Best setup with 5100’s
Discussion in 'Suspension' started by teedubbya, Sep 16, 2018.
  1. Sep 18, 2018 at 4:03 AM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    If it's in your budget, I would say to certainly go ahead with the new shocks/coilovers. Also depends what you use your truck for. If the truck is a street queen you should be fine with one of the spacers. If you take the truck offroad at all or want the "best option", then I would certainly go with the new shocks.
  2. Sep 18, 2018 at 3:18 PM
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    David
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    The front 5100's normally provide about 2.5" on the top setting but will see just a touch more with your truck being 2wd. ( Maybe 2.625"-2.75" ) and if you add 2 shims on the driver side and 1 on the passenger side you'll see about 3.25" of total lift up front. You will def want to add some lift to the rear, if not your traction control will go into panic mode when accelerating, cornering or braking. We normally use our +3" (1.75") I'll attach a pic with 3" up front and 1.75" in the rear.
  3. Sep 18, 2018 at 9:56 PM
    Dez@Nexgenoffroad
    Dez@Nexgenoffroad New Member
    DEZ
    We just dialed in this tundra with are 3+1 bilstein 5100 kit.
    Hammerdog, teedubbya[OP] and parker44 like this.
  4. Sep 18, 2018 at 11:33 PM
    K6BRY
    K6BRY New Member
    2017 Black Tundra TRD 3/1 Lift Sittin' on 34s
    5100s all around. Set to max up front with 2 CB spacers on drivers side and 1 CB spacer on Passenger. Rear has a 1" lift with shackles. 295/70/18 Toyo Open Country AT2, I needed to cut some of the plastics up front for clearance but nothing major. Any questions, let me know! I love the look! ^^^ Dez at NexGen hooked me up with this setup last week, Thanks again Dez!
  5. Sep 19, 2018 at 6:29 AM
    teedubbya
    teedubbya [OP] I like fat booty
    Austin TX
    2019 trd pro voodoo 4runner
    What did the setup run you (not including wheels/tires? Which shackles?
    K6BRY[QUOTED] likes this.
  6. Sep 19, 2018 at 4:36 PM
    K6BRY
    K6BRY New Member
    I would prefer not to discuss the pricing that I was given, but feel free to contact Dez at NexGen Off-road in Murietta. :-D
  7. Sep 25, 2018 at 3:33 PM
    Brian0414
    Brian0414 Doomsday
    Tucson, AZ
    2017 Tundra Limited 4x4
    - Winjet Black/Smoke Fiber Optic LED Tail Lights Bilstein 5100
    Installed 5100 top setting and the shop is saying they are having issues aligning it because of the stock UCA's. Anyone have issues? I planned on upgrading anyways but for the time being I was hoping to get by.
  8. Sep 26, 2018 at 3:44 AM
    parker44
    parker44 New Member
    I haven't heard of anyone having install issues with only 5100s. Typically alignments get tricky going above 3".
    Brian0414 likes this.
  9. Sep 26, 2018 at 7:38 AM
    K6BRY
    K6BRY New Member
    I just did a 3 inch front lift, 5100 set at top setting with a 1/4" spacer on 295/70/18 and the shop made no mention of it not aligning properly, I didn't have an issue with the stock UCAs.
    Brian0414[QUOTED] likes this.
  10. Sep 26, 2018 at 8:40 AM
    Brian0414
    Brian0414 Doomsday
    Tucson, AZ
    Thanks, I figured. They were really pushing UCA's. Probably to get more $$$
  11. Oct 6, 2018 at 1:13 PM
    iamsmokey
    iamsmokey Smokey the Tundra
    Oahu, HI
    2018 Cement SR5 Off-Road 4x4 Crewmax
    What's up dude, I have my 5100's on top setting and an AAL in the rear. With stock UCA's I couldn't get my alignment in spec. I got the Camburg Balljoint UCA's and it fixed it right up.
