Big 3/4 wire upgrade
Discussion in '2.5 Gen Tundras (2014-2021)' started by joeguam, Jan 31, 2017.
  1. Apr 24, 2019 at 1:42 PM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    so, i can take the original wire and connect direct to battery?
  2. Apr 24, 2019 at 8:11 PM
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    couple more questions. just a bit confused on your images and i want to make sure i connect everything correctly tomorrow.
    in the first picture, at the small red dot, you have removed the cable. in the second picture, it looks like you've made a new cable to go to the battery, yes? is this the same gauge wire as your new cable to the alternator? the stock connector at that location is pretty small.
    also, just to verify, you are now going alternator -> anl fuse -> battery. is the anl fuse necessary? i have one on the route to my amp but do i need one between the alternator and the battery?
    i think i have everything dialed and still have plenty of red cable to make a short from the voltage regulator to the battery.
  3. Apr 24, 2019 at 10:00 PM
    LEKS
    LEKS Truck name “Sancha”
    Makaha
    2013 Rockwarrior Supercharged
    I did an upgraded wire there. Removed the factory one and replaced with 2/0
    smslavin[QUOTED] likes this.
  4. Apr 24, 2019 at 10:04 PM
    LEKS
    Makaha
    I know guys that go straight from alternator to battery, no fuse. I did a circuit breaker in mine because I also did an upgraded alternator (270a). It’s just another layer of protection. 9D1C9AF7-2D87-4DCF-844F-EEF49DDD9EF6.jpg01E0C08D-1DBD-413F-B4F8-33D0BCB3E0C0.jpg
    tundramike23, Matala, GeneVS and 7 others like this.
  5. Apr 25, 2019 at 5:34 AM
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    thanks for the input. an alternator is on the list for me and i have plenty of wire left over. i’ll drop something in there.
    nice job on your wiring. :cheers:
    GeneVS and LEKS[QUOTED] like this.
  6. Apr 25, 2019 at 2:49 PM
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    one more question for you as i'm still trying to figure out how to make everything fit. the stock positive cable that has the L terminal connector on it, i believe it comes from the starter, where did you put that? that's the one that is really giving me the most issues fitment wise. i think getting a set of those flat battery terminals like yours will help as well.
  7. Apr 25, 2019 at 3:22 PM
    LEKS
    Makaha
    I extended the factory starter wire so that I had room to wire it nicely. One of the two black wires you see on my positive terminal is it, the other black wire goes to the bottom of the fuse box. I believe that’s connected to the fusible link.
  8. Apr 25, 2019 at 3:50 PM
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    what's the best way to do that?
  9. Apr 25, 2019 at 4:53 PM
    LEKS
    Makaha
    I went to a local electric supply store And picked up some butt splice connectors. I forget what gauge it was, I took a piece of the wire with me.
  10. Apr 25, 2019 at 4:54 PM
    LEKS
    Makaha
  11. Apr 25, 2019 at 6:04 PM
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    LEKS[QUOTED] likes this.
  12. Apr 25, 2019 at 8:19 PM
    LEKS
    Makaha
    Haha, All good man. Sadly I’m in California now . My family is still in Hawaii so we go back pretty often to visit.
  13. Jul 10, 2019 at 9:17 AM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Damn... That is just really clean.
    tundramike23 likes this.
  14. Jul 10, 2019 at 10:09 AM
    birdman076
    birdman076 Bird, bird, bird...bird is the word
    Chuck
    Montana
    2015 Brown Tundra Crew Max Limited
    Airbox with K&N Filter, 2" lift on 33's, Alpine iLX-F309 head unit, Pull out bed tool boxes, brown with black trim, rims, etc, black leather interior, matching topper. Muffler delete (too loud..) 62k miles!!!
    Upgrading grounds is one of the first mods I do to any vehicle. Learned it the hard way with the older pontiacs and anything dodge lol. Didn’t know of anyone doing a kit so that’s pretty cool. I usually source marine grade wire though through west marine or online as it is typically tinned and decent copper is used.
  15. Mar 28, 2020 at 10:37 PM
    TruckyTruck
    Gary
    So with the original system, the voltage regulator controls how many volts get sent to the battery. I've read 13.7-14v depending on engine bay temps.
    What happens when you bypass this and go straight to the battery from the alternator?
    How many volts will be sent then?
    The reason I ask is due to this Northstar battery. You have to keep 14.1 to I think 14.8 volts going to it in order for them to warranty the battery. I bought this little jewel to make sure that happens.
    https://www.hkbelect.com/product/297-mk4-adjustable-alternator-voltage-booster-2013/
    To you guys that have done the big 3, have any of you checked to see how many volts your alternator puts out after bypassing the voltage regulator?
