Bilstein 5100 HELP!
Discussion in 'Suspension' started by vanilla.chinchilla, May 22, 2018.
  1. May 22, 2018 at 11:12 AM
    vanilla.chinchilla
    vanilla.chinchilla [OP] New Member
    2001 tundra sr5 with topper and Wheelers AAL
    Needs vs wants
    Im in the middle of my 5100 install and have hit a road block.... The old (stock) springs won't seat correctly. The 5100 spring seats won't slide all the way into them and obviously I'm not installing them that way! I'll work on pictures, but I received Bilstein 24-261425 struts in the mail. Do I have some bad springs and now need to get new ones? HELP!
  2. May 22, 2018 at 11:41 AM
    Rica25
    Ricardo
    Tulare
    Need more pics
  3. May 22, 2018 at 11:48 AM
    vanilla.chinchilla
    Needs vs wants
    Let me know what you would like pictures of. There's the old one seated nice and easy....
  4. May 22, 2018 at 11:51 AM
    Rica25
    Ricardo
    Tulare
    Are those stock shocks?
  5. May 22, 2018 at 11:52 AM
    Rica25
    Ricardo
    Tulare
    Picture of the whole shock
  6. May 22, 2018 at 11:55 AM
    vanilla.chinchilla
    Needs vs wants
    Finding that out now. They are cheap-o quick strut ones. I'm sure they came pre-assembled and now I need to track down some actual springs. The best part is I took a grinder to the old ones and now there's no putting them back together. Woops.
  7. May 22, 2018 at 11:57 AM
    Rica25
    Ricardo
    Tulare
    Yeah they didn't look OEM.......just need to get original ones now.....i have exact same set 5100s all 4
  8. May 22, 2018 at 12:09 PM
    vanilla.chinchilla
    Needs vs wants
    The dealership quoted me at $560 for both springs. Wowzer. Any aftermarket options I could go with that you're aware of that wouldn't push my front end too high?
  9. May 22, 2018 at 12:23 PM
    15whtrd
    15whtrd Mr. Blonde
  10. May 22, 2018 at 12:51 PM
    Kanobi13
    Kanobi13 New Member
    I would look at eibach springs at wheeler offroad under 200 for pair and would give you 2" level
  11. May 22, 2018 at 12:53 PM
    15whtrd
    15whtrd Mr. Blonde
    Wonder how compatible they are with icon. Meaning the icons lift your truck with the stock springs. Heights depended on where you set them at. So with a 2 inch lift and spring I would imagine you would want them on one of the lowest settings.
  12. May 22, 2018 at 4:53 PM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    Wasn't there a guy on here a couple of days ago trying to unload some factory coilovers to free up garage space? Seemed like he was more worried about getting rid of them and didn't want much money.
  13. May 22, 2018 at 5:15 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I ran into this same problem. The springs from Monroe Quickstruts will not fit the 5100's, it would take a lot of grinding to get them to fit trust me I tried.
    I had the same sticker shock from factory springs and ended up buying OME 885 springs and Taco upper mounts. Just to get the truck on back on the road if your old shocks are done for you can buy just normal Monroe shocks to get by.
  14. May 22, 2018 at 7:22 PM
    This^^^^^
  15. May 22, 2018 at 7:31 PM
    With Bilistein you need to run their coils
  16. May 22, 2018 at 7:32 PM
    vanilla.chinchilla
    Needs vs wants
    Thanks for the quick responses today y'all! I had to get my truck back on the road and into the shop for a transfer case leak and I live in a place where getting parts is all shipping, so it just wasn't to be. Got some inexpensive strut coil preassemblies (I'm sorry truck), and when those wear out, I'll try this saga again. Really thought I'd done my homework, but of course the inexpensive aftermarket parts got me again. Thanks previous owner...
    In other news, if anybody needs bilstein 5100 struts for a first gen, I'll knock a little off retail and send them your way!
    T-rex- in your last post, do you mean "OME" instead of bilstein?
