Best off road lights
Discussion in 'Lighting' started by Medic, Jun 27, 2017.
  1. Jun 27, 2017 at 7:48 PM
    Medic
    Medic [OP] New Member
    Ontario, Canada
    2014 Limited Crew Max
    Looking to add some round off road lights to the guard being designed for the Tundra. Have been looking at LED but no opposed to halogen lights either. Have had my eye on black background LED's or possible a red ring as an accent. Any preferred types? Looking for advice. Thanks guys.
  2. Jun 27, 2017 at 8:40 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
    Halogens are garbage. HID or LED is the way to go. HID require some warm up time (5-10) seconds. LEDs are the best IMO.
    Vision X makes some round ones if that's what you're dead set on.
  3. Jun 27, 2017 at 9:47 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    For offload lights, I'd stay away from the fancy-shmancy stuff like accent rings. You're only going to use them when there is no one coming your way, in which case no-one will ever see them anyway. Instead, I would concentrate on light output, beam pattern, and durability.
    I'd also stay away from HIDs. When you need off-road lights, you need them now. HIDs are for when you need them in a while. For durability, I'd go with LEDs. As to beam pattern, this is one case where you get what you pay for. There is no end of really nice looking and really inexpensive offload lights, but they tend to have poor reflectors and worse lenses.
    I really like Black Oak lights. Rigid and Baja Designs, also make decent ones.
    Brown Bear and Baja Mike like this.