    If not, could I ask one of you to check for me?
    Edit: I may be missing the concept here. So after your power from alt to battery, you then run a smaller wire from the battery to the voltage regulator? Keeping the voltage regulator and fuse in the loop?
    Yep, maybe I better stop reading and go to sleep.
    619Tundra likes this.
  16. Mar 30, 2020 at 9:43 AM
    lonelydriver
    lonelydriver New Member
    wow thats a huge difference thanks for the writeup
  17. Sep 16, 2020 at 8:17 PM
    GeneVS
    GeneVS New Member
    Gene
    2002 Tundra SR5
    Well done Joe and LEKS. :thumbsup:
  18. May 24, 2021 at 6:06 AM
    Kin08tndr
    Kin08tndr New Member
    Nick
    Quick question, does the NEW positive wire fr the alternator have to hook up to the fuse voltage regulator (fusebox)? It cannot go direct to the positive battery post?
  19. May 24, 2021 at 6:20 AM
    #49
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    If you are going through all this trouble for better sound, why use dielectric grease? You do know that it is non conductive, should of used this instead... you can get it on Amazon. I use it for all my electrical connections. Use a toothpick or q tip...its messy shit
    MG Chemicals - 846-80G Carbon Conductive Grease, 80g Tube
  20. May 24, 2021 at 2:44 PM
    #50
    joeguam
    joeguam [OP] New Member
    JOE
    2015 Toyota Tundra SR5
    Pro Comp 6 Inch Stage II Lift Kit with Icon 2.5 coil overs and piggyback rear shocks, SPC Upper Control Arms, Atlas 6” Leaf Springs, Coach Builder Steering kit, Coach Builder +3 Shackles, BDS Recoil Traction Bars, Amp Research steps, Fuel Nutz two piece 20x12-44 offset wrapped with 38” Toyo MT tires, LineX Bed Liner, Viper 5706V Alarm and Remote Start, Pioneer 4200, JLAudio Amps, JL Audio Subs. Nitro Gear 5.29 and Auburn LSD
    Yes it can go directly to the battery post
  21. May 24, 2021 at 2:48 PM
    #51
    Kin08tndr
    Nick
    I don't know if you read my new post (Big3/4 gone wrong) shit was crazy!...but everything is fine now...
  22. May 24, 2021 at 2:51 PM
    #52
    joeguam
    JOE
    No, I have not read your post. I still have a positive going back into the fuse box
  23. May 24, 2021 at 2:53 PM
    #53
    Kin08tndr
    Nick
    Yes I saw that, did you have to take the whole fusebox,? To put your new cables in?
  24. May 24, 2021 at 3:01 PM
    #54
    joeguam
    JOE
    Dielectrical grease is used for the properties of corrosion prevention and it is what I had. It is/was not used because there was a weak connection.
  25. May 24, 2021 at 3:02 PM
    #55
    joeguam
    JOE
    No, I did not have to take out the fuse box
  26. May 24, 2021 at 4:14 PM
    #56
    Kin08tndr
    Nick
    My battery gauge still moving while bass hits, any idea? New battery? Dual?
  27. May 24, 2021 at 4:19 PM
    #57
    joeguam
    JOE
    My voltage fluctuates as well. Just make the decision to meet your system demands
  28. Jun 5, 2021 at 7:35 PM
    #58
    xj2202009
    xj2202009 New Member
    x
    Lutz, Fl
    2017 tundra sr double cab v8 5.7L black 4x2
    looking to replace factory Radio with a pioneer avix588bhs
    I have the factory 150 amp, I had one agm battery, If I run a wire directly from the alternator to battery is that going to keep the voltage at 14 instead of the 13.3 on average? I just added a second battery. by the way, what alternator is that?
  29. Jun 5, 2021 at 8:16 PM
    #59
    2mchfun
    Capacitor will fix that
  30. Jun 5, 2021 at 8:23 PM
    #60
    xj2202009
    x
    Lutz, Fl
    Dual battery, if you don't have enough power now to juice up your amp, you will have enough net power to keep up with the discharging and charging of the capacitor in time to keep up with the amp's demand. I run three amps with the factory alternator, I added an agm battery last year and could barely keep up with two amps. I just added a second agm battery and everything is working so much better. When I have wife and kids in the car I don't crank up the stereo therefore more charging for the second battery, when Daddy is alone, daddy is going to burn some power, then the cycle starts again. Longer trips longer charging periods.
