Best shocks for ride quality?
Discussion in '1st Gen Tundras (2000-2006)' started by Maximus213, Aug 18, 2024.
  1. Aug 18, 2024 at 2:59 PM
    Maximus213
    Maximus213 [OP] New Member
    Max
    2003 4.7v8 tundra
    I purchased my 2003 tundra about a year ago with bilstien 5100s already on it but even with those the front end was a bit lower then the rear and I bought some 33s and being low on cash I threw a spacer lift on the front to level it the rest of the way but now I find the the ride quality is terrrible you feel every bump in the road I’ve read the 5100s are a little stiff and spacer lifts are bad on ride quality so what would be the best route new shocks, new springs, etc? Are there shocks out there that are a little better for ride quality?
  2. Aug 18, 2024 at 3:04 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    How did you like it before the spacer? If you want level, go with OME 883/884/885 springs (you’ll need to look up what’s optimal).
    Most here would say for comfort go with the Bilstein 4600s but you won’t have it leveled, so it’s up to you to decide.
    Just stay away from spacers.
    HBTundra likes this.
  3. Aug 18, 2024 at 3:11 PM
    Maximus213
    Max
    2003 4.7v8 tundra
    I’ll look into new springs, would the 884 fit right on?
  4. Aug 18, 2024 at 3:17 PM
    Jack McCarthy
    Bill
    North of Boston
    I’m not the one to ask on that. There are several sites like https://www.1stgenoffroad.com that will give you the info you want or you could wait to hear from others here for advice who have the same model as yours with the OME/Bilstein setup for leveling.
  5. Aug 18, 2024 at 6:14 PM
    shifty` In South Dakota Trouble ain't hard to find
    HBTundra and Diablo169 like this.
  6. Aug 18, 2024 at 9:39 PM
    Maximus213
    Max
    2003 4.7v8 tundra
    From what I read ome 884 springs are what I’m looking for but will I need any other parts other than the springs to fit them or are they the same size as the stock springs just taller?
  7. Aug 18, 2024 at 10:47 PM
    j_supra
    j_supra Dreamin about boooost!
    Manitoba, Canada
    2008 Tundra Limited
    20x9 Vision brawls, 285/60 Toyo at3s, Bilstein 5100s, Tint, rock warrior grille, all chrome removed. fully paint matched, HID headlights, LED tail lights, LED fog lights, Doug thorley LTH, custom exhaust, AEM filter, TRD intake pipe, Joying HU, hertz components and sub,
    First things first, what clip setting were your 5100 set to? How thick of a spacer did you install? How much lift are you looking to achieve? And did you put the 33s on at the same time as the spacer lift?
    Riverdale21 likes this.
  8. Aug 18, 2024 at 11:16 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    2” Lift, Bilstein 5100’s and 885’s second notch, Rear 5100’s Icon 3 Leaf Pack and Firestone Air Bags w/Daystar Cradles. Spider Trax 1.25” Wheel Spacers, 4Runner Pro Wheels, Falken AT3W 285/75r17 (34x11).
    If you installed top spacers, your ride would not change. Now if you're running E rated 33’s with too much pressure, that could dramatically affect your ride.
    j_supra likes this.
  9. Aug 19, 2024 at 6:20 AM
    Spacers will impact geometry, thus will impact ride, it won't be negligible. This explains why (see the text I quoted from @des2mtn, then the image I posted for a visual representation). Not trying to 'splain anything, I know you know suspension, I thought same as you until Des opened my eyes and sent me hunting for more info on the suspension design in these trucks.
    When you mix spacers and lift components, at least from what I've seen on here, the combo of spacer and lifted spring/strut tends to amplify the lift, for lack of better terms.
    Whereas you may get 1.5" lift from a spacer, and 2" lift from a strut, mix the two together and you end up with 4.5" lift (example #'s there). This one was my favorite, where this kid went to a shop who installed Rough Country lifted struts and strut spacers, and he ended up bending up and mangling his shit because he landed with probably 4-5" lift as a result. He probably could've used aftermarket uppers which may've helped a bit to avoid contact, but I'm guessing unless he had a good donor parts truck, he probably spent a fortune fixing what the "shop" fucked up (assuming it actually was a shop that installed that shit, I never believed it).
  10. Aug 19, 2024 at 6:44 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Personally I don’t think 5100’s ride good on any pickup truck. Suspension feel is incredibly subjective, but an old truck is going to ride like an old truck point blank period.
    If you want to get it to a have smoother ride you’d need to be on 6112/5160 at bare minimum.
    If you want plush and to absolutely eat up everything the recipe for success is aftermarket bumpstops and you need to be looking at 2.5” shocks preferably with adjusters. Just remember the more performance you’re looking for in a shock usually means you’re going to give up road manners.
