Better brake controller
Discussion in 'Towing & Hauling' started by 94slowbra, Jun 7, 2018.
  1. Jun 7, 2018 at 10:50 AM
    94slowbra
    94slowbra [OP] New Member
    john
    new orleans
    2016 TRD pro
    man does the factory controller suck! ive read a few threads about it not working well but thought maybe they were just exaggerating. hooked up to about 6k for the first time today and set the gain to about 7. upped it all the way to 10 and still doesnt feel like its helping at all.
    so what is everybody using? want something that looks factory and does what it supposed to do. heaviest i tow is 6k so i dont need anything too fancy just something that will work with electric brakes. thanks
  2. Jun 7, 2018 at 10:52 AM
    Lars
    Lars Trail Communicatons Expert
    Lars
    Cedar Creek Texas
    2010 Tundra TRD RockWarrior
    I put a Reese Pod on mine.
    It's not fancy but it worked when I was hauling an enclosed around east Texas post Harvey helping folks out with trees, tarps, and the like.
  3. Jun 14, 2018 at 10:50 AM
    scharring100
    scharring100 New Member
    Houston, Texas
    2016 Tundra Limited 4X4 Crewmax
    2016 Crewmax, Bronze 4X4
    my dealership says they have a software upgrade for the stock controller that improves it a lot. Has anyone had that installed. I would rather not have to buy an aftermarket one unless I have to. If you have tried the upgraded software, does it help and if so, how much. 2016, 5.7, 4x4 Limited. The trailer I plan on buying will be a small one and will not accede 75% of the recommended pulling weight. I do plan on a rear sway bar and a WDH
  4. Jun 14, 2018 at 10:57 AM
    040Tundra
    040Tundra El Chapo
    Aaron
    Las Vegas, NV
    Super white '16 CM LTD 4x4
    I've had the factory brake controller update done on my truck (16 CM 5.7) and it works flawlessly!
    scharring100 likes this.
  5. Jun 26, 2018 at 5:33 PM
    lewi3069
    lewi3069 New Member
    2017 Crew Max 4x4 Sunset Bronze
    Is there a TSB for the update? Also does it apply to the '17s?
  6. Jun 26, 2018 at 6:02 PM
    Sterlinglwood
    Sterlinglwood Never enough!
    Sterling
    Newbury Park, CA
    2017 Tundra Double Cab SR5 4X4
    I run @ 9.5 pulling ~3k lbs w/factory controller. Might have to look into this update.
  7. Jun 26, 2018 at 7:38 PM
    ldale
    ldale New Member
    Txk Tx
    17' Limited Silver Sky Metalic
    Tonno Pro LowPro , TRD Sway Bar, Helwig Leaf Pack
    Yes there is an Update. Just had mine done while there for another TSB related issue.
    The TSB for the IBC is BR1612=.3
    Have not had the chance to use it with a trailer yet so I have no input on the effectiveness of the Update.
  8. Jul 4, 2018 at 1:26 PM
    DvH297
    DvH297 New Member
    Derek
    2018 CrewMax SR5 TRD O/R 4x4
    I have an '18 with the factory TBC. Having issues with it saying 'trailer disconnected' and no brakes. Anyways, per my dealer, only the '14, '16, & '18 came with a brake controller. Does your '17 have a factory TBC? And does it operate the brakes correctly?
  9. Jul 4, 2018 at 3:41 PM
    ldale
    ldale New Member
    Txk Tx
    Think your dealer is wrong. They didn't start putting the IBC in until the 16' model year and continued in the 17' and now the 18'. I had the update done last week or so and have not pulled the camper since then. Sorry I can't be more help.
    gosolo likes this.
  10. Jul 4, 2018 at 6:22 PM
    94slowbra
    john
    new orleans
    2016 TRD pro
    well this is good news. ill have to swing by the dealer and get this done. hopefully it works better
  11. Jul 4, 2018 at 6:40 PM
    too tall
    too tall New Member
    I went thru the same. Even after the factory software update the controller was not adequate for pulling a 6K trailer. I put in a Tekonsha P3 which is brilliant and a 10 min. job.
