Bilstein 5100’s on front
Discussion in 'Suspension' started by CARLHEIZER, Oct 13, 2019.
  1. Oct 13, 2019 at 8:33 AM
    CARLHEIZER
    CARLHEIZER [OP] New Member
    San Diego
    2019 TUNDRA 1794 EDITION
    LINE-X, BAK MX4 WITH BAK BOX, UPGRAGED SOUND SYSTEM BY OEM AUDIO + AND CERAMIC WINDOW TINT - ALL SIX WINDOWS.
    Thinking of leveling the Tundra. Should I put the shocks on the middle ring or upper ring to level?
  2. Oct 13, 2019 at 9:00 AM
    Tundrajoe
    Tundrajoe New Member
    Joe
    2014 crewmax super white
    Bilstein 5100s cooper at3 xlts, tint, full custom exhaust, methods
    I have mine on the top setting and it sits perfect!
    619Tundra likes this.
  3. Oct 13, 2019 at 9:39 AM
    Mrpgfernandez
    Mrpgfernandez New Member
    Pristine
    2018 Tundra Crewmax
    Where and how much did you get your blisten shocks for. I want to do the same for my truck. I loved it out with a leveling kit but people have told me that buying the blisten 5100 shocks is a better choice and gives you and better ride. Is this true. Should I put blisten a on the back too.
  4. Oct 13, 2019 at 9:50 AM
    CARLHEIZER
    San Diego
    Saw them on summit for about $230/pair. Am told ride quality stays the same.
  5. Oct 13, 2019 at 9:51 AM
    CARLHEIZER
    San Diego
  6. Oct 13, 2019 at 9:51 AM
    CARLHEIZER
    San Diego
    Thanks. What tire size did you go with?
  7. Oct 13, 2019 at 10:39 AM
    MacCTD
    MacCTD New Member
    2010 CM 4x4
    5100s
    I put them in the middle and it seemed level to me even maybe slightly nose high so I added a 1" block in the rear, I like the stance, opinions vary on this however....
  8. Oct 13, 2019 at 11:46 AM
    CARLHEIZER
    San Diego
  9. Oct 13, 2019 at 12:21 PM
    Tundrajoe
    Joe
    I run 295/70/18 bought at 4wheel parts, full set front and rear for about $400 ride is better than stock
  10. Oct 13, 2019 at 12:47 PM
    Boudin
    Boudin New Member
    Louisiana
    Tundra#4
  11. Oct 13, 2019 at 1:02 PM
    CARLHEIZER
    San Diego
    Thx for the pic. Good stance. Looks like upper ring would have the possibility of being a tad bit higher than rear - which is exactly what i do not want.
    Boerseun likes this.
  12. Oct 13, 2019 at 1:06 PM
    Boudin
    Boudin New Member
    Louisiana
    Tundra#4
    Yea my previous Tundra I ran top setting and it was slightly nose high.
  13. Oct 13, 2019 at 2:57 PM
    Tundrajoe
    Joe
  14. Oct 13, 2019 at 2:59 PM
    Middle setting. :thumbsup:
  15. Oct 13, 2019 at 3:00 PM
    Tundrajoe
    Joe
  16. Oct 13, 2019 at 3:00 PM
    Tundrajoe
    Joe
    Top setting, before and after wheels
  17. Oct 13, 2019 at 3:05 PM
    antwon412
    antwon412 New Member
    2006 CC SR5
    How easy it is to adjust these once installed? If I put them on the highest setting would it be a huge deal to lower it to the medium setting?
  18. Oct 13, 2019 at 3:06 PM
    Tundrajoe
    Joe
    It's a pain in the butt, have to use a strut compressor and take the load off of the spring
  19. Oct 13, 2019 at 5:21 PM
    CARLHEIZER
    San Diego
    Probably as expensive as having them installed In The first place.
  20. Oct 13, 2019 at 7:30 PM
    Tundrajoe
    Joe
    Absolutely, only do it once if possible
  21. Oct 13, 2019 at 7:52 PM
    owb2gp
    owb2gp New Member
    ID
    Top setting and 1 inch block in the rear.
  22. Oct 13, 2019 at 9:48 PM
    CARLHEIZER
    San Diego
    Truck looks good Joe BTW.
  23. Oct 13, 2019 at 9:55 PM
    BigSkyTaco
    BigSkyTaco Successfully Social Distancing since 1998
    Aaron
    W. Glacier, MT
    2011 White DC Tundra TRD
    Just did 5100s front and back this week. $360 from 4WP and one of my customers installed them and aligned for $355. Middle setting and looks great, no visible lean. Noticeable difference from stock.
  24. Oct 13, 2019 at 9:57 PM
    CARLHEIZER
    San Diego
    Those sound like good prices. Thx
  25. Oct 13, 2019 at 10:05 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    Bilstein 5100/5160 Toyo at2 295/70r18 Ray10 GunMetal
    I put 5100 on the front and 5160 on the rear. I put the 5160's on a couple months after the front. Both front and back each firmed up the ride significantly but in a very good way. I can easily compress the factory shock with one hand, minimal effort. The 5100 is strong as shit and I struggled getting the rear ones in without rigging up something on a jack. I also went middle setting, its up to your preference. Top is nose high, middle is slight rake. But with how huge our hoods our the middle looks very level.
    Middle setting on the right Tundra
  26. Oct 13, 2019 at 11:52 PM
    Warhawk
    Warhawk New Member
    Hot Springs, Arkansas
    Nissan Titan
    I must be missing something. The 6112 leveling kit is $600. But the 5100 shocks are $200 for the pair and do the same thing?
  27. Oct 14, 2019 at 7:38 AM
    JimboSlice413
    Bakersfield
    The 6112s will come with new springs. Sometimes you can have them ordered preassembled. The 5100s will require an install as they reuse factory springs. In some cases it's cheaper to get the 6112s preassembled and install them in your garage. They both give a lift but the 6112 is a larger diameter shock
  28. Oct 14, 2019 at 9:05 AM
    mrmisky1969
    mrmisky1969 New Member
    James
    Torrance, California
    2016 Toyota Tundra TRD
    5100 Bil’s on Middle Setting 275/70r18 Falken WildPeak ATs Rear Firestone Airbags ECCP Towing Mirrors LED Int/Ext lighting White Out Front Door Handles Blackout Emblems Custom Painted Front Grille
    Great info guys! New to the forum and I'm interested in doing the same to my 2016. Just one question - Does anything have to.be done to the transfer case to help the new angle of the truck? Meaning a spacer as you would with a level kit. I'm not going to need blocks in the back as I have air ride for my towing capabilities.
  29. Oct 14, 2019 at 9:06 AM
    CARLHEIZER
    San Diego
    Yeah the shocks are about $230, install is about 1 to 1.5 hours per side then alignment. So I am figuring $600 ish.
  30. Oct 14, 2019 at 9:08 AM
    CARLHEIZER
    San Diego
    Nothing to transfer case that I know of. The middle ring setting on the shock is supposed to be about a 1.5” lift.