    I’d start with removing the spacer, adjusting the perch for ride height, and then adding bump stops. You can’t lose by doing this and it’s the cheapest way to start. If you’re not happy with the results I’d establish your budget first and then start the search for new shocks and adjust it as necessary. I’m a big believer in money spent on suspension is money well spent.
    flyfisher, Weejub, des2mtn and 3 others like this.
  11. Aug 19, 2024 at 7:01 AM
    Having a 5100 shock with any degree of lift and then adding a spacer will 100% change the ride. Geometry alone will be suboptimal, but pushing the wheels down puts the front suspension closer to it's droop limit. Every time the suspension needs to cycle down, instead of having room to do so, it hits the limit of droop and suddenly stops, giving a jarring ride. Just like bottoming out the suspension, just in the other direction.
  12. Aug 21, 2024 at 2:07 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
  13. Sep 10, 2024 at 9:03 PM
    Maximus213
    Max
    2003 4.7v8 tundra
    Well if I want to be able to go off-road without feeling every pebble I go over but I also want some decent on road performance what’s the best way to go 6112/5160, just new springs on my 5100s and ditch the spacers?
  14. Sep 10, 2024 at 9:33 PM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    Lifts , Springs, and Spacers aside . . . the previous owner of my truck had just put a set of KYB 'Gas-a-Just' shocks on the truck before I bought it. (stock suspension)
    I have no complaints with the ride when empty.
    With the truck loaded with camping / fishing gear, myself and one other person, and pulling my boat, they seem to work well.
    I pull the rig down a 15 mile dirt road slowly cruising and the ride / handling seems acceptable.
    When on the highway towing the rig, I don't notice any unusual 'swaying' or excessive 'bouncing'.
    When I 'get on it' a little to pass, or find myself on a curvy section of highway, maybe with some wind, the rig still feels safe, and easy to control.
    I'd describe the ride as 'soft but sure'.
    I can't speak to the life, or longevity of the shocks . . . but I'm at 4 years now with no (or very little) degradation in ride quality.
    Hope this helps a little, if not for the OP, maybe for anyone shopping for shocks who wanted feedback on something other than Bilstein.
    shifty` likes this.
  15. Sep 11, 2024 at 7:05 AM
    Dook55
    Dook55 RCLB Guy
    Montana
    2004 4x4 V8 RCLB 2006 4x4 V8 RCLB
    When asking about ride quality or rifle scopes, a young person will usually give a thumbs up and an old person will give a thumbs down.
    Stock suspension, Bilstein 4600's improved my ride quality considerably. I put them on both my trucks.
  16. Sep 11, 2024 at 8:00 AM
    3bears
    3bears New Member
    Joshua
    fairbanks alaska
    2002 acess cab
    none yet
    currently my truck has leaking rear shocks, and the fronts are white, i dont know the brand p.o put on. it also has overload springs on the back. it still rides ok and rides better when its got weight in the back. Ive had good luck with KYBs on my 4runners, so might go that route with this one.
  17. Sep 11, 2024 at 8:19 AM
    FishNinja
    Lee
    06DC2wd
    White shocks are rancho or rough country I think; maybe even KYB(?)
  18. Sep 11, 2024 at 8:24 AM
    Rancho is white. If he has Ranchos on the front, guaranteed the shock bushing where it mounts to the LCA is blown out. And everyone I've seen post on here has said they ride harsh as shit.
    Rough Country is off-white, almost like a super light grey.
    I can't think of any others that are white.
    FishNinja[QUOTED] and KTM_AJ421 like this.
  19. Sep 11, 2024 at 8:29 AM
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    265/75r17 M/T Baja Boss AT 17x8.5 -10mm SCS Ray 10’s Bilstein 5100’s 2nd notch
    Did you put your 6112s on yet? I want to know how they ride
  20. Sep 11, 2024 at 8:32 AM
    Nah, still lack KYB tophats and isolators, so can't assemble them.
    KTM_AJ421[QUOTED] likes this.
  21. Sep 11, 2024 at 8:58 AM
    Dook55
    Dook55 RCLB Guy
    Montana
    Yes, 150 to 200 pounds behind the rear axle makes a huge difference.
  22. Sep 12, 2024 at 8:44 AM
    3bears
    3bears New Member
    Joshua
    fairbanks alaska
    2002 acess cab
    none yet
    look fairly white to me, and they are harsh
  23. Sep 12, 2024 at 8:45 AM
    3bears
    3bears New Member
    Joshua
    fairbanks alaska
    2002 acess cab
    none yet
    100 gallons of heating oil made it ride much nicer
