Bilstein 5100 Fitment on 2020 CM
Discussion in 'Suspension' started by CNE0207, Dec 18, 2019.
  1. Dec 18, 2019 at 5:21 PM
    CNE0207
    CNE0207 [OP] New Member
    Arvada, CO
    2020 Cement CM Limited
  2. Dec 18, 2019 at 7:11 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    2020 is the same as 2019 for fitment of 5100s as they only changed some little things on the truck like a slightly larger screen with crappy and a button for the starter.
    BravoDeltaRomeo likes this.
  3. Dec 18, 2019 at 8:59 PM
    CNE0207
    Arvada, CO
    Thanks, that’s what I figured but wanted to double check. I see some posts with guys leveling with the 5100s and running into some issues with the TSS radar, etc.
  4. Dec 18, 2019 at 10:50 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    That is something to worry about. Although, it isn’t a fitment issue per se, it may cause issues with TSS as some have reported.
  5. Dec 19, 2019 at 5:27 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    There are more 'concerns' about issues with the TSS than actual 'issues'. Most of the leveled or even lifted trucks on this forum have reported no issues. I have a 3/1.5 level and no issues. (other than the dealer saying that they will not work on the TSS when the truck is modified, so keep that in mind when you are still under warranty)
  6. Dec 19, 2019 at 5:43 AM
    Iowa12tundra
    Iowa12tundra New Member
    2012 tundra crew
    Seems like people try maintaining a rake when lifting to keep the TSS happy.
  7. Dec 19, 2019 at 7:26 AM
    CNE0207
    Arvada, CO
    I figure if I leave the rear and go with the middle or 4/5 setting I should still have a slight rake and it should keep my TSS ok.
  8. Dec 20, 2019 at 2:07 AM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    I installed 5100 in my 2020 dc with no issues with the TSS. 2/0, 2/-1, 2/1. I have air springs.
  9. May 3, 2020 at 10:53 AM
    Neb17
    Neb17 New Member
    2017 Toyota Tundra 4x4 Limited
  10. May 3, 2020 at 10:54 AM
    Neb17
    Neb17 New Member
  11. May 3, 2020 at 12:24 PM
    CNE0207
    Arvada, CO
    Yep, they fit. I’m running them in the middle setting since.
    JimboSlice413 likes this.
  12. May 4, 2020 at 11:04 PM
    ckkone
    ckkone New Member
    SLC, UT
    Yes they fit, hasn’t changed since 07’
  13. May 5, 2020 at 12:04 AM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    Any TSS issues?
  14. May 5, 2020 at 7:02 AM
    CNE0207
    Arvada, CO
    None at all
  15. Mar 19, 2021 at 6:13 PM
    Tundradude11
    Tundradude11 New Member
    I just opened my bilStein 5100 shocks to get ready and the washer holes are to small to go over the treaded rod, the factory shocks have a smaller rod so those washers won’t work either?
  16. Mar 19, 2021 at 7:00 PM
    CNE0207
    Arvada, CO
    Hmmm... wrong part #
  17. Mar 20, 2021 at 3:01 AM
    R0CKETMAN
    R0CKETMAN IG: @rocketmanmtb
    NGAMTNS
    '17 TUNDRA TRD PRO CEMENT ‘15 TUNDRA SR-5 WHITE
    Use stock hardware and supplied nut for rear.
    2nd/3rd Gen
    Correct part #
    front
    Bilstein (24-232173) B8 5100
    rear
    Bilstein (24-186971) 46mm
    You will not use these two washers
