Better MPGs with Tow/Haul engaged
Discussion in '2.5 Gen Tundras (2014-2021)' started by Stumpjumper, Nov 7, 2017.
  1. Nov 10, 2017 at 4:06 PM
    Ksatter
    Ksatter New Member
    Greenback, TN
    2016 Tundra 4 x 4 5.7 DC LB
    Hope you get great results testing the new cover 71_340. I'll probably be taking my wife shopping as well tomorrow. Just enjoy the experience of being together.....
  2. Nov 10, 2017 at 4:21 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    If I do save a little gas it will be more then offset by taking my wife shopping because I usually end up paying.
    realtorblake and Ksatter like this.
  3. Nov 10, 2017 at 4:48 PM
    Stumpjumper
    Stumpjumper [OP] Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Now test towing the boat without tow haul on. I filled up this morning and reset. 60 mile round trip mostly hwy to work and back with tow haul on. Sitting at 18.1 when I pulled in driveway tonight. I get 10 or close to it with 5000 lb 22' bay boat. These folks getting 15 have a heavy foot or it is all city.
    Ksatter[QUOTED] likes this.
  4. Mar 12, 2018 at 11:36 PM
    mxz83
    mxz83 New Member
    2017 Quicksand
    4.5 BDS with fox Suspension
    I’m actually getting better MPG with it own. I was at 10.5-12.0 and with it on I’ve been 12.9-13.5.
    It’s working hardest at take off by the truck almost fees lighter and once you’re on a steady drive it’s actually working less not driving the rpms up. Unless you’re flooring it..
    I m just curious if it’s doing anything negative to the engine or transmission.
    Any ideas?
  5. Mar 13, 2018 at 6:58 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    i have yet to get anything better than 14mpg. When i changed my battery it went up, but thats just because i changed my battery.....back to 14mpg.
    I'm not even romping on it. What kind of black magic are you guys doing to get 18mpg?
    R.S.5.56 likes this.
  6. Mar 13, 2018 at 8:18 AM
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    In my case I have a 4x2, not 4x4. I have no need for 4wd and 2wd is better on mpg from what I have read. I get a measured (not the display value) 16-17 mpg consistently. Unladen, mostly freeway, easy on the throttle with a few instances of giddy-yup. I calculate mpg whenever I fill up with a calculator, more accurate that way.
  7. Mar 13, 2018 at 5:27 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    According to the Fuelie app I averaged around 17 MPG over the last almost 3K miles. I do not hotrod my truck to get that kind of mileage.
  8. Mar 13, 2018 at 5:50 PM
    Blueline
    Blueline New Member
    Jeb
    Temecula, CA
    2016 Tundra TRD PRO crewmax
    Bakflip MX4
    I’ve got a MX4 on mine. Looks great, works great, but no change in mpg.AEEE47AB-4F6F-4AF2-A5EE-6488D40278A6.jpg
    TXRailRoadBandit73 likes this.
  9. Mar 13, 2018 at 7:38 PM
    Tony v
    Tony v Member
    2017 SR5 CrewMax
    Im getting 15+ combined all day long everyday without TH in my Tundra. Although, I did notice that on my POS 2017 Tacoma, I did get a little better mileage in ETC mode because I wasn’t over compensating as much for the shitty throttle response. The tundra is great!
  10. Mar 14, 2018 at 8:11 PM
    Reload172
    Reload172 New Member
    Charlie
    2015 Tundra SR5 5.7L Barcelona Red
    MPG gains with tonneau cover has to depend on your driving habits. The cover has effectively no drag reduction below 50mph, moderate around 65 and much better around 80. If you drive on high speed interstate highways, you get a better benefit than in a city. Mine shows consistently 1 mpg improvement after adding the cover. I drive mostly 50mph or less with short trips on the interstate where I do 70-75. However, I took a 7-hour trip on the interstate last month, and my dash read over 20mpg, up from about 17.5 normally.
  11. Mar 1, 2020 at 6:15 PM
    Kerktam
    Kerktam Lexus truck wanted
    middle of nowhere, up north
    2023 limited TRD OR, 2024 silverado 5.3
    35 tires, 2 inch level kit
    I'm getting over 14mpg with tow/haul on and only 12 or less with it off. I have lifted truck though with 35's tires
  12. Mar 1, 2020 at 6:46 PM
    Bigbird57
    Bigbird57 New Member
    Yes, the Beast Mode is so much fun. The throttle response is crazy.
  13. Mar 1, 2020 at 6:52 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Tow/haul makes Zero difference at highway speeds.
    All it does is move shift point to higher RPMS to allow engine to gain HP and Torque when you guessed it, Towing/Hauling.
    So as a result of higher RPM shift points, only one thing can happen, lets all chime in together now....
    May have achieved higher MPGs in this "experiement" but it is flawed for the above reason.
  14. Mar 17, 2020 at 10:42 PM
    Tony v
    Tony v Member
    2017 SR5 CrewMax
    I disagree. I tend to keep my foot off of it in tow haul.
  15. Mar 18, 2020 at 12:12 AM
    realtorblake
    realtorblake Tundra Thunda
    Redneckistan... aka Cypress, TX
    2019 Crewmax Platinum 5" Zone lift Fox 2.5 /OME suspension 12.5x35x18 ProComp's
    Hell man... I have to pay my wife an allowance just to keep her out of my bidness.. She gets $2K a month and she has a job... I've been retired for 5 years. Worth every penny though! She wants to argue, all I have to do is pick up a checkbook and shake it...LOL
    Wynnded likes this.
