Better Braking Brakes! Easy!!!
Discussion in '1st Gen Tundras (2000-2006)' started by Professional Hand Model, Oct 18, 2018.
  1. Nov 16, 2018 at 4:14 PM
    FlightSimGuy
    FlightSimGuy New Member
    2006 Tundra SR5 V8 DC
    ICON 2.5 shocks with King 14" 700lb coils, Camburg UCAs, ICON V2.0 rear shocks.
    This is where mine is.
  2. Nov 16, 2018 at 4:16 PM
    Professional Hand Model [OP] A.K.A ‘Golden Hands’
    Hand Protectors
    Yours is higher than mine was (which was bottomed out). Yours being an 06’ might be different than the 02’. Its an easy adjustment and you can always bring it back to the old location if not serving your purpose.
    FlightSimGuy likes this.
  3. Nov 16, 2018 at 4:34 PM
    FlightSimGuy
    So I should take it up, as in closer to the end of the bolt?
  4. Nov 16, 2018 at 5:18 PM
    Hand Protectors
    In my case it (the nuts) were at the complete bottom of the rod. I raised mine higher up the shaft about 3/4” kinda like yours pictured are currently. Yours being a different year might require a different adjustment up. Or, it might be good where it is. Either way, its an easy adjust readjust back if needed.
  5. Nov 16, 2018 at 5:24 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I'll get out and check mine tomorrow. Oil change, VC gaskets, and check the rear breather. And check the carrier bushing play. And the seatbelts "mod".
  6. Nov 16, 2018 at 6:34 PM
    Outbound
    Aaron
    Northern Alberta
    On my '05 the nuts are already near the top. I would only be able to adjust up 1/4" or so.
  7. Nov 17, 2018 at 9:27 AM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    Your rear brake cable is caught on the adjustment rod.
  8. Nov 17, 2018 at 2:31 PM
    FlightSimGuy
    Better? I thought it was supposed to go there.
  9. Nov 17, 2018 at 3:03 PM
    Hand Protectors
    Good eye!
  10. Nov 17, 2018 at 4:15 PM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    Much better! You should pull your right rear drum apart and see how the pads are looking. The brakes could have been partially engaged with that caught up there.
  11. Nov 17, 2018 at 4:22 PM
    Hand Protectors
    Was thinking this too althought it looks like there was/is enough play in that cable to not engage parking brake. My parking brake does not work even when adjusted and fully engaged!
  12. Nov 18, 2018 at 7:48 AM
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    I heard upgrading the brake lines helps too. Wheelers off-road has their stainless steel brake lines 50% off on black Friday. I ordered front and rear.
    Rheywood456 likes this.
  13. Nov 18, 2018 at 7:54 AM
    Casper421
    In the woods
    06 DC
    Promo code?
  14. Nov 18, 2018 at 9:06 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    I just PMed them thursday when I was ready to order and told them all the parts I needed and they took a few bucks off each part and shipping as well as the half off the brake lines. Sent me a PayPal invoice and I paid it. Shipped the same day. Should be here Wednesday. Saved me about 90 bucks total
  15. Nov 18, 2018 at 3:24 PM
    Lost Highway
    Lost Highway New Member
    2003 tundra TRD
    high performance rotors
    If your parking brake isn't engaging, I would bet that the cable came off one of the routing ramps inside one of the drums the last time the brakes were worked on. I know because it happened to me once, the cable slips off easily until the pads are secured.
  16. Nov 20, 2018 at 10:23 AM
    Rheywood456
    Rheywood456 Sup
    Riley
    Kansas City
    First Gen Tundra
    Oh sweet. I should jump on that too!
  17. Nov 20, 2018 at 10:23 AM
    Rheywood456
    Rheywood456 Sup
    Riley
    Kansas City
    First Gen Tundra
    Here is mine extended. Very necessary after installing the Deavers
  18. Nov 20, 2018 at 10:25 AM
    Casper421
    In the woods
    06 DC
  19. Nov 24, 2018 at 12:00 PM
    #49
    Lost Highway
    2003 tundra TRD
    I tried adjusting the rod further out on the threads, boy is that a mistake, when I had to brake from a higher rate of speed the rear end started bouncing hard. I think what was happening was just to much brake bias to the rear, so as the rear wheels were just about to lock, the anti-lock system released some pressure. And until my speed was down to a well reduced speed, the brake bias and anti-lock systems were fighting each other, causing the bounce.
    So now I am trying the other extreme and adjusting the proportional valve down lower on the threads to reduce the rear braking, and we will see how it goes.
    Well I have adjusted the threads to lessen the rear braking and the major bounce I felt at high speed braking is gone, but now there is sometimes a little rear wheel brake chatter when stopping. I also bled the proportional valve to see if that changed things, it didn't.
    I can live with the chatter for now, but in the near future I am going to replace the proportional valve to see if it is just worn out.
  20. Dec 23, 2018 at 4:48 PM
    #50
    MOTORHEAD
    MOTORHEAD New Member
    DAVID
    LOS ANGELES CA
    2002 Toyota Tundra SR5 V-8 4.7L WHITE
    RCD 6" SUSPENSION LIFT,ICON EXTENDED FRONT COILOVERS,3" BODY LIFT,CAMBURG UPPER CONTROL ARMS.REAR DISK BRAKE CONVERSION,BIG BRAKE FRONT CONVERSION, AND MANY MORE
    i have the sos performance rear disk brake conversion. real easy to install. hardest part was getting new brake lines fabricated.
  21. Dec 26, 2018 at 10:11 AM
    #51
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I think mine might be right where it should be.
    Thoughts?
    jpink likes this.
  22. Dec 26, 2018 at 10:15 AM
    #52
    Hand Protectors
    You have asymmetrical nuts.
    Sangre Kid and Darkness like this.
  23. Dec 26, 2018 at 10:25 AM
    #53
    FlightSimGuy
    Do you polish your axle? o_O
    Darkness likes this.
  24. Dec 26, 2018 at 10:55 AM
    #54
    Hand Protectors
    Thats how mine looked after Fluid Film. Made it look brand new. Same with the frame. Better than paint!
    FlightSimGuy[QUOTED] likes this.
  25. Dec 26, 2018 at 11:19 AM
    #55
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Every night! Oh, wait, we're talking about trucks? :anonymous:
  26. Dec 26, 2018 at 11:26 AM
    #56
    FlightSimGuy
    Might have to look into that.
  27. Dec 26, 2018 at 11:30 AM
    #57
    Hand Protectors
    2 cans will do you for the frame/axles. Maybe an hours worth of time. Grab a third can just in case you want to load up the small holes areas via the straw up near the front axle.
  28. Dec 26, 2018 at 11:36 AM
    #58
    FlightSimGuy
    How does it work? Pressure wash everything dry, then spray this stuff on?
  29. Dec 26, 2018 at 11:46 AM
    #59
    Hand Protectors
    Make sure its fairly clean from mud cack. In my case, I sprayed without having to wash anything underneath. The lanolin oils penetrate through and loose dirt film. Only power wash if cacked build up.
  30. Dec 26, 2018 at 11:49 AM
    #60
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Fred is right. I applied Fluid Film after everyone here recommended it. My truck was already pretty clean underneath so I didn't pressure wash but if yours is dirty then I definitely would clean it first. Also, take a wire brush to any rust. This was my first time applying fluid film but people report it must be done every year. I also plan on greasing a few places that have more than surface rust.
    If your truck is like mine, and didn't get the frame replaced, then I would definitely protect it with Fluid Film.
