Big 3/4 wire upgrade
Discussion in '2.5 Gen Tundras (2014-2021)' started by joeguam, Jan 31, 2017.
  1. Jan 22, 2022 at 3:18 AM
    #61
    Ohannon7
    Ohannon7 New Member
    Central Fl
    2013 5.7 4WD CM Bench-Seat Silver
    6” Pro Comp 37’s Custom audio and interior Off road capability is current focus
    @joeguam
    I used this thread to do my big 3/4 upgrade and very happy so I wanted to say Thank You Joe!!!
    619Tundra and joeguam[OP] like this.
  2. Apr 28, 2022 at 10:06 PM
    #62
    tbone75
    tbone75 New Member
    2007 White Tundra TRD
    So, I'm thinking I may attempt this and curious as to how long this process takes on average? I seen another poster asked but never got answered. I'm going back and forth on if I should attempt this or not and total time would help me get an idea. I already ordered my 1/0 and just itching to use it.
    I'm thinking of going with an Odyssey Extreme 31A (31-PC2150T) 1150cca 100ah. Only have the stock alt now but I'm sure that'll change.
    I was thinking I could upgrade to 2/0 for only 15.00 more, now would be the time, thoughts?
  3. May 3, 2022 at 6:26 AM
    #63
    joeguam
    joeguam [OP] New Member
    JOE
    2015 Toyota Tundra SR5
    Pro Comp 6 Inch Stage II Lift Kit with Icon 2.5 coil overs and piggyback rear shocks, SPC Upper Control Arms, Atlas 6” Leaf Springs, Coach Builder Steering kit, Coach Builder +3 Shackles, BDS Recoil Traction Bars, Amp Research steps, Fuel Nutz two piece 20x12-44 offset wrapped with 38” Toyo MT tires, LineX Bed Liner, Viper 5706V Alarm and Remote Start, Pioneer 4200, JLAudio Amps, JL Audio Subs. Nitro Gear 5.29 and Auburn LSD
    I believe it took me approximately 4-6 hours based on the fact that I had to figure many logistics that I have provided in PDF and or description to ease and minimize guess work. IE wire length from wire loom to next point, how to remove the clips, size of socket, best approach to reach confined spaces etc. Imagine not knowing the exact size of socket or extension length (having to get up and retrieve tools, 1st it is tiring for your muscles to include joints). In addition, what was my best approach to access the bolt and/or part. So as far as the time, well that will depend on your commitment and skill level.
    if you use anything above 1/0 AWG, I doubt it will fit in the wire loom with all the original wires that came out of it. Good luck and I hope it turns out well for you
    619Tundra likes this.
  4. May 3, 2022 at 7:23 AM
    #64
    tbone75
    tbone75 New Member
    @joeguam Thanks for the update! So, I pulled the trigger and ordered a 300amp alternator to do at the same time. The only thing is, I originally ordered 1/0 AWG and sent it back, then ordered 2/0 AWG in its place. However, before that package even arrived, the company from which I'm getting the alternator said they recommend 4/0 AWG wire for this alternator for full performance. So, I canceled the order of the 2/0 AWG that hasn't even arrived yet (Amazon) and ordered 4/0 AWG in its place. I'm going to have to zip strip the wire next to it, figuring it's not going in the loom. Regardless, I have my concerns about the 4/0 AWG wire in that its sheer size is freakin HUGH, and really question if I really need that size. However, after all this sending back and forth I think I'm going to just stick with the 4/0 and hope like hell the alternator company didn't steer me wrong. I don't think I've ever heard of anyone doing the big 3/4 Upgrade with 4/0 AWG. Oh well, here we go...
  5. Feb 5, 2023 at 3:08 AM
    #65
    FrozenTundra83
    FrozenTundra83 New Member
    @joeguam I might have missed it in the reading, but you remove the tire and go through the wheel well? Or did you just go from under the truck and hood?
  6. Feb 5, 2023 at 3:56 AM
    #66
    joeguam
    JOE
    I went through the wheel well and splash guard to get to the alternator wiring. There are several clips holding the wire harness along the way leading to the battery and fuse box so depending (top/ bottom or side) approach, whichever way was easier is what I went with. I did not have to remove the tire. Hope that helps
  7. Feb 6, 2023 at 6:10 AM
    #67
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    Aaah yeah 4/0 wire? really why? thats odd cause if you see the chart below you can be running 2/0 gauge for 300 amps for up to 19-22 ft. Unless you are upgrading the 300A Alternator for Audio upgrading to 4/0 although nice would be a pita to maneuver in those tight spaces. Especially if you are upgrading to 300A for no reason other than the big 3/4/5 upgrade.
    BTW I would go with what the manufacture of the Alternator recommends but still it might be overkill.
    Also if you are doing that you may have to upgrade the Alternator fuse on the thing as well right. Did they mention upgrading the fuse to at least 300*1.25=375Amp fuse on the 4/0 cable? Else you'll be blowing fuses all the time and getting stuck if you do not have replacement fuses with you in the truck.
    Lastly, here's a link to a wiresize calculator so you can take the guess work out of what AWG cable you need for the given distance you want to run the cable for on a given device max load (in your case your alternator of 300 amps)
    AWG Wiresize to Amp calculator - https://www.wirebarn.com/Wire-Calculator-_ep_41.html
    Also link to fuse calculator - https://mgispeedware.com/guides-documentation/fuse-breaker-size-calculator/
  8. Feb 6, 2023 at 7:21 AM
    #68
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    There's no inline fuse from the alternator to the battery. There is a fuse from the battery to the main fuse box but that doesn't need to be changed as the truck's system load does not change. I do agree that 4/0 is way past overkill though.
  9. Feb 6, 2023 at 9:07 AM
    #69
    citrusmaster
    citrusmaster New Member
    Tielar
    2015 Tundra RCLB
    Very nice, this upgrade is next on my list, I would love to install a sound system in my truck.
  10. Sep 20, 2024 at 8:00 AM
    #70
    Shmuckatelly
    Shmuckatelly New Member
    2015 Tundra Limited
    Big 3 + Aux Battery, Aux Lights, Air Tank, B81s, CS055R Springs, Air Bags
    This job was no small challenge. I don't think I would do it 'my way' a second time. Toyota gives you only 'just enough' room. Thank you @joeguam and other thread participants.
    Biggest lessons learned: The wiring harness clips were designed for maximum frustration. Zip ties are working just fine. Upgrading the wire (my way @ 1/0 AWG) left not enough room to re-use the OEM clips, the OEM wiring loom, or follow the exact OEM wiring path. I almost ran out of cable length for the connector that attaches to the fuse box as a result. Also needed to butt splice the starter cable (regret not replacing that too, but the heat shielding made it a bridge too far).
    I made a little movie to help folks get started, but it won't upload. Sorry.
    J's 4x4 and 2mchfun like this.
  11. Aug 20, 2025 at 8:26 PM
    #71
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    Sorry to revive this thread. But basically what I’m getting out of this, is that he removed the harness, removed the old alternator + to the fuse box. Installed a new larger alternator + from the alternator directly to the positive battery cable, then from the positive battery cable to the fuse box?
