Best New Battery???
Discussion in '2.5 Gen Tundras (2014-2021)' started by glenn'sTundra, Jan 25, 2023.
  1. Jan 27, 2023 at 8:14 AM
    #61
    eagleguy
    eagleguy New Member
    Spot on.
  2. Jan 27, 2023 at 8:16 AM
    #62
    eagleguy
    eagleguy New Member
    Been using these batteries ever since moving to Fl in 06. Warranty is excellent and price is reasonable when compared to the other BIG brands.
  3. Jan 27, 2023 at 11:36 PM
    #63
    BingoFuel
    BingoFuel New Member
    Costco FTW
    TXBrit, Leo's first and Tigereye like this.
  4. Jan 28, 2023 at 8:03 AM
    #64
    -PUG LIFE-
    -PUG LIFE- New Member
    Dillon
    Huntsville, AL
    2021 Cement CM SR5 Trail Edition
    I really enjoy it, been with them for almost 7 years now. They really take care of their employees and it’s just an overall great company to work for.
    WILLINH and Leo's first like this.
  5. Jan 28, 2023 at 8:11 AM
    #65
    Redline870
    Redline870 New Member
    Ian
    Central NY
    2021 Super White TRD Pro
    These terminals look super sketch. When I was a technician, I accidentally dropped a wrench on some big open terminals like this and it was quite the fireworks show. I still have the 17mm gear wrench with a melted edge on it too.
  6. Jan 28, 2023 at 8:17 AM
    #66
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I typically try not to do that
  7. Jan 28, 2023 at 8:21 AM
    #67
    Redline870
    Ian
    Central NY
    Me too! That’s why I said “accidentally”
  8. Jan 28, 2023 at 8:23 AM
    #68
    AZBoatHauler
    So.Arizona
    Arc welding is cool.
    reywcms, panicman and TRDFerguson like this.
  9. Jan 31, 2023 at 9:17 AM
    #69
    RetiredTundraBC
    RetiredTundraBC New Member
    San Diego County
    2020 Cement Tundra
    Snug Top, Icons, RXT Fuel Wheels, Toyo RT Trail, Prinsu Top Rack, Iceco Fridge,MIA RTT, RCI Skids,Sliders
    I just installed a Full Throttle 27F AGM. Before I installed I was showing roughly 145 miles to empty. Once I installed the new battery and the computer reset, it showed 200 miles until empty. Weird. So I refilled the tank and it normally shows 415 miles until empty, it showed 602. I''m assuming it's because the computer reset, after installing the new battery, and will recalculate after driving a bit??
  10. Jan 31, 2023 at 9:24 AM
    #70
    AZBoatHauler
    So.Arizona
    Correct. Probably also died the first time you tried to fire it.
    Sierradevil and NewImprovedRon like this.
  11. Jan 31, 2023 at 10:06 AM
    #71
    RetiredTundraBC
    San Diego County
    2020 Cement Tundra
    Yes exactly what it did. Thanks.
    AZBoatHauler[QUOTED] likes this.
  12. Jan 31, 2023 at 10:18 AM
    #72
    biggsy
    biggsy New Member
    Warren
    2010 Tundra DC Rock Warrior
    excuse my lack of knowledge but is 710 a lot compared to stock?
    I was thinking Costco but they dont carry 27F AGM or the 34R Interstate battery
  13. Jan 31, 2023 at 10:20 AM
    #73
    biggsy
    biggsy New Member
    Warren
    would it be worth going with the 24F AGM? same CCA
  14. Jan 31, 2023 at 10:24 AM
    #74
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    I like the AGM primarily due to being sealed and maintenance-free.
    biggsy[QUOTED] and Leo's first like this.
  15. Jan 31, 2023 at 10:33 AM
    #75
    seydou
    seydou Distinguished Member
    Just remember if you go with AGM, that you must add a diode or use a tender regularly.
  16. Jan 31, 2023 at 10:37 AM
    #76
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    Are they maintenance-free if you have to charge them every few weeks
  17. Jan 31, 2023 at 10:50 AM
    #77
    AZBoatHauler
    So.Arizona
    If you don’t just add a voltage booster you’re doing it wrong.
