Best Performance Chip?
Discussion in 'Performance and Tuning' started by EdwinHallett, Dec 13, 2014.
  1. Nov 25, 2016 at 3:47 PM
    dirtydeeds
    Keith
    USA
    more than I can list here
    magnusson is $7500 with tuner.
    The only thing avaialble right now for 2017 that actually works is hypertech. Check out www.dirtydeedsindustries.com and give a call with any questions.
  2. Nov 30, 2016 at 3:36 PM
    bsavoir
    bsavoir New Member
    Killeen, TX
    2016 Tundra Limited CM 4x4
    Gibson Metal Mulisha Exhaust, Replaced bulbs w/ LED's, AFe intake, Bullydog Tuner, Aftermarket Audio system, Rhino Bed Light sports bar, Tonneau Cover, Spyder Auto Headlights and Taillights, Recon 3rd Brake Light, Kensun HID's, Fender Flares, Custom Leather Interior, Heated Seats, 5% Tint on the Rear Windows, Pod light Foglights, 31" light bar behind the grille, linex spray bedliner, linex sprayed grille, ditch lights w/ dual 3in LED pods, 60" Tailgate LED strip.
    I have had the bullydog programmer installed for about 14 months and no issues so far. Now to answer your questions,
    1. I would say yes, I believe it only geos to the 2014 models as of now. It gives you Premium, Economy, Trail, Towing, and stock tunes. you can also select Performance or stock shift points, Speed limiter, and adjust the throttle. You can only select 3 at a time (without internet) I you want to start fresh you will need to re-download the files from bullydog's Update app for windows.
    2. The performance will be greater if you have aftermarket CAI, Exhaust, headers. So it would be better to have performance mods added.
    3. It can also calibrate the speedometer for bigger tires.
    I have not had any issues using it. the minor annoyance is it needs a battery charger to maintain 12.1V at all times while it is flashing if it falls below it could cause issues, I don't know as I never experienced this. The shifting feels better especially when under heavy throttle. I believe they got an extra 70hp out of the TRD supercharger. I also replaced my stock Entune system (speakers and all) with an Joying Android Headunit and lost the ability to change settings via the settings menu on the stock radio. The Bullydog tuner allow those setting to be changed and some that I have not seen on the radio. You can also turn off all the nannies with a couple button presses instead of pressing about 3 seconds and repeat that 2x more it will be reset when the truck is turned off. You can also get performance logs, tests 0-60, 1/4 etc, economy testing I never used these but they are there, monitor the transmission temp and the center display doesn't do so yet.
    You are recommended to run premium gasoline. I waited until I was near empty to fill up with premium, I noticed that it would stutter when pushed to near max RPM's when going from a stopped position or even while driving but after a few fill-ups it went away.
    Depending on your needs it can be an all-in-one setup. tuner, performance testing, access to settings, speedo calibration, monitor oil temp, coolant, trans.
    TheBeast likes this.
  3. Nov 30, 2016 at 4:13 PM
    FlashCulprit
    FlashCulprit ColoradoTJ's whipping boy/Gino's illegitimate son.
    Joe
    Salt Lake City, UT
    2010 Super White SR5 TRD 5.7 4x4
    @dirtydeeds is your go to! They are super knowledgeable about their products including bullydog tuners. (Super nice guys too).
  4. Dec 1, 2016 at 2:03 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    @bsavoir Approx how many HP's could one get by replacing the headers, exhaust and CAI with the Bullydog?
  5. Dec 1, 2016 at 3:58 PM
    bsavoir
    bsavoir New Member
    Killeen, TX
    Ive never got a dyno done, I want to just to see how much of the HP/TQ these company's boast. But I have seen some other tundra forums have people who posted some of their dyno sheets above 400hp w/out forced induction. The long tube headers provide a better jump in hp over short tube but is illegal in some states like my state.
  6. Feb 11, 2018 at 6:27 PM
    Rski85
    Rski85 New Member
  7. Feb 11, 2018 at 6:27 PM
    Check out Daptune
    Rex Kramer likes this.
  8. Feb 11, 2018 at 7:08 PM
    JeremyGSU
    JeremyGSU New Member
    Jeremy
    2016 Tundra
    Love these claims. Don't you think that if Toyota could simply take a laptop and re-program the ECM and get 2-5 more mpg out of their truck they would have already done that stock?
    Don't drink the cool-aid.
    Rakkasan, Sundown5oh and T-Rex266 like this.
  9. Feb 11, 2018 at 7:50 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    When you buy that tuner you might as well get the electric turbo they list as well. It will probably net you + 5 MPGs and a lot of extra HP.
    Seriously, your co-worker has to be full of BS, there isn't a tuner in this world that gives you and additional 5 MPGs.
    Rakkasan likes this.
  10. Feb 11, 2018 at 9:10 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    71_340 and 15whtrd like this.
  11. Oct 4, 2018 at 8:59 AM
    Big Al
    Big Al New Member
    Al
    Tundra trd pro 2016
    Newbie here. Just joined the tundra family. Can anyone tell me about performance chips/mods? Do products like Bully dog really work?
