Best Tires for Stock TRD Pro 2016
Discussion in 'Wheels & Tires' started by Stryker770, Sep 17, 2017.
  1. Feb 3, 2018 at 4:44 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    No cutting or trimming; these wheel wells are pretty large. I have coilovers in the front set at about two inches of lift and stock leaf springs in the rear.
    BuckWallace[QUOTED] likes this.
  2. Mar 3, 2018 at 1:56 PM
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    Yeah the DuraTrac looks great
  3. Mar 7, 2018 at 10:54 AM
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    I’m surprised more people don’t like 285/75/18....
    Alexstundra and Watt maker like this.
  4. Mar 8, 2018 at 5:48 AM
    Js18tundra
    Good point, are the cv shackles more bulky?
  5. Mar 8, 2018 at 8:23 AM
    Js18tundra
    Holy ass... lol no wonder they are $300!
    Watt maker likes this.
  6. Mar 8, 2018 at 10:02 AM
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
    I do not have a Pro but my front is exactly 2" higher than stock (5100's on middle setting with 1 coachbuilder shim on each side) and I am about to pick up new wheels with a +25 offset. Will the Duratrac 295/65 18's fit with only removing the front mud flap or would more trimming be required? @Cutter29 was running stock wheels (+60 offset) with 1.25" spacers making the effective offset +28.25. (The guy at my tire store is trying to talk me into a zero offset wheel and everything that I have read hear indicates that this could cause issue.)
  7. Mar 8, 2018 at 10:56 AM
    Cutter29
    Cutter29 ...
    Utah
    2015 Super White TRD PRO
    I ran the 295/65 18 on stock +60 wheels with zero issues. When I added the spidertrax I had to remove the front flap. I switched to new wheels with +25 and upsized to 295/70 18. With the new wheels and tires I had to heat gun the front liner just a little in two places.
    With +25 wheels you’ll pull the front flap and maybe have to do a little liner work. Each truck sits just a little different. A heat gun will fix it in 5 min or you can do the liner relocate that many on here do.
    With zero offset I believe you’re going to be doing a lot more work and have more issues possibly even cab mount contact but I’ll let the more knowlegable guys handle that offset question.
    Watt maker and sr5shark[QUOTED] like this.
  8. Mar 8, 2018 at 11:20 AM
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    Thanks, @Cutter29. It sounds like 295/65 should work. I don't mind removing mud flaps and/or working with the front liner but I do not want to do the CMC. (I also think that I need to find a new tire guy - he is insisting that the only way to fit bigger tires on the Tundra is with a lower offset wheel (+0 or +1).
  9. Mar 8, 2018 at 11:41 AM
    Cutter29
    Cutter29 ...
    Utah
    Your tire guys needs to smoke less crack. Bet him a hefty discount that 295/65 18 will fit with stock or +25 offset? Maybe @csuviper can chime in. He has the wheels and tire combo situation dialed.
    sr5shark[QUOTED] likes this.
  10. Mar 13, 2018 at 3:44 PM
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    Hi @Cutter29, I was reading through your build log and had a question about the your fitment of the 295/65's - were you running these tires on the stock wheels with the spidertrax spacers before your added the 2 cb shims? (Pro + 2 shims would put the front lift at about 3" - I am at 2"). I have a set of SCS SR8s in my garage and am about to pull the trigger on either the Duratrac 295/65 or Toyo R/T 33/12.5. Thanks!
  11. Mar 14, 2018 at 6:58 AM
    Cutter29
    Cutter29 ...
    Utah
    Correct. Ran 295/65 stock from day one. Added spidertrax a few thousand miles in and shims around the 28k mark.
  12. Oct 21, 2018 at 12:47 AM
    Airfire06
    Airfire06 New Member
    2016 trd pro
    Nothing yet
    Did u put spacers in the rear too
  13. Oct 21, 2018 at 5:41 AM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    I ran this tire on my 2/0 lifted 2016 with an aftermarket bumper. No mods were necessary. I recommend them.
  14. Oct 21, 2018 at 5:44 AM
    Over the LINE
    New Orleans
    I got about 45K out of my last set. They still had plenty of tread for street driving but were getting too noisy for me. I had the same experience with 3 sets on my Nissan Titan.
    Rica25 and IndyTundra[QUOTED] like this.
  15. Oct 26, 2018 at 2:24 PM
    Airfire06
    2016 trd pro
    Nothing yet
    How dirty does your truck get with the spacers mine is dirty bad
  16. Oct 26, 2018 at 2:29 PM
    Airfire06
    2016 trd pro
    Nothing yet
    Here it is
  17. Oct 28, 2018 at 6:56 PM
    Cutter29
    Cutter29 ...
    Utah
    I ditched the spacers for new wheels last winter. Still about the same offset. I just accepted the fact that I was going to get dirty with the stance I wanted. It was only when the roads were wet. After living/working on a dirt road this summer I had enough and put a set of rokblokz flaps on. Not a huge fan of the flap look but they’re a lot better coverage than the stock.
  18. Dec 20, 2018 at 12:11 PM
    MGM
    MGM New Member
    I’m looking at this size for my 2016 trd pro and will not add any modifications. Keeping the oem wheels. Have you experienced and issues thus far? I will remove the mud flaps that’s no worry. I do have a snugtop on the back I don’t know if that changes things. I am also looking at 285/75/18 as that tire is not as wide.
  19. Dec 20, 2018 at 9:54 PM
    #49
    MGM
    MGM New Member
    That’s good to hear. I still have plenty of thread on these stock tires but I’m fairly certain of what tire and size I’m going for when it comes time to replace them. I knew I should have stopped reading when you mentioned shackles. I read how aftermarkets can help with the sag in the rear and provide a beefier ride. :spending:
  20. Dec 21, 2018 at 12:54 PM
    #50
    MGM
    MGM New Member
    I like this mod, +2 seems modest as I am not a fan of the rear hanging.
  21. Feb 29, 2020 at 6:00 AM
    #51
    spettijohnjr
    spettijohnjr New Member
    2016 Toyota Tundra TRD off-road 4x2
    Leveling kit
    I’ve got a 2016 Toyota TRD off-road 4x2 that I just placed a leveling kit on. I want to go with a larger tire and currently have Nitto crosstek 275/65/R18. What is the largest tire I could go with without adding a lift?
