Bigger tires and odometer?
Discussion in 'Wheels & Tires' started by yoneytan, Jun 9, 2018.
  1. Jun 9, 2018 at 10:55 PM
    yoneytan
    yoneytan [OP] New Member
    Asi
    14 CM
    I know the speedo needs to be calibrated when going with bigger tires but my question is, does the odometer record more miles than i'm actually driving since going 295/70/18?
  2. Jun 9, 2018 at 11:41 PM
    ChrisTRDPro
    ChrisTRDPro New Member
    MT
    2017 Tundra TRD Pro CM
    If you go bigger tires, that means you're going further per revolution, which means the speedo shows slower than you're actually going, and recording less miles. If you go with smaller tires, then it will be the opposite.
    RitcheyRch, Prostar 190 and Y0TA PR0 like this.
  3. Jun 10, 2018 at 12:06 AM
    yoneytan
    Asi
    14 CM
    Makes sense. Thanks!
