Bilstein 5100s...Top or Middle setting?
Discussion in 'Suspension' started by ToyotaTundraMike, Apr 10, 2016.
  1. Mar 17, 2021 at 4:16 PM
    #61
    jassanch
    jassanch New Member
    Jason L.
    2015 Tundra 5.7L CM
    Just had the 5100’s installed. The truck is basically level, which I didn’t expect since I was going with the mid setting. I’m looking at the shocks, I’m pretty sure the installer set them at the top setting.
    I’m super happy with the look but curious on if I need to do anything else with the rear? Looks like we have the same set up. Are you still happy with your set up?
    JimboSlice413 likes this.
  2. Apr 21, 2021 at 4:24 PM
    #62
    Celt
    Celt New Member
    NY
    2019 Crewmax TRD/OR Cement
    Are the average height increase dimensions given for the 5100s based on a factory new tundra? Reason i ask is my 2019 currently sits at 39 3/8 in the rear and 36 1/8 in the front. If the top setting were to give me 2 1/4 raise in the front over where it currently sits then that would be great, but if it gives that much height from when the truck was new then it might sit nose high.
  3. Jun 7, 2021 at 10:57 AM
    #63
    Franco4x4
    Franco4x4 New Member
    2019 tundra CM
    What offset are those rims?
  4. Jun 7, 2021 at 10:58 AM
    #64
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    +25
  5. Jun 7, 2021 at 11:02 AM
    #65
    Franco4x4
    2019 tundra CM
    I'm installing 5100 with 275 70 18 at +25 offset. I'm thinking middle setting but nervous about any rubbing. I read a lot of people use this tire size with stock suspension but not +25 offset.
    ATV25 likes this.
  6. Jun 8, 2021 at 4:04 PM
    #66
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    pretty sure 25 offset is equal to my stock trd off road wheels with my 1.5 inch spacers. i have 275 70 18 and I am on middle setting not close to rubbing
  7. Jun 8, 2021 at 5:24 PM
    #67
    MARanger
    MARanger Lost in the woods
    Andy
    Home of Friendly's Ice Cream
    2017 Super White SR5 DC 4X4
    I have then mid setting and that tire size on a +18, it rubbed slightly at full lock but a heat gun and a little effort took care of it
  8. Dec 26, 2021 at 5:08 PM
    #68
    WXman
    WXman New Member
    Kentucky
    2016 Tundra SR5 Crew Max 4x4 5.7L
    What do the CV joints and ball joints look like with the 5100s on the top setting? Does it put them at a bad angle? Premature wear on parts or no?
    Mine should be here this week. Trying to decide.
  9. Jan 5, 2022 at 3:54 PM
    #69
    WXman
    WXman New Member
    Kentucky
    Nobody? Just wondering about alignment and premature wear if I go top setting.
  10. Jan 6, 2022 at 3:34 AM
    #70
    parkerbows
    Jack
    I think most go middle or middle with a shim. But must be someone out there
  11. Apr 15, 2022 at 1:06 PM
    #71
    clarkritchie
    clarkritchie New Member
    This is a n00b question, but having never seen 5100s in person, is it possible to tell, at a glance, what setting they are on? I am going with front 5100s here soon and will instruct the dealer to put them on the middle setting, but I want to check that is what they did before I drive away. Of course, I am planning to measure before/after, too, so I expect it will be about 1.7" taller upon pickup.
    Or maybe this is N/A -- like if it ships on the middle setting, and thus that is the default?
  12. Apr 15, 2022 at 1:21 PM
    #72
    parkerbows
    Jack
    i did my bilsteins myself. just put on middle setting b4 u bring there. tell them dont touch the ring
    Hbjeff and Musicmasterd12 like this.
  13. Apr 15, 2022 at 1:30 PM
    #73
    Musicmasterd12
    Musicmasterd12 New Member
    Southern Louisiana
    2011 4.6 Silver Sky Metallic DC
    Agreed. I just moved the clip to the middle setting myself and told the installer that I had set it and to leave it at that height
  14. Apr 15, 2022 at 1:32 PM
    #74
    clarkritchie
    Shocks are coming from the dealership that is doing the work. My question is, where is this "clip", and can I see it with my naked eye?
  15. Apr 15, 2022 at 1:35 PM
    #75
    Musicmasterd12
    Southern Louisiana
    I don’t think so
    this is not for a tundra specifically but you can see the grooves and small metal clip 764F26DC-6000-4F6E-B5AB-F6134406ACB2.jpg
    clarkritchie[QUOTED] likes this.
  16. Apr 15, 2022 at 1:45 PM
    #76
    clarkritchie
    Thanks! That's super helpful. I would imagine that, so long as it's not on the lowest setting, if I peer up into the coil assembly with a flashlight, I should see an exposed groove, unless the boot just fully covers it up.
  17. Apr 15, 2022 at 1:47 PM
    #77
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Correct. You should be able to see at least one.
  18. Apr 15, 2022 at 3:14 PM
    #78
    parkerbows
    Jack
    the boots not on it when u buy it. you can clearly see the 3 positions
  19. Apr 15, 2022 at 5:54 PM
    #79
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    KIMG0107.jpgMiddle setting, 275/70/18, +25 offset, no rubbing, VERY happy
    clarkritchie likes this.
  20. Sep 18, 2022 at 2:41 PM
    #80
    groovetank
    groovetank New Member
    Brad
    I’m getting mine installed tomorrow middle setting nothing on back. Hopefully get the same results.