    Leo's first[QUOTED] likes this.
  18. Jan 31, 2023 at 10:52 AM
    #78
    king.cong.1119
    king.cong.1119 New Member
    i have a hood solar panel specifically connected to the battery, would that provide enough juice for an AGM?
    Leo's first and RetiredTundraBC like this.
  19. Jan 31, 2023 at 10:54 AM
    #79
    RetiredTundraBC
    San Diego County
    2020 Cement Tundra
    Do you really have to add a diode or booster if the truck came with the larger alternator with the tow package?
    Leo's first likes this.
  20. Jan 31, 2023 at 11:06 AM
    #80
    NewImprovedRon
    Ron
    NW Arkansas
    I have a NorthStar AGM battery and connect it to a trickle charger about once a month. Takes maybe 15 seconds to plug it in. That's fairly maintenance-free in my estimation. My post pertained primarily to not having to add fluid since the AGM is sealed.
  21. Jan 31, 2023 at 11:53 AM
    #81
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    You’re using the ALT-S circuit to trick the alternator into outputting a higher voltage. I think the standard electrical system gets like 13.4v or something. The size of the alternator shouldn’t matter when it comes to the actual volts the system calls for.
  22. Jan 31, 2023 at 12:43 PM
    #82
    RetiredTundraBC
    San Diego County
    2020 Cement Tundra
    So I threw a meter on my battery after sitting almost 24 hours and it was showing 12.4v and when I started it it jumps to 14.1v with the truck running. That seams like plenty of volts being thrown at the battery. IDK I'm no expert in electricity or batteries.
  23. Feb 2, 2023 at 12:29 PM
    #83
    brandostundra
    brandostundra New Member
    I go with the costco battery , just because they are the easiest to deal with in case there is a problem. They know how to treat their customers
    Correct me if im wrong, but I believe all (or most) car batteries are made by just 1 or 2 companies. One is Johnson controls I forget if there is another company.
    So in most cases the only difference between 15 different brand name batteries is the colorful sticker and brand name they put on the outside.
    And when youre buying one that has a 60 month warranty compared to one with a 36 month warranty , chances are its the same exact battery , and youre just paying the extra price for the extended warranty and possibly a different looking sticker on the outside.
    There may be a few exceptions , but if you research, the information is out there.
  24. Apr 28, 2025 at 3:41 PM
    #84
    dadtrucklife
    dadtrucklife New Member
    2021 SR5 TRDOR 4x4 (Army Green)
    The consensus seems to be 27F but why do all the battery websites including Toyota’s state 24F? Which is it? Cold cranking stuttered this morning and my battery is 4 years old/ 36k odo so I think it’s time for replacement.
  25. Apr 28, 2025 at 4:13 PM
    #85
    NewImprovedRon
    Ron
    NW Arkansas
    I recently replaced my NorthStar 27F AGM with a 24F AGM just because of the weight difference. Got tired of having to wrestle a 70 lb. battery out of and into my truck.
  26. May 1, 2025 at 9:25 PM
    #86
    hi_rawb
    hi_rawb New Member
    rob
    Bay Area
    2018 CM TRD SPORT 4x4
    2018 Trd Sport
    I had mine for about 6 years now and still going strong..
  27. May 2, 2025 at 7:01 AM
    #87
    plinkn
    plinkn New Member
    2025 TRD Limited Mag Grey
    I’ve always found Deka to be the best if you can find them in your area.
  28. May 2, 2025 at 7:08 AM
    #88
    ChesterTundra
    ChesterTundra New Member
    Central FL
    2020 Tundra SR5
    RCI Alum skids w/cat guards Leveled and AT Cooled SPD Performance exhaust Amsoil everywhere…
  29. May 3, 2025 at 4:28 AM
    #89
    Elevatorguy
    Elevatorguy Yotas and JD Green!
    James
    05 DC, 4.7, 4wd, LSD.
    Are you constantly removing and installing it for some reason?
  30. May 3, 2025 at 10:48 AM
    #90
    NewImprovedRon
    Ron
    NW Arkansas
    No, at the age of 74 years and 8 months, once is enough for an almost 70 lb. battery for me.
