Bilstein 5100 Upgrade
Discussion in 'Suspension' started by benrichardson87, Jun 15, 2017.
  1. Jun 9, 2019 at 10:07 AM
    #91
    mojojo
    mojojo New Member
    2018 Cement SR5 CM
    Fwiw, a shim on top of the shock will not affect shock preload. Many choose to add shims to the shock to gain ride height, without sacrificing ride quality.
    My apologies for quoting such an old post.
    Rica25 likes this.
  2. Aug 11, 2019 at 6:28 AM
    #92
    Zztoph
    Zztoph New Member
    2019 CB Tundra
    Bilstein 5100 mid clip and shims, Gator Evo cover
    Have you had any issues with the TSS after you put the 5100 on?
  3. Aug 11, 2019 at 6:56 AM
    #93
    ab1653
    ab1653 Ew member
    TX
    2014 Tundra
    I went from BF All terrain T/A KO to Falken
    Wildpeak AT3 and it was a big difference in road noise. I’ll be buying the wildpeak again moving forward
    mromiami and phogallen[QUOTED] like this.
  4. Aug 11, 2019 at 8:16 AM
    #94
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    IMO, the XLT's and Falkens seem to be the quietest followed very closely by the Nitto Ridge Grappler. I have 4000+ miles on my XLT's and they're still very quiet and wearing very well also. We sell a ton of Falkens at my shop and very few XLT's, even on my recommendation. Ive always had good luck with Coopers and I love my XLT's. I think the tread pattern is proven, they're quiet as can be and the side wall is slightly more aggressive than the Wildpeaks and in the 275/70/18 they're about 4 lbs lighter than the Wildpeaks or the Ridge Grapplers.
    Mudbug and Boerseun like this.
  5. Aug 11, 2019 at 9:02 AM
    #95
    Rica25
    Ricardo
    Tulare
    I will be removing my 5100s all around in the next month they are 8 months old now and have about 6k miles on them upgrading to 6112s and 5160s if anyone interested let me know.....I'm in California
  6. Aug 11, 2019 at 9:25 AM
    #96
    Bif
    Bif New Member
    Bif
    2014-1794 Edition
    Stock
    Bilstein is top notch quality. I have them on my OBS F-350 and love them!
    Rica25 likes this.
  7. Aug 11, 2019 at 9:58 AM
    #97
    Rica25
    Ricardo
    Tulare
    Will be heading to the next Tundra to sedona next year and just want better set up by then
  8. Aug 14, 2019 at 10:43 AM
    #98
    D3C
    D3C New Member
    Dana
    OC
    Hey @Rica25,
    might be interested in your 5100s. PM me your asking price. I'm located in So Cal.
    Rica25 likes this.
  9. Sep 12, 2019 at 5:09 PM
    #99
    Thebigginny
    Thebigginny New Member
    2016 Tundra D cab TRD
    Has anyone set the 5100 front shocks on the lowest setting (as close to stock) and the rear 5100 on the lowest setting? It seems like most are using the middle setting on the front. Thank you in advance.
    Rica25 likes this.
  10. Sep 12, 2019 at 6:12 PM
    #100
    Zum
    Zum New Member
    NS Canada
    There's a post on here with people using the lowest setting up front.
    There is no adjustment to be made with the rear. 5100's ...lift in the back comes from other means....blocks, shackles,leafs etc
    Rica25 likes this.
  11. Sep 12, 2019 at 6:22 PM
    #101
    Thebigginny
    I’ll try to find that post. I bought these from Toytec and this is the description-
    1 x 24-186971-P - Bilstein 5100 Series Rear Shocks (0-1" Lift) for 07+ Tundra
    That’s why I asked about the rear.
    Rica25 likes this.
  12. Sep 12, 2019 at 6:29 PM
    #102
    easleycrawler
    Travis
    Easley, South Carolina
    2020 Limited DC 4X4 CEMENT
    That just means, that the shock is long enough for up to 1" lift. They are not adjustable.
    Rica25 and Thebigginny[QUOTED] like this.
  13. Sep 12, 2019 at 6:54 PM
    #103
    Thebigginny
    Thank you easleycrawler
    Rica25 and easleycrawler like this.
  14. Sep 17, 2019 at 9:01 AM
    #104
    Jsnake89
    Jsnake89 New Member
    Dane
    2019 Tundra TSS SR5 8W2
    Bilstein 5100 3/1 Pro Comp 1" Blocks, 12Volt Remote start.
    Got a 19 TSS wanting to level and lift. Was thinking of getting the Bilstein 5100 B8 front and rear kit, then adding procomp 1” shackles. So this would give me a 3/1 level lift correct?
  15. Sep 17, 2019 at 9:01 AM
    #105
    Jsnake89
    Jsnake89 New Member
    Dane
    Did you add shackles on the back?
    Rica25 likes this.
