Bilstein 5100 Upgrade
Discussion in 'Suspension' started by benrichardson87, Jun 15, 2017.
  1. Oct 28, 2019 at 4:17 PM
    #121
    Torian13
    Torian13 New Member
    2019 Tundra XSP
    @Kwint23 are you getting any rubbing or clearance issues with the 37s? Mind if I shoot you a pm?
  2. Oct 29, 2019 at 1:39 PM
    #122
    GATORthaBEAST
    GATORthaBEAST New Member
    2019 Tundra SR5 2WD Silver Sky Metallic
    18x9 METHOD MR312 w/BFG A/T KO2s, TRD DUAL EXHAUST, TRD PRO SKID PLATE, BLACK TOYOTA NERF BARS......work in progress.
    Is the ride rough on the top setting? Sorry if o did this wrong I’m new.
  3. Oct 29, 2019 at 9:31 PM
    #123
    Kwint23
    Kwint23 New Member
    Ken
    2018 Tundra CM
    Yea you can send me a PM. I dont have any rubbing now but I do have an aftermarket front bumper and also did a body mount chop as well.
    60av8tor likes this.
  4. Nov 3, 2019 at 7:54 AM
    #124
    FirstTruck
    FirstTruck New Member
    18 Tundra MGM CM TRD Sport
    Stock, for now
  5. Nov 3, 2019 at 9:19 AM
    #125
    Mrpgfernandez
    Mrpgfernandez New Member
    Pristine
    2018 Tundra Crewmax
    Hi there. Nice looking truck. I just want to know what is the highest setting you can put on those blisten 5100. I’m thinking of putting it on my 18 truck to level it out. Right now I have leveling kit on mine but everyone says blisten 5100 is the way to go.
  6. Nov 3, 2019 at 2:03 PM
    #126
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    Not anymore, looks like they pulled it.
  7. Nov 4, 2019 at 7:11 AM
    #127
    Kwint23
    Kwint23 New Member
    Ken
    2018 Tundra CM
    Do you have a spacer lift currently. I live the 5100 for what I do. Top setting will make the truck higher in the front. I put a coach builder shackle kit on the rear went with the plus 2. Rear sits like a 1/4 to 1/2 inch higher. I wanted a little rack as I use the bed fit hauling stuff. Hope that helps.
  8. Nov 7, 2019 at 3:23 PM
    #128
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    I just picked up a 20 DC that replaced my '16 DC. I upgraded to a 275.65.18 18x9 -12 offset wheels, from the factory steelies, Driver side tires rubbing on mud flaps on while turning. I picked up the 5100 so I can set it higher to eliminate that rubbing, and maybe upgrade to 33's 295.70.18 after I wear the my 32's. How much lift do I really need to be able to achieve not rubbing while keeping the mud flaps.
    Current configuration:
    275.65.18
    18x9 12mm offset
    Firestone air springs paired with daystar cradles
    Parts on hand ready to be installed:
    Bilstein 5100 ft/rr
    TRD sway bars ft/rr
    Tuff Country 2" leveling kit with axle drop
    OEM color keyed pocket fender flares to keep the truck cleaner.
    Do I need shims? Shackles?
    Thanks!
  9. Nov 8, 2019 at 6:22 PM
    #129
    Kwint23
    Kwint23 New Member
    Ken
    2018 Tundra CM
    I had 33's on stock sr5 suspension that had steel wheels on it orginally. but i had the 33's on 08 wheels I think they were. I'm unsure of offset of those wheels. The wheels I currently have are plus 25 I believe with 37's and 2.5 inches in the front, so top setting. Not sure if that helps or not then the rear I did coach builder shackles plus 2's.
    SprinterAE86[QUOTED] likes this.
  10. Dec 4, 2019 at 7:41 PM
    #130
    GATORthaBEAST
    Do you have any side shots of your truck??? I just ordered 5100s and 2 CB shims to put one on each side with it set to the middle setting. Your truck was one of the deciding factors for me. Thanks
  11. Dec 5, 2019 at 4:23 PM
    #131
    Zztoph
    Zztoph New Member
    2019 CB Tundra
    Bilstein 5100 mid clip and shims, Gator Evo cover
  12. Dec 5, 2019 at 8:52 PM
    #132
    GATORthaBEAST
    Thank you!!! Looks awesome!!!
  13. May 25, 2020 at 4:56 PM
    #133
    7elXray
    7elXray New Member
    2014 Platinum
    Rock stock this far
    Hello all, I know this is a old thread but I have questions and cant be the new guy asking the some old questions in a new thread :D
    Just picked up a 2014 Platinum and need to get it ready for the farm. That means smaller wheels, more tire and a slight lift. Would like to maintain some rake as I will being carrying some weight. Was thinking 5100's set in the middle on all four corners w/ coachbuilder shims up front and +1 shackles in the back. Will probably just run 275x75x18 Nitto RG's.
