Bilstein 5100 Upgrade
Discussion in 'Suspension' started by benrichardson87, Jun 15, 2017.
  1. Jul 3, 2017 at 5:23 AM
    benrichardson87
    benrichardson87 [OP] New Member
    Ben
    2014 Double-Cab SR5 Off-Road Silver
    What's the difference from front to rear? It looks really close.
    LiftMeUp likes this.
  2. Jul 3, 2017 at 5:25 AM
    benrichardson87
    Ben
    I've went from 15.8 to 15.2 so not that much of a difference and that's 2 tanks of fuel.
    duece292[QUOTED] likes this.
  3. Jul 3, 2017 at 7:01 AM
    Apasion217
    Apasion217 New Member
    2016 Magnetic Grey Tundra
    It's pretty close. I think the back is barely higher.
    Lablover71 likes this.
  4. Jul 3, 2017 at 1:31 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    You actually get about 360 lbs at the rear tires. I'm not surprised you felt a difference, by upgrading to that size tire you gained 1.6" of height and nearly 1.2" of tire width.
  5. Jul 3, 2017 at 1:47 PM
    Cbrunt
    Cbrunt 2017 SR5 CM
    Charles
    Sacramento
    2017 White SR5 Crewmax
    Bakflip g2 cover Trd pro grill/bulge Nerf bar steps
    Looks good wanting to do same.
  6. Jul 12, 2017 at 10:40 PM
    TundraDan723
    TundraDan723 Not as new as I used to be...
    2023 Celestial Silver Tundra 1794 TRD CM
    I purchased my truck with the urinal cakes leveling kit on the front. Would replacing them with the 5100's on the middle setting be a better option to achieve the same height? I appreciate the information as I am trying to learn more about the suspensions in these trucks.
    LiftMeUp and PermaFrostTRD like this.
  7. Jul 12, 2017 at 10:58 PM
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    Where did you purchase the 5100s from. I have been looking around for the best price.
  8. Jul 13, 2017 at 8:24 AM
    benrichardson87
    Ben
    Toytec.com ask for David
  9. Jul 13, 2017 at 8:27 AM
    benrichardson87
    Ben
    Depends on what your looking for in height and ride quality. The spacer lift works and it's keep but from what I did research on you loss some ride quality. Other people like them and they are really cheap. It's really personal opinion. Me personally I wouldn't put a spacer on anything when you can spend $200-$300 more and get and upgraded shock and not loose factory ride quality.
    10TundraSR5 likes this.
  10. Jul 13, 2017 at 9:59 AM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    If I remember correctly, Bilsteins specs are 1.71" on the middle setting and 2.58" on the top setting. Depending on the height of the spacers that are in there now and if you're satisfied with the current height, that will kind of determine where you'd want to set the 5100's. If you go to the top setting you'll want to do differential drop spacers. The ride quality should be better with the 5100's.
    mattyd170 likes this.
  11. Jul 13, 2017 at 10:25 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    the 5100 heights are a little bit different for the tundras. this is from toytec's website:
    • Adjustable in 3 positions for lift of .87", 1.57" or 2.28" (Adjustment required before assembly).
  12. Jan 19, 2018 at 5:53 PM
    Al476
    Al476 New Member
    @benrichardson87 I just purchased 5100s for my 2018 Tundra. I also want to use the mid settings. Did you have to get a differential drop kit? Curious if I need to purchase anything else for the install.
  13. Jan 22, 2018 at 6:36 AM
    benrichardson87
    Ben
    No I didn't buy anything additional, I'm pretty sure you only need the diff drop if you go more than 3 inches of lift.
  14. Jan 25, 2018 at 4:06 PM
    Al476
    Al476 New Member
  15. Jan 30, 2018 at 5:46 AM
    benrichardson87
    Ben
    Picture? What size tire you going to run?
  16. Feb 9, 2018 at 5:56 PM
    Al476
    Al476 New Member
    Running 285/65/18.
  17. Feb 9, 2018 at 5:59 PM
    Al476
    Al476 New Member
  18. Feb 9, 2018 at 6:04 PM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    I don' see a 275/75/r18 offered in the RG, did you mean 275/70r18?
