Bilstein 5100 up front, fox rear ride question
Discussion in '2.5 Gen Tundras (2014-2021)' started by mrburns05, May 17, 2019.
  1. May 17, 2019 at 6:15 AM
    mrburns05
    mrburns05 [OP] New Member
    Jacob
    Menifee CA.
    2018 4.6L White DC SR5
    Maxtrac 3.5” Spindles Bilstein 6112 Icon AAL Icon 2.5” PB shocks Coachbuilder +1 Shackles AFE dry filter TRD AIA Magnaflow muffler TB Coolant Bypass
    I have been holding out for some fox 2.5” coilovers but they’re expensive and I’m gonna be buying tires and paying other bills for awhile before that happens.
    I have fox 2.0 performance shocks on the rear right now, and stock front. Seeing as I could get a pair of 5100’s for just over $200 (reuse stock spring) I wondered if the different valving between the brands front and rear would cause a weird ride (digressive with linear? or progressive?)? Was wondering if any of you have tried this and could help me decided if it would be worth getting the 5100’s for a slightly better ride and a little more height (I only want to go up the 0.8 setting as I already have maxtrac spindles in the front)
  2. May 17, 2019 at 6:59 AM
    monaco730
    monaco730 New Member
    16 Inferno Tundra
    Fox shocks, TRD Exhaust, TRD grill, TRD shift knob, weathertech floor/bed liners, ARE topper, FrontRunnerOutfitters cargo rack, Relentless cargo bars, color matched front bumper/side mirrors, fuel wheels, nitto RGs, K&N intake
    I was in the same boat as you. I had stock trd-off road suspension with a readylift 3/1. I wanted Fox but didnt wanna spend that kinda money all at once on the entire setup so i first did the rear (2.0 reservoir). No issues. I then got the 2.5" coilovers in the front. I love the whole setup. You won't be disappointed if you go that route.
    JNorman84 and mrburns05[OP] like this.
  3. May 17, 2019 at 7:00 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Your fine I had fox rear shocks on with the stock bilstiens till I got
    My 2.5s
    monaco730 and mrburns05[OP] like this.
  4. May 17, 2019 at 7:04 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    If you are running stock shocks in the front now with the Fox in the rear with no issues, then the 5100 in the front paired with the Fox in the rear will be the same or better. Should be good to go.
    mrburns05[OP] likes this.