    Do you think this will give me some rake? And if I do this will I need to do anything else, ie diff drop, bump stops etc? This truck will see lots of rock, mud ext on the farm but wont be doing any actual wheeling.
    Thanks
  14. May 25, 2020 at 5:19 PM
    #134
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    @7elXray I'm using 5100s at mid perch up front and nothing in the back. 1" rake measured ground to fender front: 38 1/8" rear: 39 1/8" just to give you an idea. (Everyone's will vary slightly with spring/leaf sag). Now add in your shims and +1 shackles and you should have a rough idea of your planned rake.
    Believe diff drop is recommended if you are going over 3" lift. Front 5100's come with bump stop spacers (literally a washer). I didn't use them. The 1 bump stop I attempted to remove snapped the stud, so I left the other 3 alone.
  15. May 26, 2020 at 10:37 PM
    #135
    TXTundra89
    TXTundra89 New Member
    Conroe, TX
    2016 Silver Tundra SR5 crewmax
    6112's on top setting with Boss shims, 1.5 inch shackles, 5160's in rear. 305/70r18 KO2's, Method Grid 0 offset.
    Does anyone know how much space, or how to determine how much space, there should be be between my bump stops (with extensions) and the lower control arms. A shop thought that there was too little allowed travel caused by my extensions/spacers possibly limiting full capabilities of the shock. I know a shock can't full compress so there has to be a limit (the bump stop). I am wondering how to tell what is too little or too much movement.
  16. Jul 15, 2020 at 9:57 AM
    #136
    Dr.X
    Dr.X New Member
    Antonio
    2018 Tundra Crewmax TRD Sport 4x4
    Do those tires rub at all?
  17. Jul 17, 2020 at 6:47 AM
    #137
    2019-1794
    2019-1794 New Member
    2019 1794 Crew Max 4x4
    No i just removed the front flap. But i did that before I put them on so not even sure it was necessary
    Dr.X likes this.
  18. Jul 20, 2020 at 7:28 PM
    #138
    khaywood9
    khaywood9 New Member
    I’m digging your 1794 stance. Those factory wheels have a +60 offset right? I’m trying to decide what size tire to go with my 2020 factory platinum wheels (+60 i think) and 5100 Bilsteins(middle or top setting). I’ve read conflicting reports on what size tires will fit.
  19. Jul 20, 2020 at 7:30 PM
    #139
    Dr.X
    Dr.X New Member
    Antonio
    Just literally measure your stock rake. the top setting ends up being ~2.25" so subtract that and see if you go nose high. on my '18 TRD Sport CM 4x4 I have almost exactly a 2" rake, so the top setting would make me nose high.
  20. Jul 20, 2020 at 7:45 PM
    #140
    khaywood9
    Really wasn’t asking about that. More so asking about his 1794 wheels.
  21. Jul 20, 2020 at 7:47 PM
    #141
    Dr.X
    Dr.X New Member
    Antonio
    Oh wow, I totally misread your post. My bad
  22. Jul 20, 2020 at 8:10 PM
    #142
    khaywood9
    No worries. I’m on the fence about the bilsteins setting too but I’ll save that for a different day:D
  23. Jul 20, 2020 at 8:26 PM
    #143
    2019-1794
    Man honestly I think you can go 285/65 on the 1794/Platinum 20’s with the clips on middle setting, easy with the top. I just got the Fox pro suspension in for my truck and will be going 285/65 after the pro suspension is on.
    khaywood9 likes this.
  24. Jul 21, 2020 at 4:00 AM
    #144
    khaywood9
    Did you not like the bilsteins?
  25. Jul 21, 2020 at 4:13 AM
    #145
    2019-1794
    No they are great and do what I need them to I just can’t leave well enough alone honestly.... I got a pretty decent deal on the fox pro setup and figured why not.... I deff recommend the 5100 set up... go ahead and get the rears while you’re at it, middle setting is nice because you don’t have to mess with lifting the rear and you’ll have slight rake.
    BravoDeltaRomeo likes this.
  26. Jul 22, 2020 at 1:43 PM
    #146
    khaywood9
    Awesome! Thank you for the advice
  27. Jan 11, 2021 at 4:20 AM
    #147
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    seems I cant find 275 75 18. not listed, wonder if that size got discontinued?
  28. Jan 12, 2021 at 11:55 AM
    #148
    Florida Man 82
    Florida Man 82 New Member
    2021 TRD Off Road 4x4
    Looks sharp. what size tire? any rubbing?
  29. Jan 19, 2021 at 6:07 PM
    #149
    bjohnson425
    bjohnson425 New Member
    Brandon
    Anyone know who has the best price on 5100s? I found some on real truck for $260 for a pair of fronts it’s the cheapest I have found yet.
  30. Jan 21, 2021 at 7:32 AM
    #150
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    I got a full set (4) for $370ish last year from Boss Offroad. They had a working club coupon.
    But I hear Bilstein anything is on back order from everyone.