  19. Feb 9, 2018 at 7:40 PM
    #49
    Rica25
    Ricardo
    Tulare
    Mine is also at top setting
  20. Feb 13, 2018 at 5:47 AM
    #50
    benrichardson87
    Ben
    Yes the 275/70r18 mistyped it when I wrote it my apologies
  21. Mar 4, 2018 at 6:49 AM
    #51
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
    @Al476, I like your setup. What offset wheel are you running?
  22. Apr 26, 2018 at 9:16 PM
    #52
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    OK, I'm looking to get my stereo done, but am also looking hard at doing this as well. I think I'm going to get the 5100's from Amazon and a friend will help me with labor.
    I'm leaning toward the top setting now which should pretty much level me out. I'm 36.5 in the front and 39 in the rear right now. I figure I can always add a 1" block later if I want some rake. Also, I'm 2 wheel drive so don't have to worry about the diff drop.
    Depending on if I rent a spring compressor or try to find a shop to swap the springs for me, this should put me right in the same budget range as the Readylift spacer kit, but with a much better setup.
    mattyd170 and duece292[QUOTED] like this.
  23. Sep 11, 2018 at 11:33 PM
    #53
    K6BRY
    K6BRY New Member
    2017 Black Tundra TRD 3/1 Lift Sittin' on 34s
    I like that setup! Is that the 5100s at the top setting in front with a 1 inch lift in the rear or what?
  24. Jan 23, 2019 at 8:16 AM
    #54
    Jpagansr
    Jpagansr New Member
    Joel
    2018 tundra Trd Sport
    I just installed 5100's few days ago on top setting with stock 20's, Ordered the 5100 and a pair of spring compressors the 5100's cost 390 front and back and tool cost 59.00 took me 3hrs taking my time to install and $69 to do alignment $518.00 Will post pics soon
  25. Jan 23, 2019 at 9:28 AM
    #55
    Pat
    Pat Sorta-new Member
    Pat
    Virginia Beach
    '16 MGM SR5 DC
    CAI, 5100's
    I've seen that some people add spacer shims to correct side lean when they put on 5100's, wouldn't those be bad like spacer lifts? Or is there something I'm missing here?
  26. Jan 30, 2019 at 10:26 AM
    #56
    LiftMeUp
    LiftMeUp New Member
    Anything on the rear?
  27. Jan 30, 2019 at 10:28 AM
    #57
    LiftMeUp
    LiftMeUp New Member
    What setting you have them on?
  28. Jan 30, 2019 at 10:29 AM
    #58
    LiftMeUp
    LiftMeUp New Member
    Ha. We're in the same boat. I need 3" on front and know I can achieve with the 5100s. I've seen plenty where people use the middle setting with two shims or the top setting with one. But same question, isn't that basically doing the same as a spacer????
  29. Jan 30, 2019 at 10:59 AM
    #59
    mattyd170
    mattyd170 New Member
    Rio Rancho, NM
    2020 Tundra Limited Crewmax with Leer shell. Calvary Blue
    Stock for now, but have TRD Rear Sway bar for it.
    It is more of a shim than it is a spacer. I did 5100's with a single shim and went from 36" in front to 38" by using the middle setting. The rears are 39 1/2 pretty much, so then I added a second CB shim and now I am at a solid 38 1/2" in the front on both sides and 39 1/4 (ish) in the back and it looks perfect. The shim adds about 1/2 inch, yes, technically it is a spacer, but it only adds a little to the preload of the spring. It is a better option overall, however, for the money and running around town mostly, a spacer lift is generally fine and isn't going to kill or hurt anything, unless you go bajaing or rock crawling all the time.
    The 5100's are great shocks and my shocks were garbage, so the ride was much better. I went months debating and researching on here before doing it and am happy with how it turned out. 5100's on middle setting and 2 CB shims on both front shocks. Nothing in the rear but new 5100's. Hope this helps.
    rv740, Ccraw2323 and JoshuaA like this.
  30. Jan 30, 2019 at 10:59 AM
    #60
    duece292
    Greg
    Green Bay, WI
    Nothing in the rear, just stock height. I'd like to go to something like a 3/1 but I don't think I'd get in the garage.
