Biggest tires with Readylift kit?
Discussion in 'Wheels & Tires' started by FALCONDRIVER, Jan 21, 2015.
  1. Jan 21, 2015 at 7:32 PM
    FALCONDRIVER
    FALCONDRIVER [OP] New Member
    Colin
    2015 Tundra Limited Crewmax TRD
    Many to come..
    I need advice from the pros! I just installed a readylift leveling kit to my '15 Limited. What are the biggest tires, preferably BFG AT's that I can put on without causing issues? Much thanks!
  2. Jan 21, 2015 at 7:50 PM
    chphilo
    chphilo Tundra addict
    Western PA
    What kind of leveling kit? 3/1? 2/0? 3/2? Are you using the stock wheels?
  3. Jan 22, 2015 at 4:06 PM
    FALCONDRIVER
    Colin
    Many to come..
    2/0. Stock wheels.
  4. Jan 23, 2015 at 1:11 PM
    chphilo
    Western PA
    Personally, I would probably go with GoodYear DuraTrac 295/65/18. I've seen some pictures with 2 inch in the front and these tires look perfect. I like BFG AT KO2, but they don't have too many sizes available. If you really want to go with KO2, you could go with 285/65/18 (which is about 1/2 inch shorter than DuraTrac but should still look good.
