Best fuel additive
Discussion in 'Performance and Tuning' started by ScottB1973, Dec 17, 2024.
  1. Dec 18, 2024 at 12:43 PM
    Tundra family
    Tundra family New Member
    I heard it from my grandpa and it just kinda stuck with me.
  2. Dec 18, 2024 at 12:58 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    A six pack for the driver of a 2017 crewmax is the best additive. Highly recommend!
  3. Dec 18, 2024 at 1:03 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    173,000 miles on mine, so far, without a single drop of fuel additive. Still runs as smooth as on day one.
    Over 1/2 a million miles between two daughters’ 2010 Priuses without any additives. We’ve owned both cars since new.
    70,000 miles on the wife’s VW. Same.
    Too many cars to list that haven’t ever had an additive in the fuel tanks. No issues. No loss of performance, and no appreciable loss of efficiency. Keep clean oil in them and roll.
    Id bet we have close to 2,000,000 miles driven in my household, and have had exactly zero engine failures. None.
    You don’t need fuel additives. You don’t need oil additives. Regular maintenance.
    AZBoatHauler and nobodyintexas like this.
  4. Dec 18, 2024 at 1:07 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    Most additives, if not all, are worthless
    maybe the direct injection folks might need it
    With that said: I add a bottle of Techron to the tank that I use before the next oil change
    why?
    dunno
    And i use top tier Costco gas
    it’s a high volume station so you know the gas is fresh
  5. Dec 18, 2024 at 1:21 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    The car care nut has some sound advice on this topic. Refuel from the same station as often as possible and if not that station the same company. Always buy from a station that sells top tier fuel. He goes on to say don't shop for the cheapest gas around town. And if you use the same oil time after time why wouldn't you use the same fuel? No additives are necessary.https://m.youtube.com/watch?v=1OFV8gpxAxI
    AstroDude and nobodyintexas like this.
  6. Jan 6, 2025 at 8:17 AM
    308Plinker
    308Plinker New Member
    Patrick
    Tennessee
    18 SR5 Cement in Black Trim
    3" lift and 35" tires, Borla Cat Back Pro XS exhaust
    I agree with the majority of comments. If you’re driving daily, I doubt you’ll see benefits. If I do use a pour in fuel product, it’s BG’s 44k.
    I cleaned my throttle plate within days of taking ownership of my 18 SR5. It was filthy, and I’ll continue to do so at least bi annually. A filthy throttle plate/body will cause the learned idle value to change gradually over time. Best to use a mild detergent that evaporates or a product made to clean throttle bodies. Nitrile gloves and elbow grease is my preferred method. Pop n pour products are poorly regulated in the US. Buyer beware is the order of the day.
  7. Jan 6, 2025 at 8:32 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    The few throttle bodies I've cleaned, they are very sharp and have so much spring power that they could slice my finger easily. They all appeared dirty, but not where the blade moves. Also the blade is positioned slightly open for the fail safe mode, so engine would still be able to breath and idle. When ECU powers up, it does the throttle check from zero to full throttle, so the blade scrapes the tiny bit that may have been accumulated there between fail safe angle and zero in the previous engine run.
    tl;dr: I don't clean them anymore :)
    nobodyintexas likes this.
  8. Jan 6, 2025 at 9:39 AM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    I’ve been using Royal Purple Max Clean. Nothing else I’ve ever used works like this. Check out their reviews
