Bfg tire pressure
Discussion in 'Wheels & Tires' started by Shanesyota, Feb 10, 2020.
  1. Feb 10, 2020 at 5:15 AM
    Shanesyota
    Shanesyota [OP] Midnight
    Shane
    Ohio
    2019 Black Tundra Platinum
    Weather tech Floor mats Weather tech bedliner and tailgate liner Black TRD shift knob Tonneau cover Match front window tint
    I don't know if there is a thread on her about this..
    What Air pressure to run the Bfg's at they put 38psi at discount tire and it rides rough.
    Let me know if anyone has any what they run. I have a platinum with 20s
  2. Feb 10, 2020 at 5:18 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
    The spec for air pressure should be inside the door (sticker) or in your owners manual.
  3. Feb 10, 2020 at 5:19 AM
    bfluitt
    bfluitt New Member
    2016 TRD PRO Quicksand
    Im running 50 psi in the KO's, sidewall recommends up to 80 cold.
  4. Feb 10, 2020 at 5:19 AM
    BTBAKER
    BTBAKER BE YOU. THE WORLD WILL ADJUST.
    Brad
    Castle Rock
    2017 Tundra Limited
    I Run 40 all around.
  5. Feb 10, 2020 at 6:44 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    275/70-18 Wildpeak AT, LoPro bed cover, TRD rear sway bar, DD 10 inch exhaust, and various other goodies
    Tell me the load index and pressure of the stock tires. That can be located on the door jam. Then tell me what your new tire are, and the size.
    Once you have the load index for the new tire, we can check and see what the correct pressure is. There is a chart out there.......changing from a SL tire to and LT tire requires different air pressure, you cant just use what the door jam lists. LT tires need higher pressure to carry the equal load of a SL tire.
    Tileguy and D4x4TRD like this.
  6. Feb 10, 2020 at 7:11 AM
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    Not for BFG KO2s unless they came as OEMs. My did and supplemental sticker reads 46 which is about right. I run closer to 50. If don't the light comes on on real cold mornings.
  7. Feb 10, 2020 at 7:14 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    My BFG KO2 tires are an E, rated at 3195lb at 65psi, so x4 12780lbs capacity.
    Truck weights 6200lbs.
    So 6200/12780 = 48.5%
    65psi / 48.5% places me at 32psi cold, so that's where I started and that's where I see the best contact patch for DD.
    In your case as well OP, the fact you have 20s doesn't help much
    Flyinryank, T-Rex266 and 15whtrd like this.
  8. Feb 10, 2020 at 8:27 AM
    Shanesyota
    Shane
    Ohio
    I lowered the pressure this morning to 32 in front and 35 in the back.. the sticker on the inside door says 30front/33rear ride is alot better but seems low still. To me 30/33 seems low for the BFGs..
  9. Feb 10, 2020 at 8:32 AM
    15whtrd
    15whtrd Mr. Blonde
    I’ve been running 38 to 40 PSI in the front and 32 to 35 PSI in the rear. If I load up in the back I give them more pressure. I like having good steering input, which is why I like the fronts more firm than the rear. It also gives me a similar contact patch since the truck is nose heavy.
    Mnorris1206 and 14burrito like this.
  10. Feb 10, 2020 at 8:41 AM
    frichco228
    Yes that would be low for LT BFG tire on your Tundra. You moved from the stock SL tires to an LT tire. LT tires need higher air pressure to carry the same load as the stock tires.
    1-Check your door sticker, what is the load index listed there?
    2- what is size of the new BFG tires?
  11. Feb 10, 2020 at 9:07 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    Why would it seem low?
    If you do the load to pressure calculation, it'll give you a baseline.
    15whtrd likes this.
  12. Feb 10, 2020 at 10:06 AM
    Doylfish
    Doylfish New Member
    2016 Tundra 1794 Crewmax
    My BFG KO2 AT didn’t come stock on my 1794, so my door jam still reads for those terrible Bridgestone Duelers, but they were stock takeoffs from a TSS OEM package and that doorjam read 46psi all four corners. That being said I’ve had very good wear results over 20k miles still have 11-12mm left running 48 rear / 50 front
  13. Feb 10, 2020 at 10:31 AM
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    2017 SR5 CrewMax
    I got mine at 40psi all the way around. I've been getting good tire wear and have no issues with stability. The rough ride...well you're in a full-size pickup truck on 20s, with E rated 10 ply tires. No changing that just get used to it ...or buy 18s with P metric tires.
  14. Feb 10, 2020 at 1:02 PM
    Shanesyota
    Shane
    Ohio
    The Bfgs are load range D1
    load index of 112s
    Tire size is 275/55-r20
    Load range SL
    Load index is 111h
  15. Feb 10, 2020 at 2:00 PM
    frichco228
    Ok... I got the chart I am using off a link from this site. I found it a few days ago, do not remember the name of the thread. It maps load index for SL tires, XL tires, D load, C, E, D2, C2, E2, etc.
    Based on stock tire pressure of the SL tires at 30 front and 33 rear and the load index of 111- they supported 2063 front and 2224 rear.
    Checking the chart for D load tires, load index of 112, to support that same weight pressure would be 51-52 ish front, 58 ish rear. I am guessing your D load tires have a max pressure of 65?
    So, that does seems high to me but that is what the load index chart is showing. I will see if i can find the original thread, it was a good read.
    My main point in all this- which I learned from under-inflating tires when moving up to different load classifications....is that when you move from a standard load tire to anything "higher" like D or E range tires....they require more air pressure to handle the same amount of weight. I'm sure there are probably other load index calculators out there on the web as well.
    Try it and see....does the truck track straight and handle well? Or is it too hard and wanders at speed? Try different pressure (but will need higher than your 30/33 psi stock) and see what feels good. Then do a chalk test and see if you are good or need to add or air down a little.
  16. Feb 10, 2020 at 2:05 PM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    I have bfg ko2s in 305/65/R18 and run them all at 35 psi cold
    14burrito likes this.
  17. Feb 10, 2020 at 2:05 PM
    Shanesyota
    Shane
    Ohio
    I'm thinking about raising it to 35 or 36 all around see what that does.. thanks
  18. Feb 10, 2020 at 2:15 PM
    frichco228
  19. Feb 10, 2020 at 2:15 PM
    realtorblake
    realtorblake Tundra Thunda
    Redneckistan... aka Cypress, TX
    2019 Crewmax Platinum 5" Zone lift Fox 2.5 /OME suspension 12.5x35x18 ProComp's
    I run 33-35psi in E rated 35×12.5×18's. I'll air them up if I have a decent sized load, but after load is removed, the ride reminds me to air them back down. This is one of the reasons that I got rid of the 20" rims.
  20. Jun 17, 2021 at 9:06 AM
    amajack
    amajack New Member
    I’m 35 all around and I’m on stock size 18s ko2 e on a 2020trd. I’m getting some small wear on the outsides of my fronts . Thinking of going up to 40…
  21. Jun 17, 2021 at 9:54 AM
    TheBeast The Beach
    Just installed some 35"s K02 18"S. Running 38 all corners for DD.
    I was running 38 front and 41 rear on my Toyo (camper shell on bed) and wear was even.
    However when going off road I drop the psi below 30
