Bigger cup holder
Discussion in 'General Tundra Discussion' started by Mroe66, Jun 1, 2018.
  1. Jun 1, 2018 at 11:36 AM
    Mroe66
    Mroe66 [OP] New Member
    i have a 2018 Tundra and wondering if a larger base cup holder is available. Can’t fit my favorite cup in the factory one
  2. Jun 1, 2018 at 11:44 AM
    Borgs
    Borgs New Member
    PA
    They sell a million types on Amazon. I have one that extends to fit a 32 ounce jug.
    toyofan87 likes this.
  3. Jun 1, 2018 at 11:50 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
  4. Jun 1, 2018 at 12:04 PM
    Mroe66
    Links to how you searched on Amazon, as I don’t see any that will extend higher and enlarge, thanks for the info
  5. Jun 1, 2018 at 12:09 PM
    Mroe66
    Thanks loads just ordered a couple
    15whtrd likes this.
  6. Jun 1, 2018 at 12:11 PM
    15whtrd
    15whtrd Mr. Blonde
    Click the link above that @Danimal86 posted
  7. Jun 1, 2018 at 12:29 PM
    Borgs
    Borgs New Member
    PA
  8. Jun 1, 2018 at 12:32 PM
    Danimal86
    Daniel
    Sacramento, CA
    Fyi, when you open it up, you might think that it came with a can koozie, its not. Use it over the rings that sit in the cup holder to give it a tight fit.
  9. Sep 15, 2019 at 2:53 PM
    Secondtime
    Secondtime New Member
    Dave
    SE Pennsylvania
    ‘19 1794
    Diamondback cover
  10. Sep 15, 2019 at 4:27 PM
    Rubberdown
    Rtic tumblers fit perfect!
    Cobshop likes this.
  11. Sep 16, 2019 at 2:29 PM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    2019 White Tundra Limited
    In work
  12. Sep 18, 2019 at 6:00 AM
    Cobshop
    Cobshop New Member
    Rtic bottles and coffee cup no longer fit. Not sure I want to raise them up that high with an extension. I’m willing to cut the whole center cup holder section out and start fresh.
  13. Sep 18, 2019 at 6:04 AM
    Rubberdown
    What do you mean they don’t fit!’vbvvcfuhdnmdj
    I was about to order a few more online. Did they change?!?!? Those wankers.
  14. Sep 18, 2019 at 6:09 AM
    chphilo
    chphilo Tundra addict
    Western PA
    I had a cup that I liked with fat bottom. I had to hold the cup while driving. Rather than modding the cup holder, I got a new cup (holds 32 oz, I think) with narrower bottom. I guess I am lazy (or I wasn't as attached to the original cup), haha.
    TundraDude18 likes this.
  15. Sep 18, 2019 at 6:37 AM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    Check out the holder I linked there are no adapters
  16. Sep 18, 2019 at 7:57 AM
    Cobshop
    Cobshop New Member
    In the stock cup holders. The additional inserts will have to raise the cup or bottle up enough where I’d expect it to be too heavy
  17. Dec 9, 2019 at 7:40 PM
    Trk5100
    Trk5100 New Member
    Tate
    2016 Super White 4x4 SR5 CrewMax Tundra
    Upgraded from 2015 Tacoma TRD Pro in January 2019
    Just my two cents - but the BottlePro linked above is garbage. Nowhere near secure with a Nalgene bottle sitting inside it. Threw it out after a month.
  18. Dec 9, 2019 at 8:00 PM
    realtorblake
    realtorblake Tundra Thunda
    Redneckistan... aka Cypress, TX
    2019 Crewmax Platinum 5" Zone lift Fox 2.5 /OME suspension 12.5x35x18 ProComp's
    I bought 3 of these. They are awesome for Tundra cup holders. The 3rd one is for the wifes 4Runner.
    AggiePhil and Tchase like this.
  19. Dec 9, 2019 at 8:11 PM
    TundraDude18
    TundraDude18 Deus vult
    'Merica
    '21 Limited CM
    Silver Bullet Express
    Those look cool. I'm up for it, except quite a few of the reviews say they broke. How long have you had them? One person said they're manufacturing them with different material now [stronger], but the amount of 'broke through normal, light usage' complaints is fairly numerous.
  20. Dec 9, 2019 at 8:54 PM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    I’ve been using two off the Amazon link I posted for about 2 years now no issues they are awesome. I’m sure if you torque them too hard they will bust....
    TundraDude18[QUOTED] likes this.
  21. Dec 10, 2019 at 4:06 AM
    r8rs4lf
    r8rs4lf New Member
    Al
    Tree Juan Hoe
    2015 MGM SR5
    I just purchased one of these as a trial run. I wanted something to hold a standard cup from a coffee shop without tipping. This works!
    I'll be purchasing another one for the passenger.
  22. Dec 10, 2019 at 11:00 AM
    realtorblake
    Only had them for a week and they seem very sturdy. I can see somebody breaking one though by over-tightning them in a cupholder. I have mine turned tight enought that they won't move or pull out. Wouldn't try to push my luck by testing them tighter than that. Really like them for hooding my sunglasses also. The tundra holder is worthless.
  23. Dec 10, 2019 at 11:17 AM
    TundraDude18
    'Merica
    '21 Limited CM
    I just bought a new Yeti cup and 30 oz Tumbler, so I am going to order this.:thumbsup:
    Yeah, I hadn't thought about people trying to over-tighten them [of course, people would do that:facepalm:].
    realtorblake[QUOTED] likes this.
  24. Dec 10, 2019 at 11:38 AM
    r8rs4lf
    r8rs4lf New Member
    Al
    Tree Juan Hoe
    2015 MGM SR5
    Mine is as tight as it will get and I still can pull it out of the Tundra cup holder with minor resistance. It's pretty much at it's limit when installed so I cannot see how it can be overtightened. :notsure:
  25. Dec 10, 2019 at 11:51 AM
    TundraDude18
    'Merica
    '21 Limited CM
    So ... you're a Raiders fan ............................................................................................................................. that's unfortunate .......................................................................... we might have been friends.
    :duel:
  26. Dec 10, 2019 at 12:43 PM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    There is a sweet spot for the expanding prongs make sure you line them up as well as possible and when tightening don't let them move. I would assume all of our cup holders are the same diameter but maybe there is a difference in the cup holder brands I'm using the swigzy. You could also cut some double back to the prongs to give you a litter more thickness...
  27. Jul 16, 2021 at 1:27 PM
    CamV.
    CamV. New Member
    CamV.
    2018 Tundra SR5
    Black decals, all weather mats
    Thanks for the suggestions! My wife has a '14 highlander limited and her cup holders fit my 32oz Nalgene perfectly - idk why they didn't give the Tundra the same bigger holders. I was hoping there would be a mod available to remove ours and replace with the bigger ones. With the trim it's clear there's enough room to fit them
  28. Jul 16, 2021 at 1:28 PM
    andnyleswillriot
    andnyleswillriot Not Remote Working
    Breckenridge, CO
    2016 DC w/ Black Topo Topper
    Toytec 3" w/2.5 Coilovers. SPC UCA's. Method Roost Bronze Wheels. 35" BFG KO2's. SPC Upper Control Arms. 2019+ TRD Pro Grill. LED headlight bulbs. 2020 OEM LED Fog lights. Tech12volts Remote Start. MobArmor Magnetic Phone Mount. Topo Topper.
    If you need another suggestion, look on Etsy for 3D printed cupholders made to exactly fit your OEM cup holder. Those ones with adjustable wings n such just break over time
