best wheel paint
Discussion in '1st Gen Tundras (2000-2006)' started by danmurphymn, Aug 1, 2022.
  1. Aug 1, 2022 at 7:16 AM
    danmurphymn
    danmurphymn [OP] New Member
    Minneapolis, MN
    Black 2004 DC TRD
    What do you all use for a good high quality wheel paint? Something 2 part with a hardened clear?
  2. Aug 1, 2022 at 8:20 AM
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
    I like powder coat. What wheels are you painting?
  3. Aug 1, 2022 at 8:22 AM
    danmurphymn
    Minneapolis, MN
    Black 2004 DC TRD
    thanks, these are just going to be a spare set of stock tundra aluminum wheels. While i would prefer to powdercoat, I'm planning just a sand & re-spray with the tires still installed.
    2006Tundra[QUOTED] likes this.
  4. Aug 1, 2022 at 8:24 AM
    2006Tundra
    Lou
    Long Beach, CA
  5. Aug 1, 2022 at 8:39 AM
    shifty` Waving My Dick In The Wind
    All I'll say is this, what I always say when people bring up 2-part paints like SprayMax 2k clear packs:
    SprayMax and similar 2-part paints contain Isocyanates. THEY WILL KILL YOU if you don't wear a proper respirator, the gas mask type, not a KN95.
    Best way to put in layman's terms, think of Isocyanates as superglue vapor. You know what super glue does when it touches your finger, immediately hardening?
    That's basically what airborne Isocyanates do when they come in contact with your lung tissue. If you go down that route, protect your lungs, it's hard to get another pair.
    ATV25, tunyota, HBTundra and 2 others like this.
  6. Aug 7, 2022 at 6:07 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Shifty - superglue is cyanoacrylate. Polyurethane paints contain various isocyanates. The health concerns with iscocyanates includes mucous membranes irritation, chest tightness, difficulty breathing and severe asthma like symptoms. Several isocyanate compounds are classified carcinogens. NIOSH recommends a supplied air respirator for these products
  7. Aug 7, 2022 at 7:30 PM
    Right, note the "cyan" Latin root in both. All part of the cyanide group. Just as deadly. If you vaporized super glue at the same ppm concentrate and inhaled it, the results would be about the same.
    Concentration on 2-part paints like Spraymax is just as bad as Imron, and will mess you up just as bad or worse. I dunno if you remember all the controversy with Imron or not, but it was amazing stuff. Sucks, a lot of guys were left maimed or dead unless they had a fresh oxygen supply, studies showed it could break through a standard cartridge respirator in 15 minutes.
    That can of poly Rustoleum bought at the store has a fraction of ppm compared to what a 2-part clear typically has, and even less so what Imron would. I'm obviously not a doctor, my 'harden on contact' example isn't 100% accurate, but from a physiological perspective of what would happen in both cases on contact with healthy lung tissue, it's not exactly wrong either.
    It's worth cautioning people who aren't aware. scAmazon and other vendors selling 2K paints don't bother to alert anyone, many ppl don't like reading labels, and virtually none bother to hunt for MSDS on products either.
  8. Aug 14, 2022 at 2:16 AM
    not so fast 2
    not so fast 2 New Member
    bob
    Dare I say it, I used Plastidip on my stock wheels, have to apply at least 4 coats but no biggee and its been on for about 5 years of more, did it with tires mounted also, and right over the chrome, cleaned of course.
    NSF