  16. Sep 17, 2019 at 11:24 AM
    #106
    whiskeydrink
    whiskeydrink Asst to the Regional Manager
    West TN
    2019 QS SR5 Offroad
    Question for you driver side shimmers...
    I have a 2019 sr5 off road stock for now. Was looking to put some 5100s (not 6112s I know) on the front only at the middle setting and leave the rear stock. Should I shim the driver side while I’m at it? Does every Tundra lean towards the driver? I haven’t noticed one as it sits... thanks from a newb
    Rica25 likes this.
  17. Sep 17, 2019 at 11:29 AM
    #107
    Jsnake89
    Jsnake89 New Member
    Dane
    I was thinking the same thing mine Leans towards driver side also .
    Rica25 likes this.
  18. Sep 17, 2019 at 12:26 PM
    #108
    Zztoph
    Zztoph New Member
    2019 CB Tundra
    I have 5100s middle setting and a @BOSS4x4s shim on each side and don't have any lean.
  19. Sep 17, 2019 at 12:34 PM
    #109
    MARanger
    MARanger Lost in the woods
    Andy
    Home of Friendly's Ice Cream
    2017 Super White SR5 DC 4X4
    I did not shim with my 5100, and have no noticeable lean
    whiskeydrink and Rica25 like this.
  20. Sep 17, 2019 at 1:59 PM
    #110
    Jsnake89
    Jsnake89 New Member
    Dane
    That is the truck and color I just got yesterday. Did you do anything to the rears?
    Rica25 likes this.
  21. Sep 17, 2019 at 2:09 PM
    #111
    Zztoph
    Zztoph New Member
    2019 CB Tundra
    @Jsnake89 The rear is factory. I like the level look.
    Rica25 and whiskeydrink like this.
  22. Sep 17, 2019 at 8:22 PM
    #112
    Torian13
    Torian13 New Member
    2019 Tundra XSP
    Are you not getting a error code from the TSS sensor from having your truck leveled?
    Rica25 likes this.
  23. Sep 18, 2019 at 3:49 AM
    #113
    Zztoph
    Zztoph New Member
    2019 CB Tundra
    @Torian13 The TSS is working just like it should no errors or codes. I was worried about it, but have had no issues.
    Rica25 and Torian13 like this.
  24. Sep 18, 2019 at 3:55 AM
    #114
    Torian13
    Torian13 New Member
    2019 Tundra XSP
    Interesting @Zztoph Thanks for the info!
    Rica25 likes this.
  25. Sep 18, 2019 at 4:24 AM
    #115
    Tundra16LTD
    Tundra16LTD New Member
    Wilton Maine
    2016 Toyota Tundra Limited
    Im on stock Suspension now and am running 275-60-20's with no issue. These are 33's so yours would probably look good with he same size or maybe 295s would fit.
    Rica25 likes this.
  26. Sep 18, 2019 at 3:41 PM
    #116
    NateDiz
    NateDiz Sunday Tunday
    Nathan
    So Cal
    2013 MGM CrewMax TRD
    Trd Pro Suspension, spyder headlights with morimoto HID, Raceline Defender Wheels, AFE filter, Dirty Deeds 8” exhaust
    wondering what you all think....
    I recently did 5100 on middle setting as well. No shims. Im sitting at the following hub to fender measurements
    LF 23 RF 23.25
    LR 25 RR 25.25
    What I cant seem to figure out is why the rear is so high stock. Everyone seems to be getting in the 25in range (hub to fender) for the rear AFTER doing a 1in lift. I am like 99% sure that the rear is stock (Bilstein 4600). Shackles are stock, and leaf pack appears to be stock as well.
    Reason i noticed is middle setting didnt look as level as i expected. Which makes sense because most the pics in the forums i found were like more at 24in hub to fender for the rear. So after 5100 at middle setting i still have a 2in rake. I really dont want to spend the two hours taking it back apart to add shims. So i think im just gonna deal
  27. Sep 18, 2019 at 5:56 PM
    #117
    Torian13
    Torian13 New Member
    2019 Tundra XSP
    @Zztoph what size tires you runnin?
  28. Sep 18, 2019 at 6:31 PM
    #118
    Zztoph
    Zztoph New Member
    2019 CB Tundra
    @Torian13 they are stock tires for now(275 55r20). I am looking though, lol.
    Rica25 likes this.
  29. Sep 18, 2019 at 8:51 PM
    #119
    Torian13
    Torian13 New Member
    2019 Tundra XSP
    Awesome, same size I am stuck with for a while. I’ll let the wife know it’s your fault when there is a box full of leveling parts on the porch.
    jordan0317, Zztoph[QUOTED] and Rica25 like this.
  30. Oct 21, 2019 at 6:06 AM
    #120
    Kwint23
    Kwint23 New Member
    Ken
    2018 Tundra CM
    5100's front and rear. Front top setting no shims rear has coach builder shackles +2. Sitting on 37x12.5x17. 20191019_173229.jpg 20191019_173933.jpg
