Bilstein 5100 Tire Size Pics
Discussion in 'Suspension' started by jetsweeps, Mar 13, 2020.
  1. Mar 13, 2020 at 6:46 AM
    jetsweeps
    jetsweeps [OP] New Member
    I just purchased a 14 Crewmax TRD and I ordered Bilstein 5100 front and back. I was thinking about putting the fronts at the top setting and either running 275/70 or 285/75 on stock TRD 18 inch wheels. I'm sure this has been discussed many times on here before so I apologize for the redundancy.
    Can anyone post pictures of bilstein 5100 on top setting running 275/70 or 285/75 on stock TRD 18 inch wheels as well as any mods that needed to be made?
    Thanks in advance
    georgiey22 likes this.
  2. Mar 14, 2020 at 4:15 AM
    Kojack
    Kojack New Member
    MIke
    Black Mountain, NC
    2017 Tundra XSP CrewMax
    8A0D355D-F599-4896-B7DD-0ADA7C693837.jpg Bilstein 5100’s all around. XLT’s in 285/60/20’s on +18 rims. Tires are 33.5” Sits perfectly level. AC66F62D-A4C5-47C5-ABE1-B98057DA2579.jpg 9B036331-4D9B-4A8E-B9FF-B4DC175C2D2E.jpg
    Removed front small mud flap and had to bend the stock skid plate ends just a little. Removed front sway bar. Trust me.... you’ll want to do that! No other suspension mods yet. Have Toytech shackles on the bench in the garage to install to help with towing the boat.
  3. Mar 14, 2020 at 4:18 AM
    jetsweeps
    What setting are you on? Middle?
  4. Mar 14, 2020 at 4:19 AM
    Kojack
    Kojack New Member
    MIke
    Black Mountain, NC
    Top setting. Glad I went with that setting. Gave a true 2.5” front lift. No lean
  5. Mar 16, 2020 at 4:29 AM
    jetsweeps
    I like that look are those 275/70?
  6. Mar 16, 2020 at 4:56 AM
    Kojack
    Kojack New Member
    MIke
    Black Mountain, NC
    285/60/20
  7. Mar 19, 2020 at 7:49 AM
    2019-1794 New Member
    2019 1794 Crew Max 4x4
    275/65/20 5100's middle setting
  8. Mar 24, 2020 at 4:45 PM
    jetsweeps
    I ended up going on middle setting. Bought 20 inch oem limited wheels and put 285/60 r20 toyo at2 on them. No shims no wheel spacers. Rubbed at full on skid plate, popped off skid plate trimmed corner and that was it.
  9. Mar 24, 2020 at 4:50 PM
    Kojack
    Kojack New Member
    MIke
    Black Mountain, NC
    That post is useless without pics....
  10. Mar 24, 2020 at 4:56 PM
    jetsweeps
    My bad I dont have great pics as I just got it back tonight.
    After shocks
    After tire/wheel
    ATV25 and InfernoToyo like this.
  11. Mar 24, 2020 at 5:11 PM
    Kojack
    Kojack New Member
    MIke
    Black Mountain, NC
    Looks great man! That’s definitely the right size for our trucks at that height.
  12. Apr 4, 2020 at 9:22 AM
    Dan14CrewMax
    Dan14CrewMax New Member
    2014 Tundra CrewMax 4x4
    I posted in another thread, but got no answers. I'm about the jump into some mods and thinking about going with something similar to yours: Front Bilstein 5100's at middle setting, 285/60/20 Toyo MT's hoping to go with the 20" XD 778. The XD's are offered at 20x9 (35mm) OR 20x10 (-12mm). I'm most concered with rubbing on the UCA. I've already taken off the front flaps. Any words of advice?
  13. Apr 9, 2020 at 9:12 AM
    jetsweeps
    For me personally I wouldn't go with the -12mm offset wheels. They will poke out way too far. the +35 mm should be perfect with this tire size and should sit about flush. Mine are on stock limited 20s with a +60 mm offset and I still have UCA clearance. All I had to do was trim the skid plate.
  14. Apr 10, 2020 at 2:47 AM
    Dan14CrewMax
    Thanks for the response! I'll be sure to post pics when completed
  15. Feb 15, 2021 at 10:03 PM
    Calidude7
    Calidude7 New Member
    did you end up going with that setup ? if so do you have any pics , thanks!!!
  16. Jan 17, 2022 at 7:47 PM
    17-xsp-crewmax
    17-xsp-crewmax New Member
    2017 black xsp crewmax
    I’m installing the 5100’s next week and think I’ll put them at the highest setting. I’m debating between 285/60/20 or 275/65/20. I’m hoping they will fit.
  17. Jan 25, 2022 at 5:45 PM
    ehidal1
    ehidal1 New Member
    Eric
    2020 Tundra Limited cement
    I was going to go 5100's on the middle setting and hoping 285/60/20's would fit with the +50 offset TSS wheels. Think that would work or do i need to go top setting?
  18. Jan 26, 2022 at 5:32 AM
    ehidal1
    ehidal1 New Member
    Eric
    How is the ride on the top setting compared to stock?
