Bilstein 5100 top vs mid setting ride quality
Discussion in 'Suspension' started by BlueRibbon4x4, Mar 1, 2020.
  1. Mar 2, 2020 at 7:02 AM
    Ant131313
    Ant131313 New Member
    2019 Toyota Tundra TRD- Midnight black metallic
    Tundra all weather mats Tundra bed mat APS iBoard 5" matte black running boards
    Okay, awesome to know. I'm going to do top setting on stock 5100 kit and hoping it's going to be level for us. Doing 5100 kit in rear too and not sure why the instructions say the rear is 0-1" height increase. We have a 2019 Crewmax TRD off-road 2wd so It says which factory tundra you have plays into the height increases that are listed by Bilstein....
    ordered a set of new LT285/70/18 Nitto Exo Grappler AWT's to go on the stock 18" TRD wheels for the setup and hoping it turns out good.
  2. Mar 2, 2020 at 7:30 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    You may be lifted higher in the front with a 2wd, less weight. 5100 in rear with 0-1" is to allow for lifting the rear up to 1". They also make a 5100 that goes up to 2".
  3. Mar 2, 2020 at 8:58 AM
    Ant131313
    I wish some tundra users with this setup can post pics.....would be so helpful. Anyone have 2019 TRD 2wd with this setup?
    Thanks
    Rica25 likes this.
  4. Mar 2, 2020 at 10:31 AM
    SILVER FOX
    SILVER FOX New Member
    GARY
    IDAHO
    2015 SILVER DOUBLE CAB
    BULL BAR ** FENDER FLAIRS ** TINTED WINDOWS ** VISOR VENTS.....so far. :)
    Do you want actual pics of the shock/spring/fender setup? If so let me know.
    This shows the stock ride height (left side) and my leveled truck. (right side)
    I went with 5100's, top setting and used the stock springs. The springs were tested by the suspension shop and found to be "as new" which is why they are used again I hope this helps.
  5. Mar 2, 2020 at 10:33 AM
    Ant131313
    Yes, this helps a ton! Anymore pics of your rig and setup from different angles? Also, how is the ride on the top setting in your opinion?
    Thanks @SILVER FOX .
  6. Mar 2, 2020 at 10:58 AM
    SILVER FOX
    GARY
    IDAHO
    BEFORE:
    AFTER:
    One thing I did notice, that the shape/"slope" of the bed gives an illusion of it being slightly higher than the front. You can see that the bottom of the truck is fairly level with the ground....I searched for quite awhile looking for a level location; this was the best I found. All this make sense? Kinda hard to describe.
    Also, there were no spacers used.
    Let me know what else you need... happy to help. :)
    rv740 likes this.
  7. Mar 2, 2020 at 11:03 AM
    Ant131313
    Helps yes! Did you measure from the ground to start of fender for both front and rear? It does appear to be pretty much level. I am just wondering if my 2019 crewmax will be too much different for the front setting to the top b/c I have a TRD off-road bu 2wd so less weight on the truck and Bilstein site says that there will be differences between different model tundra and setups so just wondering. I just don't want to set in the middle setting and then pay for install of the 5100 kit only for it not to be level and still lower in the front so maybe I should just go to 3rd highest setting. How is the ride of yours after installing the kit and the top setting for the front? I've heard this 5100 kit rides amazing and I'm hoping it does lol...we love how ours rides now as we have the stock 4600 Bilstein shocks (yellow and blue) on our TRD and one of the reasons we bought this exact model with these shocks and the 18" TRD wheels. Thanks!
  8. Mar 2, 2020 at 11:25 AM
    SILVER FOX
    GARY
    IDAHO
    It measured just under 2 inches from stock. Rear stayed the same.
    I was very hesitant and unsure of the outcome also...probably like all of us.
    What I did, was make an arrangement with the manager regarding the possibility of changing the position of the shock setting, and a price, just in case. So we decided to start on the highest setting then work down to the middle. Turns out we nailed it, based on a lot of research.
    Share before/after pics with us. :)
    rv740 likes this.
  9. Mar 2, 2020 at 12:21 PM
    10TundraSR5
    10TundraSR5 Happy Tundra owner
    Tennessee
    2010 Black Tundra SR5
    Curse you Perry the Platypus!
    Got a 2010 SR5 CMAX 4x4 a year and half ago. Back in December I finally got 5100's all the way around with the fronts on mid setting. I figured the stock ones were originals so it wouldn't hurt to replace them PLUS I am almost level. No complaints and the truck rides great!
    BlueRibbon4x4[OP] likes this.
  10. Mar 2, 2020 at 1:34 PM
    SiberianTundra
    SiberianTundra I heard Unicorns get horrible MPG
    Greg
    War Machine
    Camper shell, LED lighting VLEDs, Front Camera, Pro Comp wheels. Trd HID LED headlights. ESP storage rear seats.
    what is that grill you got with amber lights ?
