Best Looking Tires for 2022 Tundras
Discussion in '3rd Gen Tundras (2022+)' started by Bman95, Mar 14, 2022.
  1. Mar 18, 2022 at 11:03 PM
    #61
    theripper
    theripper New Member
    Oregon
    2022 MGM Tundra Platinum
    I’m loving the Falken Wildpeaks AT3/W they look mean and ride surprisingly well. These are 295/70r18, will probably go narrower next time. Slight rub, fixed with zip ties.
  2. Mar 19, 2022 at 3:24 AM
    #62
    dekeman
    dekeman New Member
    Derek
    Ottawa, ON, CANADA
    2022 Tundra Limted TRD
    Looks fantastic.
  3. Mar 19, 2022 at 5:38 AM
    #63
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    These look good…might I ask where was the rub happening?
  4. Mar 19, 2022 at 6:58 AM
    #64
    theripper
    Oregon
    The felt liner at the back of both front wheel wells, only at full lock. It took about one minute per side to fix. Drilled a hole through the felt, fed a zip tie through the felt into a metal hole in the wheel well, tightened while pushing up and voila.
    Edit: Wheels are the battleborns with +18 offset which really helped these tires fit.
    bigjuice[QUOTED] likes this.
  5. Mar 19, 2022 at 6:59 AM
    #65
    bigjuice
    WA State
    2024 Terra TRD Pro
    Ok thanks.
  6. Mar 19, 2022 at 7:04 AM
    #66
    tundratoofun
    tundratoofun Yall better rednekonize
    Glendale
    Beast
    I ignored this because I thought you were asking about the look of the tread pattern and I was like "wtf does that matter as long as they grip"
    Your asking about size, that matters and in my opinion, bigger is better. Go with the biggest tire you can fit!!
  7. Mar 19, 2022 at 9:58 AM
    #67
    ToyoTundra89
    ToyoTundra89 Member
    Seattle, WA
    2022 Tundra SR5 TRD OR CM 6.5
    Very nice! Is this on stock suspension? Love the Crewmax & 6.5 bed. Looks amazing.. almost like a HD/Superduty
    theripper[QUOTED] likes this.
  8. Mar 19, 2022 at 1:00 PM
    #68
    theripper
    Oregon
    It is, I thought I’d have to lift it to clear but I’m actually really happy with it the way it sits right now.
    ToyoTundra89[QUOTED] likes this.
  9. Mar 19, 2022 at 2:46 PM
    #69
    Krusher22plat
    Krusher22plat New Member
    22plat
    Nice!! Where did you grab those lugs from?
  10. Mar 19, 2022 at 6:46 PM
    #70
    theripper
    Oregon
  11. Mar 19, 2022 at 7:32 PM
    #71
    Buellride
    Buellride New Member
    Olympia
    THE BOULDER
    BD Lights, Banks PM, Fuel Vector 18" on 295/70R18 Cooper AT3 XLTs, Black-Out badges, TRD front grill
    Nice looking truck! I was thinking the same tire size but concerned with rubbing...could you post a slight better close of your front wheel well? I am wondering if I should wait for a lift and then go that big or what was the slightly smaller size you were thinking?
  12. Mar 19, 2022 at 9:02 PM
    #72
    Stormtrooper22Tundra
    Stormtrooper22Tundra New Member
    22Tundra
  13. Mar 19, 2022 at 9:25 PM
    #73
    Buellride
    Olympia
    THE BOULDER
    Very nice what sized KO2s?
  14. Mar 19, 2022 at 9:27 PM
    #74
    22Tundra
    Thanks man.
    275/70R18 = 33.2 inches
  15. Mar 20, 2022 at 4:33 AM
    #75
    bigjuice
    WA State
    2024 Terra TRD Pro
    Probably 285/75/18 for a taller/narrower tire or maybe down to 275/70/18…which have really good prices and looks good on @Stormtrooper22Tundra truck
    Outbound likes this.
  16. Mar 20, 2022 at 11:54 AM
    #76
    theripper
    Oregon
    Thanks man! I’m out of town but will snap some when I get back home on Tuesday. I’d probably go 285/70r18 mainly for the weight savings. The tires I have are really heavy @ 69 lbs.
