Bike Carry with CrewMax 5.5' & Tonneau
Discussion in '3rd Gen Tundras (2022+)' started by nrm91, Aug 29, 2022.
  1. Aug 29, 2022 at 7:20 PM
    nrm91
    nrm91 [OP] New Member
    Boise, ID
    2022 Platinum CrewMax Magnetic Grey
    35/11.5/20 Toyo AT III's
    Have a 5.5' CM with the Bakflip MX4 tonneau on it. I was wondering if anyone has some good suggestions for c-channel bike holders? I would be fine with keeping the tailgate down + buying the bed extension. I found a couple on Amazon, but they aren't compatible with the tonneau since it required relocating the rails down a bit. If I can't find anything, I have a tailgate pad I could use, but would prefer to not need it since I hate taking it off/on all the time
    SirSwish32 likes this.
  2. Aug 30, 2022 at 8:37 AM
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
  3. Aug 30, 2022 at 8:39 AM
    nrm91
    Boise, ID
    I actually bought that and tried it. It won't work, the bracket won't reach down to the channel if it's been relocated like it with the BakFlip MX4.
  4. Aug 30, 2022 at 9:18 AM
    Maharisc
    Maharisc w/Patty
    Karl
    Well then, the only other one I am considering is: https://pipelineracks.com/collections/truck-rail-racks
  5. Aug 30, 2022 at 10:56 PM
    Odithtfg747
    Odithtfg747 New Member
    2022 SR5
    I can’t remember where I saw it but on another thread I remember seeing a bike mounted transverse across the truck bed with a rail-to-fork attachment. Requires taking the front wheel off and having the front of the bike a little in the air to reach the side rail of the truck but seems reasonable?
    Somewhat related, I don’t have my 5.5’ crewmax yet but I’m thinking of taking the plunge to get the bakflip over the cheap gator sfx tonneau purely due the the fact that the bakflip can securely lean against the cab and provide more room for bikes. I feel like even with a tailgate pad route, I’ll need the whole 5’ which I wouldn’t get with the gator, right?
  6. Aug 30, 2022 at 11:33 PM
    TundyMcTunra
    TundyMcTunra Irrational people are not often convinced by facts
    Lost in the PNW
    2010 Tundra Limited Crew Max 4x4, 2018 Tacoma Inferno TRDORDCSB, 2019 Rav4 Lunar Rock, 1991 4Runner Crawler. Ivan Stewart Edition
    On my short bed Tacoma I fold mine forward twice and with the tailgate down there's plenty of room for the bike to stand up. Or you could always get a tailgate protection cover and turn the bike around putting the front wheel and forks over the tailgate.20220629_084559.jpg 20220629_084620.jpg
  7. Nov 5, 2022 at 9:05 AM
    Odithtfg747
    2022 SR5
  8. Nov 6, 2022 at 4:34 PM
    BobPro
    BobPro New Member
    2023 Sonic Red Limited
    Had this on my Gen 2 - worked really well, picked it up on AMZ for $49 a few years back. Just pulled it off my Gen 2 today, haven't tried to install it on the Gen 3 yet but it looks like it will be just fine.
    https://rockymounts.com/products/loball-track.html
  9. Nov 6, 2022 at 5:56 PM
    alex17117
    alex17117 New Member
    Alex
    2024 limited, Lunar Rock
    I use this on my 3rd gen. Works great!
    Welderdude80 likes this.
  10. Nov 6, 2022 at 10:03 PM
    Odithtfg747
    2022 SR5
    This is great, thanks. Out of stock most places but I’ll find one
  11. Nov 6, 2022 at 10:27 PM
    SC4333
    SC4333 New Member
    Grant
    2022 Tundra Limited TRD OR 4x4
    I'm using the rockymounts to haul my two mountain bikes and have had good luck so far. They installed into the factory tracks without issue. Great product. They can be found on Amazon or ordered direct, FWIW.
  12. Jun 15, 2023 at 1:43 PM
    Welderdude80
    Welderdude80 New Member
    JP
    Alberta
    2026 Tundra limited TRD
    working on it
    Hey ! Do you have any pics of it with bikes in the box ? I’m looking at alternative for when I tow travel trailer and bring bikes with me. I have a Thule XT2 rack but not Rv rated
  13. Jun 15, 2023 at 7:01 PM
    SC4333
    SC4333 New Member
    Grant
    Not the greatest picture, but I have two bikes on the rocky mounts and my daughters bike back there as well. 6.5' bed. The mounts work great. I have since taken them off because I installed a Retrax bed cover and purchased some rails and a bike mount. That wasn't a cheap date, but I needed the bed cover.
