Bike Mount for Bed Rails
Discussion in '2.5 Gen Tundras (2014-2021)' started by SALAZAR44, Aug 6, 2018.
  1. Aug 6, 2018 at 9:26 AM
    SALAZAR44
    SALAZAR44 [OP] New Member
    Victor
    2016 Tundra SR5, Mag Grey
    RC Steps Plasti Dip Badges Aux Reverse Lights 4" pods Fuel Krank Wheels / Falken Wildpeaks ATW3 175/70/18
    I made a couple of bike mounts that attach onto the bed rails. I really liked the way they came out and wanted to share them with you all. Let me know what you think and if you have any questions. I would say that each one came out to about 28 bucks. I bought all the parts inside OSH (except for bike mounts), but you can probably get them at any local hardware store.
    My first issue was drilling big ol' holes for the huge 5/8" bolt to fit through. I used a stepper bit. Then I bolted together the two halves using the pre-drilled holes and tested them out on the bed rail. I did have to remove a screw to slide the square nut back, but its not a huge issue. Then I drilled the holes in the bracket to mount the bike mount. Once assembled, I sprayed the bracket with some bed liner spray paint I had already.
    My goal was to create mounts that will be able to sit under my tonneau cover. I also wanted to just flip the cover back and mount the bikes sideways so I didnt have to remove the cover everytime.
    Qty - Description
    2 - brackets mounted together
    https://www.homedepot.com/p/Simpson-Strong-Tie-Z-MAX-2-in-x-6-in-12-Gauge-Galvanized-Medium-L-Angle-ML26Z/202071149
    2 - 5/8 square nut for inside rail
    http://www.osh.com/c/Midwest-Fastener-5-8-11-Square-Nut/p/1990993
    2 - 5/8 jam nut to secure bracket
    http://www.osh.com/c/Midwest-Fastener-5-8-11-Coarse-Hex-Jam-Nuts/p/1990050
    2 - 5/8 Bolts to fit inside square nut.
    cant find a link for them.
    4 - nylon locking nuts and 4 bolts to secure angle brackets together
    cant find links for them. test fit in store.
    1 of these depending on your needs
    https://www.amazon.com/gp/product/B000AO7GRG/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
    https://www.amazon.com/gp/product/B01ENW5P3M/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
  2. Aug 6, 2018 at 9:43 AM
    danz75
    danz75 New Member
    Everett, WA
    18' Cement SR5
    OEM LED headlights, Rigid SAE foglights, Go Rhino RB10 running boards, ARE Classic CX
    I've been searching for DIY bed rail mounts for my road bike. Might have to try this out. FWIW, the sunlite mounts were cheaper on ebay
  3. Aug 6, 2018 at 9:58 AM
    neoflex
    neoflex New Member
    Charlotte. NC
    Sweet set up. I like that the bikes sit sideways taking up minimal bed space.
  4. Oct 11, 2020 at 6:10 AM
    Voda48
    Voda48 New Member
    Wisconsin
    2016 Platinum
    That is slick. How has it held up for you? I am looking at a tundra and researching bike options (I have a mtn, road, and trail bike that I ride). This seems like what I was hoping to find for a tonneau solution
  5. Oct 12, 2020 at 1:28 PM
    chainslap
    chainslap New Member
    Phoenix
    Another option for those just looking for a quick bed mount is to just use some T-Nuts. I assume this would also fit under a tonneau cover? My bike is too long to fit sideways...ha
    jvfBI_XnfQwXDTw8-SoOejKeabAdUrUKV5HTOFNj_c4dccf6dcef54baf19eda0d56ca680de2d173328.jpg
    OHOr0NRT6_ZTOCN3yFfKYBaoZgWJavWA0vAJAvyP_e70f8f83711b55411d668be6f1acdd4d301e40d9.jpg
    PoppaGrizzly likes this.
  6. Mar 5, 2023 at 4:51 AM
    Arpiland
    Arpiland New Member
    Andreas
    2018 CrewMax SR5
    Do you have a short bed and what size is your mtb?
  7. Mar 14, 2023 at 9:30 PM
    Arpiland
    Arpiland New Member
    Andreas
    2018 CrewMax SR5
  8. Mar 15, 2023 at 8:34 AM
    Lassie
    Lassie New Member
    HKM
    TAMPA, FL
    Nice idea!!
    I am doing different method. My bike's front wheel is not quick release and need a hex key to remove it from fox 36 fork. For that reason, I am a big fan of tire hold. I assembled 1x4 woods to make a DIY tire hold rack. Put this on front side of bed vertically. And mount rear tire in this DIY wood rack, only by this rack, my bike can stands. For the rear side of the bed, since I have a bed extender, I use it as a mounting point. I extend the extender then I use a velcro strap to attach the front tire with extender. Bike is secured by both tires. Nothing else touches any part of the truck.
  9. Mar 15, 2023 at 2:09 PM
    Voda48
    Voda48 New Member
    Wisconsin
    2016 Platinum