    Cheers
  17. Mar 20, 2022 at 12:02 PM
    #77
    Buellride
    Olympia
    THE BOULDER
    No worries...285/70R70s are hard to find unless they are MTs...the ones that are all terrain are $$$...
  18. Mar 20, 2022 at 12:15 PM
    #78
    theripper
    Oregon
    Then I guess I’m stuck with these!!! I love them though
  19. Mar 20, 2022 at 12:45 PM
    #79
    Buellride
    Olympia
    THE BOULDER
    Regardless you have a very good looking Tundra sir!
  20. Mar 20, 2022 at 4:01 PM
    #80
    Krusher22plat
    22plat
  21. Mar 20, 2022 at 5:13 PM
    #81
    ThePolak
    ThePolak 2022 Platinum hunt/tow/haul/family ride on order!
    The Land of the Cobra Chicken
    Thanks for everyone’s input. I’m a tire and wheel noob so this was super helpful. After reading reviews, articles, and some videos of after 1 year reviews, I’m going to be going with the Toyo Open Country AT3 in either the 275/65r20 (34.1” and 55lbs) or the 295/60r20 (33.9” and 60lbs).
    These will be going on stock platinum wheels without a lift. From everything I read there shouldn’t be any run issue. I eventually may do the Toyota lift when it comes in in the summer, but for now this will do just fine.
    I live in Canada where we get solid 4 -season weather and in the winter, the snow piles up, so does anyone have any thoughts on 275 vs 295 considering the above?
  22. Mar 21, 2022 at 12:04 PM
    #82
    gmcguire7220
    gmcguire7220 New Member
    Ontario Canada
    2022 Limited TRD OR Crewmax - WCP- 2019 Toyota RAV4 Hybrid XSE
    TRD running boards & Bridgestone Dueller Ascent tires
    It’s only a 2cm difference in width so I think the difference will be marginal. Think like snowshoes - skinny (275) smaller surface area (contact patch) is more likely to sink through the snow to the road surface vs the wider (295) tire.
    But I think the weight of the trucks and the small difference in contact patch size it won’t matter too much. Tread design & rubber make up is as, if not more important depending on if you will be driving on packed snow, icy roads vs deep powder.
  23. Mar 21, 2022 at 1:22 PM
    #83
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
  24. Mar 28, 2022 at 11:42 PM
    #84
    Mrconnsmythe
    Mrconnsmythe New Member
    Saskatchewan, Canada
    2025 Tundra Ltd TRD OR WCP
    Full body wrap, crazy.
    Wonder what that costs?
    Looks wicked though. Interesting with the +18 offset wheels that it rubbed. So that tire [295/70R18] would not rub on stock OEM's? Thought I read above one said theirs did not rub and one that did?
  25. Mar 29, 2022 at 6:15 AM
    #85
    osu1978
    osu1978 New Member
    Near the end of the video he said they were +1 offset.
  26. Mar 29, 2022 at 6:20 AM
    #86
    Breathing Borla
    AZ
    this looks great, good balance, not too small and not stuffed.
    are those load E?
  27. Mar 29, 2022 at 6:41 AM
    #87
    Krusher22plat
    22plat
    They are one of the lightest LT E available (I think 52lb). Originally the Pirelli 275/65’s ordered that are standard on Rivian but delivery kept getting pushed back and aren’t a huge difference in weight. Better pics:
    Jorts and WingedHussar like this.
  28. Mar 29, 2022 at 6:48 AM
    #88
    Breathing Borla
    AZ
    ya, that looks great.
    how much weight over stock is that set-up? not sure what a stock platinum 20" tire weighs
  29. Mar 29, 2022 at 9:14 AM
    #89
    Krusher22plat
    22plat
    Really not sure but faintly remember the OEM 265’s at 44 pounds? Won’t bet the farm on it but beleive 42 or 44.
    I really have noticed negligible mileag difference, very quiet, no hum and ride is good. Tighter but kinda like the way it does not wallow as much as when on the pure road tire.
  30. Mar 29, 2022 at 10:21 AM
    #90
    osu1978
    osu1978 New Member
    Anyone throw a set of 285/75r18's on yet?
    Mrconnsmythe and Outbound like this.