    PBNB likes this.
  14. Jun 15, 2023 at 7:15 PM
    Welderdude80
    JP
    Alberta
    working on it
    It looks good
  15. Jun 16, 2023 at 2:01 PM
    Dfrink
    Dfrink New Member
    SR5 CM 4wd
    I run this setup now. I'm looking to put a cover on my truck. Probably the Bak rollup hard cover. I'm trying to figure out a way to have the fork mount bolted to the front of the bed so they can site above the cover. Then you just roll the cover up and the fork sits over the top of it. Still trying to figure out a mounting option...
  16. Jun 17, 2023 at 10:06 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I like this approach as well. My challenge is that taking the front wheels off the bikes is a challenge with the bolts and the disc brakes. The road bikes don't mind but the gravel bikes are a bit more work. I have the upright bike carriers so I decided that I would just mount it to the cover and remove the bike carrier when I need to lift the covers. I have the kayak racks already installed so the additional set of cross bars would be mounted closer together and only a few inches off the top of the cover. This way I can take the kayaks and then bikes on trips
    This is what I did with the Ridgeline in the past. This is only a 5' bed so bikes fit pretty tight. The DB cover lets me bolt things to it with great holding capacity.
    SC4333 likes this.
  17. Jun 17, 2023 at 10:50 AM
    Tundra McTundraFace
    Tundra McTundraFace Full-time Airstreamer
    2023 Black on black Platinum
    If you haven’t found a solution yet, you could check out RCI metalworks. We have a BakFlip, an RCI rack with bike mounts on the rack sides. You can even buy piece that will mount a tire between the bike frame and rack. Pretty slick set up.
  18. Jun 17, 2023 at 10:55 AM
    KingsAustin
    KingsAustin Grey Goose II
    Morgan County, AL
    2021 Limited Night Shade
    BakFlip MX4, Gator All Weather mats, Console Safe, Ceramic Tint, Roadmaster Active Suspension, Interior/exterior LED conversion, Wireless console charger, AJT designs.
    I like a rack that would fit over my MX4, but I haven't been able to find a suitable one. I am eyeing the rack that fits over the propane tanks but I am worried about loading/unloading them. So, I may end up going with a rear trailer hitch. Still up for debate.
  19. Jun 17, 2023 at 10:29 PM
    Bourbonator
    Bourbonator New Member
    North ID
    '23 LE CM 6.5
    I guess I'm the only one who just throws his bike in the back with the tonneau down and shuts the tailgate.
    earlwright239 and Winning8 like this.
  20. Jun 18, 2023 at 7:15 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I used to put the bikes in the back. The current bikes are too sensitive and will get damaged if they are stacked in the bed.
    Once I stacked 4 bikes on the top of our little tent trailer. I found some holes in the top of the tent trailer from pedals rubbing on the fibreglass.
    The current bikes are carbon fiber so they need a bit more care to move them around.
  21. Jun 18, 2023 at 9:40 AM
    99ways2die
    99ways2die New Member
    NJ
    2022 Tundra Platinum
    This is how I've done it since 2017.
    Thule Xsporter rack (trimmed support legs, mouted to S-type bracket, which then goes under the tonneau frame, and mounts to the Tundra's rails inside the bed) with 4x Thule bike racks.
    Had a soft roll up cover on the old truck. Worked great.
    Transplanted it to the 2022, and since it came with the hard cover, made it work the same way (notched the cover's frame rails to mount the rack the same way as before). Obviously I can't open the hard cover much, but if need be - 2 bolts per support and the whole bike rack comes right off.
    I also have a 2nd set of crossbars, which have ski racks mounted on them, so just before winter I simply remove the bike rack, and mount the ski rack.
    earlwright239 and larryhlc like this.
  22. Jun 18, 2023 at 3:29 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    We do have some pretty amazing places to hang out!
  23. May 26, 2025 at 1:56 PM
    larryhlc
    larryhlc New Member
    2025 Tundra Limited
    Very nice setup, was wondering where you found the brackets you are using?
  24. May 29, 2025 at 10:40 AM
    Dfrink
    Dfrink New Member
    SR5 CM 4wd
    Ended up going this route. I'm quite happy with this setup.
    larryhlc likes this.
  25. May 29, 2025 at 7:26 PM
    larryhlc
    larryhlc New Member
    2025 Tundra Limited
    I’m using this setup with the Peragon accordion style cover. The accordion cover can be removed just leaving the rails in about 30 seconds if desired.
    Dfrink likes this.
