Best Mods for 2010 Double Cab?
Discussion in '2nd Gen Tundras (2007-2013)' started by HunterDonahue, May 20, 2019.
  1. May 20, 2019 at 11:17 AM
    HunterDonahue
    HunterDonahue [OP] New Member
    It is very likely that I will be getting a 2010 Double Cab SR5 in the next three months. I was wondering what mods you would recommend doing, preferably not thousands of dollars? I can post more info if needed. I will replace the radio and add a backup camera so if you have any recommendations, I would love to hear about those too.
  2. May 20, 2019 at 11:34 AM
    Tundra234 Mods, mods, and more mods
    The Mods tab up top will fill your brain with ideas. :spending:
    Tundyfundy likes this.
  3. May 20, 2019 at 12:08 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
  4. May 20, 2019 at 12:12 PM
    TheBeast The Beach
  5. May 20, 2019 at 12:18 PM
    Trooper2
    JR
    Pretty good in my opinion, pic with video on Pioneer NEX-8100 HU. Great in daylight hours, grey at night (Fairly common). Considering more reverse lighting for low light. Pic probably poorer than actual.
    TheBeast likes this.
  6. May 20, 2019 at 12:32 PM
    TheBeast The Beach
    not bad at all. I might get it. thanks
  7. May 20, 2019 at 12:33 PM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    1220181607.jpg 1220181604a.jpg 1220181604.jpg I bought a Auto-Vox M1 a few years ago and it's been really great. At that time it was $ 49.95 shipped. Pic is "washed-out" because of my phone flash but it's crystal clear. It has a "Guide Line Remove" button and picture settings adjustments. Bottom pic is where the camera mounts.
    fairclothr1, Kn4x2 and Trooper2 like this.
  8. Jun 3, 2019 at 3:07 PM
    Kn4x2
    Kn4x2 Common sense is not so common!
    3rd rock from the sun
    2010 DC 2WD
    Afe Pro Dry filter Tinted windows Coverking seat covers Traxion tailgate ladder Auto vox M1 backup camera
    CMB
    How did you run the wiring for your camera to monitor (under the bed and thru floor board drain maybe?)
    Thanks
  9. Jun 3, 2019 at 4:23 PM
    I have the Pioneer 5201 in mine. How would I wire the factory camera to it?
  10. Jun 3, 2019 at 4:36 PM
    Trooper2
    JR
    Disconnect RCA plug at screen, guessing mirror, reroute cable to HU and plug in RCA plug at HU. Guessing RCA plugs are same, may not be. Also have heard there are different voltage cameras, OEM vs. aftermarket that may have to be addessed.
    Not an expert, things I have read. Had an install shop install mine.
    Should be doable
  11. Jun 3, 2019 at 5:21 PM
    nuclearlemon
    nuclearlemon New Member
    wyoming
    2012 dc
    free mods are the best. the rear folding seat mod is awesome and only takes some time.
    Trooper2 likes this.
  12. Jun 3, 2019 at 7:50 PM
    rnicholls
    rnicholls New Member
    2010 Crewmax SR5
    I too would like to know.
  13. Jun 4, 2019 at 1:42 AM
    CMB
    CMB New Member
    Cecil County MD.
    Hey Kevin and rnicholls, wiring was so simple, even I could do it:eek: Power is gained from inside the Tail light housing. Just Tap into the reverse circuit after running the wire under your truck. Wire is easily tucked down along the bottom corner of the dash and inside weather strip running down along the door. When you guys get it 'in-hand',it'll be clearer. Any more questions/concerns, I'll be around, just ask:thumbsup:
  14. Jun 4, 2019 at 5:49 AM
    rnicholls
    2010 Crewmax SR5
    So.. Tailgate > passenger tail > under truck > cab? I read somewhere to come up under the passenger seat.
  15. Jun 4, 2019 at 8:39 AM
    CMB
    CMB New Member
    Cecil County MD.
    I went the shortest route into the Driver's side tail light. Pretty straight shot from where my screen is mounted. Getting down through to the underside just took some lookin' and probin' but access was more direct than I thought. From there, it's a straight shot to the power source.
  16. Jun 4, 2019 at 8:49 AM
    Kn4x2
    2010 DC 2WD
    Thank you
  17. Jun 4, 2019 at 9:34 AM
    fairclothr1
    fairclothr1 Here and There Member
    Ryan
    2009 Sand Mica Tundra TRD
    Plasti Dipped grill and badges. Shorty antenna.
    I have the Auto-Vox as well, and went the passenger's footwell route. There's a plug you can pop out and put the cable through. There was just enough to get from the driver's side dash to the rear passenger's light. As stated earlier though, it's pretty intuitive once you get going.
    Cheers!
  18. Jun 5, 2019 at 6:04 AM
    Dr_Al
    Dr_Al New Member
    Al
    Under the rear seats are a couple of rubber plugs. I made a small hole in one and ran the wires up through. Since it's rubber the small hole stretched for the wire to go through and self sealed.
