Bike mounts for track
Discussion in 'Sports, Hobbies & Interests' started by Diverguy, Apr 16, 2018.
  1. Apr 16, 2018 at 12:09 PM
    Diverguy
    Diverguy [OP] Breathes under water
    Leon
    PA, USA
    2018 Tundra Limited TRD Offroad-Inferno
    Windows tinted, window visors. Bedrug, led bedlights, Nfab nerf step bars, Lund toneau cover, Evo One remote start, BAMufflers 8"
    After looking for bike mounts that work with the track system for a bit, I found a couple of options. One was $65 each, the other, from Toyota was $95 each. These are the brackets that the front forks attach to, after removing the front wheel.
    I found some “universal” brackets on EBay for $20 for a pair. I cut, drilled, and tapped some 1/4”x1”x1 1/2” stainless, added some stainless bolts, and they work perfectly!
  2. Apr 16, 2018 at 1:31 PM
    Skippy
    Skippy Standing for the Flag
    San Antonio US of A
    2016 Tundra 1794
    Can you provide the link pls?
    831Tun likes this.
  3. Apr 16, 2018 at 1:44 PM
    Diverguy
    Leon
    PA, USA
  4. Apr 16, 2018 at 4:00 PM
    jeffw6236
    jeffw6236 New Member
    Jeff
    San Antonio
    2019 MGM CrewMax 4x4
    DiamondBack HD Katzkin
    Cool. Way less than I spent. I got the Rocky Mounts that work with a track system. They do lock so I guess that’s part of the extra cost. I installed some leftover unistrut on top of my diamondback cover and they work great.
  5. Apr 16, 2018 at 4:12 PM
    eddie98
    eddie98 New Member
    Atlanta, GA
    2018 MGM CM
    N-Fab Podium Steps, Line-X, Bed Lights
    I did the same thing for my Tacoma. Bought some universal ones at my bike shop
    Diverguy [OP] likes this.
  6. Apr 16, 2018 at 4:49 PM
    Hoologan
    Hoologan New Member
    California
    18 Cement Limited Crewmax TRD
    I did the same thing on my Titan, except I modified one of the cleats so it was removable. For the Tundra I went with a Rockymount because I need it to lock.
  7. Apr 18, 2018 at 1:50 PM
    Diverguy
    Leon
    PA, USA
    Works great! $25 for two
  8. May 14, 2018 at 10:25 PM
    kodyklb
    kodyklb New Member
    Kody
    I have a diamondback cover on my F-150...I have the same exact mountain bike as well, strangely enough. Trek XCaliber and also a Trek cyclocross (crossrip). I'm looking to do this same exact kind of setup with a fork block.
    How did you go about mounting the unistrut on top of your cover?
  9. May 15, 2018 at 5:30 AM
    Levidale08
    Levidale08 New Member
    Kevin
    Gardendale,Tx
    2015 TRD PRO
    Homemade bed rack with extra spare with Rhino rack,two jerry cans mounted in the bed
    It’s not the kind of rack your talking about but this one is nice. It sits up nice and high for wheeling 6F5FAC3A-5CAF-4F6A-BF33-CC7A28A77242.jpg
    Mountun Goat and smslavin like this.
  10. May 15, 2018 at 6:20 AM
    jeffw6236
    Jeff
    San Antonio
    Pics below. I painted the unistrut and washers with Bed liner spray from Home Depot. To block any water I used 3m Moisture sealing electrical tape on both sides (between the unistrut and the cover and between the underside washer and the cover. BTW.... I use that tape as a cheap chainstay protector on the bike as well. I do also use a strap to keep the bikes from sliding around when turning corners. They’d probably be fine without but seems like a good idea absent a rear tire tray.
    7447F339-DAC0-47E0-8A14-BA6D70E369E7.jpg 76B1D8B0-FF87-4A59-9BF7-95B557A65EFF.jpg 3553E8B3-22B0-4A90-A281-13A8F3DDF6E1.jpg
  11. May 15, 2018 at 7:14 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  12. May 15, 2018 at 7:24 AM
    tlr641
    tlr641 New Member
    Robb
    Oregon
    2018 Tundra Sport
    Trd dual exhaust, bilstein 5100’s, tint
    I got the Rocky mounts, wanted the locking ability.