  12. Jun 8, 2020 at 8:01 AM
    Army11
    Army11 New Member
    Brandi
    2007 Tundra Limited crewmax
    None
    Hello,
    I am new to this forum and to Tundras. I just bought an 2007 Tundra limited crew max. I’m looking for recommendations to help increase the performance and the gas mileage as much as one can in a Tundra. This isn’t an every day driver for me but will be used for hauling and highway travel to our cabin/camping. I’ve looked into the S&B CAI and have been checking out some tuners. My truck has the towing package on it. With that said, I’d like to hear people’s insight to what would need to be done for the performance and mpg increase. The truck as of now is stock.
  13. Jun 8, 2020 at 8:05 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I installed a DAP tune on my 2007 about 2 years ago, I am very happy with the results.
    TRDOBSESSED likes this.
  14. Jun 8, 2020 at 8:07 AM
    Army11
    Army11 New Member
    Brandi
    None
    I will definitely check it out. What did you see for performance and mpg increase? Is your exhaust stock?
  15. Jun 8, 2020 at 9:28 AM
    Tundra_power
    Tundra_power New Member
    Nick
    I have bullydog best mod so far. I had the s&b intake with bullydog=badass..
  16. Jun 8, 2020 at 10:38 AM
    Army11
    Army11 New Member
    Brandi
    None
    Which bully dog tuner do you have on your truck the BDX or the GT?
  17. Jun 8, 2020 at 11:31 AM
    Tundra_power
    Nick
    BDX way easier than any tuner iv install.. Hook it up to your internet while in the truck and download the tunes and done super easy..
  18. Jun 8, 2020 at 1:11 PM
    Army11
    Army11 New Member
    Brandi
    None
    What are you getting for horse power and mpg with it?
  19. Jun 8, 2020 at 11:10 PM
    #49
    Tundra_power
    Nick
    Power is great definitely notice a difference on premium tune. Mpg went down because of my heavy foot lol. If you dont beat on it you will get better mpg i saw 0.5 to 1 on average.
  20. Jun 18, 2020 at 2:05 PM
    #50
    dirtydeeds
    Keith
    USA
    SALE SALE SALE BULLYDOG BDX ~ BULLYDOG PLT ~ HYPERTECH
    Sale going on until 6/30/2020:
    BULLY DOG BDX $340 - shipped
    BULLYDOG PLT $375 - shipped
    HYPERTECH $220 - shipped
    Save an additional $20 if you purchase a Bullydog and Hypertech together.
    Dirtydeedsindustries.com or 760-877-4234
  21. Jun 13, 2023 at 5:30 AM
    #51
    Juniorpnc
    Juniorpnc New Member
    2019 Tundra Crewmax SR5
    Sound system... Tonneau Cover.. 3D tundra lettering on tailgate
    Anyone have success raising the MPG gas mileage? That would be my main goal... 2019 crewmax
  22. Jun 15, 2023 at 9:24 PM
    #52
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Only way to create an appreciable fuel consumption improvement is via small, light tires and wheels.
    Exhaust won’t do much for mileage, nor will any intakes (yuck) or tuners.
    If you see an HONEST 1 mpg improvement with a tuner and exhaust, consider yourself lucky.
    Our trucks are great for a lot of things, but mileage just ain’t one of them…
    I have a fairly light foot for the most part. 5.29’s, heavy 34” LR-E tires, HP Tuner that was dialed in on a dyno, run 89 octane, corrected speedometer, and get 14 mpg. 15 if I’m really nice.
    About 2 mpg less than 100% stock with light tires…
    Sleeper16plat likes this.
  23. Jun 15, 2023 at 11:39 PM
    #53
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Keith's exhaust will give you some mpg. I noticed a solid and consistent 1 mpg after. @dirtydeeds
  24. May 11, 2024 at 1:32 AM
    #54
    2001sr5 _yota
    2001sr5 _yota New Member
    Dev
    01 tundra 2r5
    3in cat back. Rest stock
    Can someone drop a link for an affordable ob2 tuner chip??
    Tia!
  25. May 11, 2025 at 4:43 PM
    #55
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    Any updates on this?
  26. May 11, 2025 at 5:45 PM
    #56
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    @JustDSM with a OTT Tune, anything else is vaporware.
    JustDSM and Corndog123[QUOTED] like this.
  27. May 11, 2025 at 6:14 PM
    #57
    Corndog123
    Sam
    Tennessee
    Thank you!! I'll Google ott tune. Thanks again!
  28. May 11, 2025 at 7:44 PM
    #58
    Chad D.
    Chad D. New Member
    Western Oregon
    Like Sniv said, OTT is pretty much the gold standard for a pre-built “canned” tune. Many people are very pleased with their work.
    Your only other good option would involve a lot more money, a dyno, and the unknown if you’ll get better results. Will all depend on the tuner. The biggest advantage to this route is you can make small changes as you like to your engine or transmission tune. Or big changes when you put a blower on…
