Better Brakes?
Discussion in '2.5 Gen Tundras (2014-2021)' started by kidrman, Jun 5, 2021.
  1. Jun 6, 2021 at 8:24 PM
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    The one I knew of and saw did not mount to a shock tower, just clamped to itself with a nice big threaded pre-load screw like a gear puller.
    white rocket[QUOTED] likes this.
  2. Jun 7, 2021 at 6:28 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I ordered 4 Stoptech SS lines, what are the missing part numbers?
    950.44023
    950.44524
    Thanks,
  3. Jun 7, 2021 at 7:32 AM
    Nowhereman
    Al
    Monterey Bay area
    Or if your a confident type of guy, get on Amazon and order 30 feet of stainless steel woven tubing and fittings.
    A shit ton cheaper and you can custom run lengths.
    The only thing is piece of mind driving but, if your experienced at doing hydraulics lines as most bikers are, it's a snap.
  4. Jun 7, 2021 at 7:33 AM
    Djone27
    Djone27 New Member
    2017 MGM Crewmax TSS 4x4
    HID Headlights, full LEDs, TRD front and rear sway bars, CB +2s, Eibach Stage 2s, SABM w/ pro intake tube
    All 6 came in one set I linked them earlier in the thread, but here it is again:
    https://www.amazon.com/dp/B07N1JV59K?ref=ppx_pop_mob_ap_share
    Power Stop BH00130 Stainless Steel Brake Hose Kit- Front & Rear
  5. Jun 7, 2021 at 7:38 AM
    e30cabrio
    I missed your post, looks like I need the two on the bottom.
  6. Jun 7, 2021 at 7:55 AM
    e30cabrio
    @Nowhereman, I can and will do alot, I won't make my own brake lines.
    After looking at the schematics I don't see that line that seems to go over the rear Tundra axle on a Sequoia (which does not have the same rear suspension as a Tundra) I'll look at my truck when I get home tonight.
  7. Jun 8, 2021 at 7:48 AM
    e30cabrio
    Climbed under there this morning. 2013 Sequoia lines go from the second rubber hose to the hard line. No third ss line needed.
  8. Jun 8, 2021 at 7:55 AM
    2mchfun
    Better brakes for what? Ship horn, massive tires, stout bumper, and good insurance.
  9. Jun 8, 2021 at 8:48 AM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    True story. There is a ton of “reserve” braking power. I’m actually quite pleased with the brakes on the new tundra.
  10. Jun 8, 2021 at 11:07 AM
    e30cabrio
    How long did your order take to ship? I ordered the 6th and it's "processing"
  11. Jun 8, 2021 at 12:03 PM
    5150bronco
    5150bronco New Member
    Justin
    Bay Area, Ca.
    couple days.
    calipers are back ordered.
  12. Jun 8, 2021 at 1:25 PM
    e30cabrio
    Thanks, I just did rotors & pads.
  13. Jun 8, 2021 at 1:31 PM
    5150bronco
    Justin
    Bay Area, Ca.
    Right on!
    get on the list for the calipers now.
  14. Jun 15, 2021 at 7:51 AM
    Doublecab22
    Doublecab22 New Member
    I went with the Wagner OEX slotted pads all the way around with a good pressurized brake bleed. far better than stock. whenever these wear out ill probably go with EBC pads and rotors at the same time.
  15. Jun 15, 2021 at 1:30 PM
    Kenny1794
    Kenny1794 New Member
  16. Jun 17, 2021 at 12:01 PM
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
