Best LED bulbs for 2010 tundra
Discussion in '2nd Gen Tundras (2007-2013)' started by Doepatrol406, Dec 8, 2019.
  1. Dec 8, 2019 at 4:10 PM
    Doepatrol406
    Doepatrol406 [OP] New Member
    Kyle
    2010 tundra double cab sr5
    I am looking to replace my low beam and high beam bulbs in my 2010 tundra. Any input? I dont want to spend a ton of money
  2. Dec 8, 2019 at 4:25 PM
    SouthWestGA
    SouthWestGA New Member
    Doepatrol406[OP] likes this.
  3. Dec 8, 2019 at 9:39 PM
    avt007
    avt007 New Member
    Rob
    2010 Silver Tundra Double Cab
  4. Dec 9, 2019 at 4:27 AM
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
    Deuxlatch likes this.
  5. Dec 9, 2019 at 4:29 AM
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    Second on the Auxbeam. They are great and affordable.
    Doepatrol406[OP] and Vr0ck like this.
  6. Dec 9, 2019 at 4:38 AM
    Deuxlatch
    Deuxlatch AirBus
    Chris (Latch)
    Tomball, Tx./Lafayette, La.
    2010 Super White Tundra CM
    TRD Supercharger, TRD Big Brake kit, MotoMetal wheels, Undercover Tonneau with dual swing out saddle bag tool boxes.
  7. Dec 10, 2019 at 9:18 PM
    Doepatrol406
    Kyle
    Does that have the high beam bulbs and low beam bulbs? Or is it just two high or low beam bulbs per package
  8. Dec 10, 2019 at 9:47 PM
    bensky
    bensky PlatinumPro
    Ben
    Utah
    2018 Red Platinum Tundra
    Hands down VLEDS. Best quality and great customer service.
  9. Dec 11, 2019 at 4:26 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Anyone have a wall shot with the Auxbeams?
  10. Dec 11, 2019 at 5:07 AM
    dsotm
    dsotm New Member
    2016 SR5 Crewmax 4x4
  11. Dec 11, 2019 at 5:15 AM
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    Yes. This is the only photo I have. Still have to do the fogs.
  12. Dec 11, 2019 at 5:31 AM
    sundance
    sundance New Member
    BEAMTECH.
  13. Dec 11, 2019 at 8:58 AM
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Definitely brighter than stock. Ended up having to adjust headlights down a bit to not blind others.
  14. Dec 11, 2019 at 10:38 AM
    Vleds!!
  15. Dec 11, 2019 at 11:17 AM
    TheBeast The Beach
    VLEDS !
  16. Dec 11, 2019 at 7:03 PM
    KingKong
    KingKong New Member
    Asher
    2008 Super White Double Cab Long Bed 4x4
    I've got the V.4s from @Headlight Revolution. Super bright with great cut off and hot spots in factory housings.
  17. Dec 12, 2019 at 5:24 AM
    Headlight Revolution New Member Vendor
    Atlanta, GA
  18. Jan 11, 2020 at 2:27 PM
    TundraMax12
    TundraMax12 New Member
    Dom
    2013 TSS Crewmax
  19. Jan 14, 2020 at 5:17 AM
    TundraMax12
    Dom
    2013 TSS Crewmax
    For those that went with the Auxbeam LEDs, anyone find it difficult to install into the factory headlight housing. Mine seemed to be excessively tight and they didn't want to turn into place. Not sure what I could be missing here? Suggestions? I would assume they should just turn into place as the factory replacement bulbs do.
  20. Jan 14, 2020 at 5:21 AM
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    I didn't have any problems. Look through the thread in the link below. There are some good lessons learned and even a video.
    https://www.tundras.com/threads/led-lightbulbs-opinions-advice.41411/
  21. Mar 5, 2021 at 9:12 PM
    ScooterDobs
    ScooterDobs New Member
    Scott
    2013 SR5
    I just bought and installed the AuxBeam S1 9005's into my 2013 DC. I found the same thing, that they were really tight when installing. I had to push pretty hard to get them in enough to turn. After a week, one of the bulbs fell out of the light. Two of the three locking wings broke off. The second one was tight as well but not broken. Fortunately I saved the old bulbs. The blue rubber seal that AuxBeam uses is thicker and firmer than what was on the old bulbs. I took the seal off the original bulb and put it on the AuxBeam and it locked in with "normal" force.
    I contacted AuxBeam for replacement and they replied right away. The locking piece is removable so I assume they will be sending me a new locking piece. I will reuse the seal from the original bulb when I install the second bulb.
