BFG KO2 285/60r20 or 275/60r20 with Bilstein 6112/5160
Discussion in 'Wheels & Tires' started by UTAHRTK, Jan 16, 2020.
  1. Jan 16, 2020 at 6:07 AM
    UTAHRTK
    UTAHRTK [OP] New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    I will be needing new tires soon and have been researching.
    I will be keeping current wheels (20 x 9 +40) - primarily due to budget.
    My 2017 TRD crewmax is my daily driver. I live in San Diego and estimate 1 - 2 days/ month offroad in hard packed dirt and loose sand.
    I do not have a camper shell and do not tow regularly or haul heavy loads.
    Though we do not get many local rain days I prefer to have a tire that has decent traction in wet conditions.
    Another factor is that I have Bilstein 6112's (3rd setting/1.9) and 5160's with Coachbulider +2 shackles and 3 CB coilover shims; none of this is installed yet but should be soon. I am on the fence with regard to installing 2 shims driver side/ 1 shim passenger side or just 1 shim driver side (each .25" shim provides approximately .50" of lift). So, I will either end up with the truck somewhat leveled or with approx. 2.75" front and 1.25" rear. I am pondering how these heigths will mesh with 285/60/20 and 275/60/20. Looking for the best balance overall. I am also considering the following tires - Cooper Discoverer AT3 XLT, Falken A/T3W (285/60/20), Yokohama Geolander A/TG015 (275/60/20).
    I would love to go 285/75/17 however, that will not be the case at this time.
    Any wisdom/experience shared is much appreciated.
  2. Jan 16, 2020 at 6:11 AM
    UTAHRTK
    SOCAL
    Totally different topic but I wanted to put a plug in for Keith - Dirty Deeds- BA Mufflers. I had the 8" standard installed when I got the truck (2017) and love it everyday- highly recommended not only for the great sound and performance but the outstanding customer support.
  3. Jan 16, 2020 at 6:17 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Extra width will look a lot better with 9 inch wide wheel imo
  4. Jan 16, 2020 at 6:28 AM
    UTAHRTK
    SOCAL
    Agreed. When I first got the truck I was looking at 295/60/20. I changed my plan ended really wanting Icon Rebounds with 285/75s - now after a reality check it looks like I will be keeping my 20" wheels. They are Asanti Offroad AB807 with Nitto TG G2s (275/55/20) and were on the truck as a dealer upgrade - I was able to negotiate that add-on; basically no charge for the wheel/ tire upgrade as well as the sill protectors and some other crap they were charging an arm & leg for. I was unable to negotiate all weather mats and a bed mat- I bought those...
  5. Jan 16, 2020 at 6:47 AM
    WestexSBK
    WestexSBK New Member
    2019 SuperWhite CM TRD Sport 4x4
    Agreed. 285 ko2 look good. I had them originally
