Better Braking Brakes! Easy!!!
Discussion in '1st Gen Tundras (2000-2006)' started by Professional Hand Model, Oct 18, 2018.
  1. Dec 26, 2018 at 12:04 PM
    #61
    FlightSimGuy
    FlightSimGuy New Member
    2006 Tundra SR5 V8 DC
    ICON 2.5 shocks with King 14" 700lb coils, Camburg UCAs, ICON V2.0 rear shocks.
    Thanks! I'll do this as I want to keep this truck as long as I can so any preventative measures I can take are good. It was used pretty hard by the previous owner
    Thanks! I have no idea about the frame. :confused:
  2. Dec 26, 2018 at 12:09 PM
    #62
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Are you in a high salt area? I would definitely check the VIN to see if your frame is original. It's good info to know since you plan on keeping the truck a long time.
    FlightSimGuy[QUOTED] likes this.
  3. Dec 26, 2018 at 12:31 PM
    #63
    FlightSimGuy
    As far as I know the truck has spent most of it's life in western CO so I don't think a lot of salt except from snow plows and mag chloride.
  4. Dec 26, 2018 at 12:35 PM
    #64
    Professional Hand Model [OP] A.K.A ‘Golden Hands’
    Hand Protectors
    Check your cross-member where the ends tie into the c-frame. Thats where the problem usually begins even in low salt areas. Load the crap out of the frame over lapping with a grease needle as much as possible there. Spray some penetrant in there too.
  5. Dec 26, 2018 at 12:40 PM
    #65
    Hand Protectors
    Yours looks to be where mine is sitting currently post adjustment. Mine originally was bottomed out at the lowest setting of the threads for 16 years. No way to know whats right but your feel by driving. My adjustment location has improved the braking hugely.
  6. Dec 26, 2018 at 1:04 PM
    #66
    FlightSimGuy
    OK, I'll check it.
    Wish I could get my truck to brake like my 06 4Runner. Every time I drive that thing I want to buy it back from my parents.
  7. Dec 30, 2018 at 9:30 AM
    #67
    ladywolf
    ladywolf New Member
    Kristen
    Clarksville TN
    05 S45 4x4 Double cab Jade Green Mica
    2.5" eibach coils/springs
    I need to do this as my front brakes are doing all the work. My ebrake cable is also drooping, not nice and taught like those are.....ah the joys. Blech.
  8. Dec 30, 2018 at 2:28 PM
    #68
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I'm really afraid to look inside my rear drums. Im not positive, but I doubt the previous owner did anything with them. Once I do decide to open them I'm going to replace every part or pay someone to do it.
  9. Dec 31, 2018 at 10:13 AM
    #69
    ladywolf
    ladywolf New Member
    Kristen
    Clarksville TN
    I just pulled the trigger on new pads, rotors, drums, shoes, and upgraded brakelines. So I feel ya.
  10. Dec 31, 2018 at 10:53 PM
    #70
    Reddogone85
    Reddogone85 New Member
    Eric
    2003 Toyota Tundra 4.7 V8
    Stock. Want to do some slight modifications.
    I have a 2003 Tundra sr5 4.7, and they had a recall on the brakes as I'm sure you know, and I had rear drum probs and still have shaking when I'm braking. I'm a poet and didn't know it.
  11. Jan 5, 2019 at 5:57 AM
    #71
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    IF THAT IS YELLING AM I NOW SCREAMING? Hopefully you are only using that braided line at the ends to the front calipers, or the one flexible one in the back. dope Too late
  12. Jan 6, 2019 at 7:21 AM
    #72
    Somemedic
    Somemedic New Member
    Mark
    2000 SR5 AC Cab/ 2010 Dbbl Cab Long Bed
    Yak racks Awning LED dash LED headlights / fog lights Hellwig Helper springs KC HD springs Bed slide out Sony AX100 w/ cam SOS Big Brake front kit Rancho 9000 front / rear
    You took the drums off? Speak to me master Yoda and tell me more of these things
  13. Jan 6, 2019 at 10:35 AM
    #73
    Lost Highway
    Lost Highway New Member
    2003 tundra TRD
    high performance rotors
    Has anyone ever tried, or is it possible to adjust the anti lock braking system on a gen 1 Tundra? I have come to believe the braking bounce I am getting is from the abs system and not from the load proportional valve.
