Bestop Tonneau Cover Install with KB Voodoo Bed Crossbars
Discussion in '2.5 Gen Tundras (2014-2021)' started by KB Voodoo, Aug 8, 2017.
  1. Aug 8, 2017 at 8:59 PM
    KB Voodoo
    KB Voodoo [OP] New Member
    Chad
    2017 Tundra Pro Crewmax, Cement
    Many KB Voodoo Fabrications accessories!!
    Finally getting around to posting this up.
    Install was super simple.
    Parts
    Truck: 2014-2017 Tundra Crewmax
    Cover: https://www.amazon.com/gp/product/B01JETYO7M/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
    Instruction Sheet Specific to Cover: https://assets.bestop.com/files/_bestop/9/10/1/14060_b.pdf
    Crossbars (our own, of course): http://www.kbvoodoo.com/shop/toyota-tundra-hi-rise-crossbars-for-use-with-tonneau-covers
    NOTE: Your truck must have the Deck Rail option for this mod!!
    Step 1
    Install aluminum blocks for cover, and T-Slot nuts for crossbar uprights (this is easier if you bust out your T30 torx and take the accessory rail right off). Place all the parts in the rail in the proper sequence.
    Step 2
    Bolt the uprights for the crossbars in place (TIP: leave them a little loose so you can slide them into position after the cover is on)
    Step 3
    Simply lay the cover on the bed towards the cab, and from underneath, attach the built in clamp to the aluminum block and tighten (make sure it's square to the bed first).
    Step 4
    Slide the crossbar uprights to the position that you want, and tighten the bolts.
    Step 5
    Folder the cover down until it covers the bed.
    Step 6
    Place the crossbars on the uprights and install the knobs (or optional tamper proof bolts).
    That's it, you're done!!
  2. Aug 8, 2017 at 10:28 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Hell yeah!! Looking badass
  3. Aug 9, 2017 at 1:10 AM
    hooter
    hooter New Member
    2019 SR5 TRD Off Road Crewmax
    Great setup! I'd like to do this to my truck.
  4. Aug 10, 2017 at 8:50 AM
    KB Voodoo
    Chad
    It's a great system, although I might be slightly biased.
    Eclipsed & Floating and TheBeast like this.
  5. Aug 11, 2017 at 6:10 AM
    RussellVaughan
    RussellVaughan New Member
    Houston
    2015 Gray TSS 5.7 CM SR5 4x4
    AMP Research PowerSteps; Katzkin leather seats (Nightrunner, all black, no perf/logo); TRD 18" BBS Forged rims; Nitto Terra Grappler G2 LT295/70R18) tires; LT295/70R18 spare tire; Rough Country speedo calibrator; Fox 2.0 IFP front & rear w/1" leaf blocks; TRD PRO black headlamps w/Headlight Revolution harness; TRD PRO grill w/color match hood bulge; RCI engine skid plate; BakFlip MX4 tonneau; Baja Design Squadron Sport fog lights w/clear wide lens; front/rear color match bumper covers; K&N CAI; Pedal Commander throttle controller w-trailer brake bezel; SE Toyota wireless charger tray; VLEDS interior and exterior LED lights; AJT Designs interior chrome delete; Sparks Parts driver side grab handle kit; Pop&Lock tailgate lock; ICS Fab dash mount w/support plate; ICS Fab center console mount; SNS Custom Design ABS sensor guards; TRD PRO shift knob; Undercover Swingcase bed storage; Rad Rubber Design engine splash guards; Bull Ring bed rail tie-downs; exterior debadge w/black & engine badge and black 4x4 badge; Charvonia Design billet bed tie-down anchors; rear console USB port; TRD rear sway bar; Fumoto Oil Pan Valve; Toyota metal oil filter assembly; Vexing R1 dash cam; X2Power 24F Battery.
    this is awesome. i've been looking for something like this for a roof top tent that I can also use with my tonneau. The website says it supports roof top tents, but there is no load rating indicated. Do you know what it is?
  6. Aug 11, 2017 at 6:29 AM
    KB Voodoo
    Chad
    We don't like to state exact load ratings, because it's so dependent upon how the item is used.
    These bars will hold almost any tent within reason. Obviously, if there are 3 or 4 HUGE people in it, there might be problems.
  7. Nov 9, 2017 at 6:01 PM
    KB Voodoo
    Chad
    And now with a really cool rack...
    blue16 likes this.
  8. Nov 9, 2017 at 7:18 PM
    Borgs
    Borgs New Member
    PA
    Y'all need to figure something out for the BAKflip covers. I'd be the first to order a set!!!
