Best Tonneau Cover
Discussion in 'Tonneau Covers, Caps and Shells' started by Kevfran99, Oct 14, 2020.
  1. Dec 8, 2020 at 11:12 PM
    OlRazzl
    OlRazzl New Member
    just ordered a peragon. heard good things and met my needs and most my wants. with the platinum package it was just north of 1k
  2. Dec 9, 2020 at 4:00 AM
    Haggis777
    Haggis777 I.L.J.C.M.L.
    SW Michigan
    2015 Silver SR5 TRD Tundra Canadian Model
    LEDs interior & exterior, stubby antenna, Bak-Flip cover, 285's, AGM battery, block heater, Pine tree air freshener
    My previously-owned 2015 came with the BakFlip G2 hard cover, quad-fold cover.
    It is durable. Can secure the goods in the bed when the tailgate is locked, but...
    DANG, it is heavy to fold back to the window!
    I think the site said it is 250 Lbs. I would probably get 2-3 mpg better without it.
    I had a soft, roll up cover on my Sierra.
    Much easier to work with and easy to maintain. Probably less expensive, too.
    That one came with the truck also.
    Definitely evaluate what works best for you. Pros/Cons to both.
    Windnsea26 likes this.
  3. Dec 9, 2020 at 4:09 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I went with this UnderCover Classic that I found on Craigslist for cheap, it secure and easily removed and set aside if I need to haul something that doesn't fit underneath.
  4. Dec 9, 2020 at 4:51 AM
    FUTRBLD
    FUTRBLD New Member
    South Florida
    2020 MGM Tundra Limited
    I would not recommend the Undercover Ultra Flex for what they cost, I picked one up this summer last minute for a road trip otherwise I would have sent it back. It leaks just enough to be frustrating, even after numerous adjustments and weather striping the tailgate. The cover could almost stand to be an inch longer and slightly wider. Had the ARE LSII tonneau cover on old truck, great for the weather but really limits what you can haul, once I took it off for something it never went back on, will most likely be ordering a cap soon.
  5. Dec 11, 2020 at 9:04 AM
    Bronco Ken
    Bronco Ken New Member
    Ken
    MGM 1794
    Wife just ordered me the RETRAX XR ONE as I want to use the Yakima Overhaul HD to load kayaks on and still keep the bed locked with all our crap in it.
  6. Dec 11, 2020 at 9:42 AM
    KingsAustin
    KingsAustin Grey Goose II
    Morgan County, AL
    2021 Limited Night Shade
    BakFlip MX4, Gator All Weather mats, Console Safe, Ceramic Tint, Roadmaster Active Suspension, Interior/exterior LED conversion, Wireless console charger, AJT designs.
    Not sure about the best, but I am on my second Bakflip MX4 cover. Never had an issue, no leaks and stands up good with the Texas sun. Under 900 on some sites.
  7. Mar 8, 2021 at 2:22 PM
    Berschwinger
    Berschwinger New Member
    I'm thinking about getting the Ultragroove myself. Did you have to give up your track system to install it?
  8. Mar 8, 2021 at 2:44 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    No. I kept the tracks. The cover does uses the rail system so it will limit the travel of your anchor points.
    Berschwinger[QUOTED] likes this.