  14. Jan 6, 2019 at 10:41 AM
    #74
    Hand Protectors
    If one wanted to bypass the ABS temporarily to test your theory, then they could disconnect the sensors at the 4 wheels. Or, and easier option is to remove the fuse at the panel temporarily.
    Only for theoretical test purposes and not recommended.
    Never heard of this bed bounce (cue the Office jokes up).
  15. Jan 9, 2019 at 4:54 AM
    #75
    zombie
    paul
    Rhode Island
    2007 Black DC 4x4
    What is this Anti lock brake system you speak of. :goingcrazy:
    Rex Kramer and Darkness like this.
  16. Feb 17, 2019 at 12:16 PM
    #76
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Well, I tried to adjust mine as all of you have, and my adjuster bracket dohicky snapped off. Anyone know the actual term for it? I can't seem to find it after scouring every parts diagram and auto parts site on the internet.
  17. Feb 17, 2019 at 12:20 PM
    #77
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Rear brake propositioning bracket?
  18. Feb 17, 2019 at 12:23 PM
    #78
    lsaami
    lsaami Let ‘er buck
    Minnesota
    tried that and a million variations. turns out it's called a "Load Sensing Spring Shackle" Who knew?
    for my 2000 4.7L 4x4 the part number is
    47936-35050
  19. Feb 17, 2019 at 12:44 PM
    #79
    Hand Protectors
    Isaami. This is for the 2002 but probably works for your 2000.
    lsaami likes this.
  20. Mar 8, 2019 at 9:16 PM
    #80
    Somemedic
    Mark
  21. Mar 9, 2019 at 7:38 AM
    #81
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Should he see a doctor about that? Asking for a friend. o_O
  22. Mar 9, 2019 at 7:57 AM
    #82
    Hand Protectors
    Depends on ones perspective.
  23. Mar 14, 2019 at 2:22 AM
    #83
    zombie
    paul
    Rhode Island
    2007 Black DC 4x4
    And the pop up camper helps who.........Yoda?
  24. Sep 28, 2019 at 10:14 AM
    #84
    merbesfield
    merbesfield New Member
    I would like to do a rear disc conversion but don’t want to lose the parking brake function. No I don’t use it but I don’t like disabling factory stuff. What are the options others have found?
  25. Sep 28, 2019 at 6:34 PM
    #85
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    @Pinay sticky? I forgot about adjusting the rear propositioning valve.
  26. Sep 28, 2019 at 6:55 PM
    #86
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Place thread in 1st gen Tundras Info thread?
  27. Sep 28, 2019 at 7:03 PM
    #87
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I think so. It's a handy tidbit of info, and PHM deserves a sticky.
  28. Oct 5, 2019 at 12:28 PM
    #88
    Hand Protectors
    Thanks, but we’ll keep this info underground. A moderator here, by the name of Jerry, turned me on to this anyways. Its his info.
    Tundra2 likes this.
  29. Aug 2, 2020 at 10:41 AM
    #89
    FLJ23
    FLJ23 New Member
    2004 DC 4x4
    Stock for now
    so you loosen both nuts so the bracket goes higher?
  30. Aug 2, 2020 at 10:55 AM
    #90
    Hand Protectors
    Yeah. Be careful because some members here have broken the assy in one form or another due to not being mechanically inclined. :poking:
    You’ll need two wrenches (10mm?). Hold the bottom nut firm with one wrench and loosen the top nut with the other wrench. Twist the top nut loose about 1/4-1/2” higher on the post depending on your needs and then raise (turn) the bottom nut/bracket up to the higher relocated nut and tighten.
    I raised mine approx 3/4”.