  11. Mar 2, 2020 at 3:39 PM
    BlueRibbon4x4
    BlueRibbon4x4 [OP] Let’s color match it
    Geno
    2015 Blue Ribbon 4x4
    It’s an EAG Raptor grille off Amazon
  12. Mar 2, 2020 at 4:56 PM
    1999cutiger
    1999cutiger Top Flow Lifestyle
    2017 Toyota Tundra SR5 4x4
    RBP 67R AK-8 20x9 wheels General Grabber ATX 275/60/20
    5100’s on middle setting 4x4.
    Ride is good.
  13. Mar 2, 2020 at 5:37 PM
    Ant131313
    Thanks everyone. Anyone with pics on top setting for the 5100s and a crewmax?
    Rica25 likes this.
  14. Mar 2, 2020 at 5:43 PM
    SILVER FOX
    GARY
    IDAHO
    What kind of wax/cleaners do you use? Very, very nice. :hattip:
  15. Mar 2, 2020 at 6:11 PM
    SiberianTundra
    Greg
    War Machine
    This is a grill for 3rd gen or is yours 2nd in that picture ?
    Rica25 likes this.
  16. Mar 2, 2020 at 6:34 PM
    BlueRibbon4x4
    Geno
    Mine is a 3rd gen but if you need one for a 2nd gen, they make those too.
    Rica25 likes this.
  17. Mar 2, 2020 at 7:19 PM
    OONIGHTTRAIN
    OONIGHTTRAIN New Member
    jesse
    silverado 2500 duramax 4x4
    so im a total idiot when it comes to this whole bilstein thing..
    you say thats middle setting? would you say thats pretty level or ?
    Rica25 likes this.
  18. Mar 3, 2020 at 6:01 AM
    Ant131313
    anyone on top setting with a newer crewmax? pics? Thanks
    Rica25 likes this.
  19. Mar 3, 2020 at 2:00 PM
    #49
    Ant131313
    So to clarify yours in on the top (3rd) highest setting for the Bilstein 5100 kit? How is the ride quality on top setting @SILVER FOX ?
    Thanks
    Rica25 likes this.
  20. Mar 3, 2020 at 4:56 PM
    #50
    1999cutiger
    Thanks.
    I use the Klasse twins.
    Rica25 likes this.
  21. Mar 3, 2020 at 4:57 PM
    #51
    1999cutiger
    It was very close but appeared slightly nose high. I have since added 3/4” shackles on the rear...it’s perfect.
    Rica25 likes this.
  22. Mar 3, 2020 at 5:52 PM
    #52
    BlueRibbon4x4
    Geno
    Yep! 1-1/4” spidertraxx
    TRDSPORT118[QUOTED] likes this.
  23. Mar 3, 2020 at 8:03 PM
    #53
    OONIGHTTRAIN
    jesse
    no kidding.. damn.. ive got a set of 5100s on the way for the front of my 2020 crewmax 4x4.. the front of the truck is almost exactly 3 inches lower than the rear measuring from the ground to the middle of the wheel wells.. my plan was to have them set at the highest setting which according to bilstein is 2.28".. according to my brilliant math skills, that would mean the nose would still be about 3/4" lower than the rear..
  24. Mar 3, 2020 at 8:35 PM
    #54
    r1-superstar
    DB
    UTAH
    You have to understand a lot of us probably measure like you did, but I doubt the wheel wells are the same distance from the ground at level (meaning the way the body was made). Instead measure something like the bottom of the cab at the rear of the front tire and the front of the rear tire. That is a constant.
    Rica25 likes this.
  25. Mar 3, 2020 at 9:30 PM
    #55
    SILVER FOX
    GARY
    IDAHO
    Yes, on the top setting. Smooth ride, I really don't feel any change; neither does my wife.
    There is that apprehension we all felt. It will work out; plenty of research will bare that out.
    Boerseun and Rica25 like this.
  26. Mar 4, 2020 at 7:41 AM
    #56
    r1-superstar
    DB
    UTAH
    I took these pictures because when I was researching, no one else did. Here are four different pictures of my Tundra.
    Bone Stock
    Bilstien 5100s on the middle setting (level)
    Bilstien 5100s on the top setting, shims, shackles at 2" and 5100s in the rear
    Bilstien 6112s on the top setting, shims, SPC UCAs, Boss 4x4 shackles at 2" and 5100s in the rear, 305/65-18 Ray 10s 18x9 +25mm.
  27. Mar 4, 2020 at 7:43 AM
    #57
    Ant131313
    Gorgeous setup @r1-superstar!
    Thank you for the pics of differences.
    r1-superstar likes this.
  28. Mar 4, 2020 at 7:45 AM
    #58
    r1-superstar
    DB
    UTAH
    Sorry for the confusion earlier, I have since edited my pics in my build thread to depict all that was done. Hope these pictures will help you in your decision.
  29. Mar 4, 2020 at 8:21 AM
    #59
    RatedEpic
    RatedEpic New Member
    How do you get 2" shackles... all I see is 1-1.5
    BlueRibbon4x4[OP] and Rica25 like this.
  30. Mar 4, 2020 at 10:08 AM
    #60
    Ant131313
    Anyone else on top setting 5100 kit with a crewmax 2wd ?
    Rica25 likes this.
