F) & 5100’s (R), Wireless iPhone charger, TRD rear sway bar, swing case, led bed lights, pop-n-lock...
    I installed the 6112/5100 last week; the 6112 are at the highest setting and the rear looks lower, can I add blocks in the rear to make the truck level with the front?
    geno0506 likes this.
  7. Oct 12, 2017 at 4:19 PM
    geno0506
    geno0506 New Member
    Michael
    http://dirtydeedsindustries.com/product/coachbuilder-shackles/
    either the +1 or +2 might get you level, others will chime in and help. I bought the +2's haven't installed mine yet because my 2017 is level where I like it, I have a 6112/5160 setup maybe thats why mine seems a bit level, 6112's at top setting!
  8. Oct 12, 2017 at 4:22 PM
    geno0506
    geno0506 New Member
    Michael
    see my post #41 just above ^^^, thats my 6112/5160 setup!
    saadi996tt likes this.
  9. Oct 12, 2017 at 4:59 PM
    saadi996tt
    Saadi
    Bakersfield, CA
    2014 CM LTD
    Here is what the truck looks like today... maybe my eyes are playing a trick on me.
    6c8ae366a76faef3e280a75d2e8b5516_6be7ace700c889087b6b3b2666233a0f4699c401.jpga122e454eec9e1b784d22d309d6c4bba_2903550e987344f68f777164b59813cb5932a707.jpg
  10. Oct 12, 2017 at 5:16 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I've got the 6112/5160 set up as well. My wife thinks the nose is a higher. My tape measure says even. That's from ground to fender.
    Bust out a tape and check.
    geno0506 and saadi996tt like this.
  11. Oct 12, 2017 at 5:36 PM
    geno0506
    geno0506 New Member
    Michael
    Love that look!
  12. Oct 12, 2017 at 5:37 PM
    geno0506
    geno0506 New Member
    Michael
    Yep it may look higher but I measured even! Though it may get a little higher when you go balls to the wall!
    https://www.youtube.com/watch?v=B_3TlrZLpQ0
  13. Oct 14, 2017 at 11:35 PM
    BayRunner
    2017 Tundra Platinum
    @judge, to confirm, Bilstein suggested position 2 from bottom (1.3" lift) for the smoothest on-road, or position 2 from top (1.9")? Is your profile pic this setup?
  14. Oct 18, 2017 at 8:41 AM
    alphaghost13
    alphaghost13 New Member
    Scott
    2014 CM Tundra TRD Off Road
    I have been looking for a few weeks now trying to figure out what lift I want on my truck. I am new to lifts but after reading a lot think I have a fair understanding, at least in theory lol. I have a 2014 CM TRD Off Road and I plan on going with 6112/5160 on top setting with Toytec Shackles middle setting like @Muleycrazy13 and 35" Toyo Open Country R/Ts. I'm guessing that I might have to trim some areas for proper fit, but is a diff drop kit, stirring stops and/or new UCA's needed or is that pretty much 4" and above before you need to worry about it? Main goal is to fit the 35" Toyo R/Ts and a better ride than the stock TRD Off Road suspension.
  15. Oct 18, 2017 at 8:43 AM
    borntostun
    borntostun New Member
    We are . . .
  16. Mar 2, 2018 at 10:59 AM
    judge
    judge New Member
    Sorry about the delay. Yes, the #2 position is the second shortest length. The one that adds around 1.25" lift to the truck. After 10,000 miles I am still very happy with the ride. It is night and day better onroad, and offroad or washboard, or anything bumpy is even more improved. I can't believe the shocks my Tundra came with. It rode like a backhoe. And backhoes don't have suspensions. And yes I think all my pics are after I did the shocks (all 4) and the 2" blocks in the rear. Bilstein was super nice. During the call the girl reached out to the guys who actually do the Tundra development for their best ideas. Maybe this picture shows the truck a bit better. In this pic the rear of my truck is probably 1 to 2 inches below the front. When I see it in a lot it look flat to slightly high in the rear, which is what I prefer. I just measured... ground clearance at the bottom of the step bar at the front mounting point is 13 1/8" and at the rear mounting point it is 13 3/4".
  17. Mar 29, 2019 at 5:10 PM
    AK-in-MI
    AK-in-MI New Member
    Joey
    Michigan
    2015 Platinum Crewmax
    D.A.P. Tune Bilstien 6112/5160 33x12.50xr20 Toyo Open Country M/T 20x9 Fuel Coupler TRD Exhaust
    Beautiful truck. This is the exact look I am going for. What size shackles did you go with. I just ordered the 6112/5160 with 2" coachbuilder shackles and two shims. I have been debating if I need the shims or 3" shackles. Do you have shims on your setup?
  18. Jul 8, 2019 at 8:56 PM
    BrennanC0212
    BrennanC0212 New Member
    Brennan
    Atlanta, GA
    2014 Toyota Tundra Platinum - White
    I currently have a 3/1 leveling kit on my Tundra and I am running 35x12.5x18. Will the 6112/5160 kit allow me to continue running these tires? I didn't have to do the BMC, and I have plenty of clearance. If so, what settings would I be able to run? Thanks guys!
    Opus5150 and equin like this.
  19. Jul 8, 2019 at 9:23 PM
    #49
    Opus5150
    Opus5150 Terminal Lance
    Live Free or Die
    2017 Tundra
  20. Jul 8, 2019 at 9:24 PM
    #50
    BrennanC0212
    Brennan
    Atlanta, GA
    Thanks man!
  21. Jul 8, 2019 at 9:53 PM
    #51
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Looks real nice, i like stance and the tires just looks perfect
  22. Apr 22, 2020 at 8:09 PM
    #52
    MatausTundra
    MatausTundra New Member
    Andrew
    2017 Tundra 1794
    noob question, what do the shackles do exactly?
  23. Apr 22, 2020 at 8:10 PM
    #53
    MatausTundra
    Andrew
    2017 Tundra 1794
    shackles?