  9. Nov 9, 2017 at 7:22 PM
    KB Voodoo
    Chad
    Those damn Bakflip covers are literally the bane of my existence.
    Eclipsed & Floating likes this.
  10. Nov 9, 2017 at 8:20 PM
    Borgs
    Borgs New Member
    PA
    Had i known when I got it, I would have went in another direction. I am not a big fan of it.
  11. Nov 10, 2017 at 5:38 AM
    Ebbsnflows
    Ebbsnflows New Member
    2015 Tundra - 1794
    Out of curiosity, why won't the bars work with bakflip covers?
  12. Nov 10, 2017 at 5:40 AM
    KB Voodoo
    Chad
    In their infinite wisdom, Bakflip came up with this kooky bracket that relocates the factory deck rail. Our uprights attach to said deck rail.
  13. Nov 10, 2017 at 5:45 AM
    Ebbsnflows
    2015 Tundra - 1794
    Ahhh...gotcha. I don't have a bakflip...but was curious. Speaking of the crossbars, though...any plans for "Black Friday" deals on them? ;)
  14. Nov 10, 2017 at 5:48 AM
    Borgs
    Borgs New Member
    PA
    Even if you fabricated a longer bracket to make up the lower rail, I don't think your design would work - would it? Due to the low profile and seal of the actual cover. I am no engineer Hope I am wrong.
  15. Nov 10, 2017 at 5:48 AM
    KB Voodoo
    Chad
    We don't do sales. Sales mean that you've been gouging your customers all year, and now things are slow, so it's finally time to charge a fair price.
    That said, if you want a set, PM me and I'll get you a promo code.
  16. Nov 10, 2017 at 5:50 AM
    KB Voodoo
    Chad
    They move them down, and they move them in. Plus they have a metal frame that you would have to cut away.
  17. Nov 10, 2017 at 6:01 AM
    Borgs
    Borgs New Member
    PA
    I'd consider taking the cover off to Use the racks. Not hard to do. But I take it there is no way to adjust to account for the bed rail rack being brought in?
  18. Nov 10, 2017 at 6:04 AM
    KB Voodoo
    Chad
    Not that I'm aware of....
    But...we are coming out with a universal tonneau cover crossbar that might work in that situation.
  19. Nov 10, 2017 at 6:40 AM
    Eclipsed & Floating
    Voluptuous Whitey
    Great response....im in full agreement about that. It's rare I cash in on a BF sale. I. Really just pissed they wanted full price earlier in the year
  20. Nov 10, 2017 at 6:45 AM
    Eclipsed & Floating
    Voluptuous Whitey
    @KB Voodoo
    Tell me the process of removing a bed basket. I'm about to order one and don't really think I need sliders but can't make up my mind
  21. Nov 10, 2017 at 8:04 AM
    KB Voodoo
    Chad
    To take it out, you would just pop four bolts off.
  22. Nov 11, 2017 at 11:29 PM
    775tundra
    775tundra New Member
    2015 superchargered CM
    Magnuson supercharger, 22x9.5 black rhino traverse, black widow muffler, URD pulley, katskins, pioneer 4600NEX , Toyo ST2, SOS racing 2/4 drop
    Looking good!
  23. May 24, 2022 at 9:45 PM
    avssuc
    avssuc Efilnikufesin
    Gulf Coast
    2021 Tundra TRD Pro LR
    Would this work with a BAKFlip trifold tonneau?
  24. May 25, 2022 at 4:44 AM
    KB Voodoo
    Chad
    Yes, absolutely!!
    avssuc[QUOTED] likes this.
  25. May 26, 2022 at 1:45 PM
    avssuc
    Gulf Coast
    It just slides under that strip there? No issues with water getting in after the installation?
    Sorry, there just isn't much online about this, and if there is, its obscure, so I'm sorry if I've missed any answers here. I really only need the cargo bars to carry rooftop cargo box, and that's only for hurricane evacuation, and I really like that tonneau... so I need to be sure.
  26. May 26, 2022 at 1:46 PM
    KB Voodoo
    Chad
    Yep, our uprights fit under the rail of the cover. You may see a little water intrusion, but weatherstripping can be added to prevent that.
  27. May 28, 2022 at 11:17 AM
    Redpill
    Redpill New Member
    2015 Tundra DC Limited 4x4
    Leveling kit, airbags on rear axle, led light bar with cattle pusher.
    I have the Undercover Ultraflex tri fold. Will these bars work with this cover. If so this could solve a problem I'm having!
  28. May 28, 2022 at 11:23 AM
    KB Voodoo
    Chad
    I believe on a Tundra that cover is compatible.
    It gets tricky with a Tacoma.
