Best Fender Flares for 2017 Tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by co17tundra, Jan 21, 2021.
  1. May 23, 2021 at 4:57 AM
    #91
    18" TRD Off Road Wheels
    I don't have flares, so my opinion is only based on my readings and research, but if flares are being added it is usually because the wheels have a lower offset than factory. This pokes the wheels out, and the factory mudflaps aren't really effective at that point. This I do know, because I have aftermarket wheels with a +25 offset wheel, and the factory mudflaps provide minimal protection from mud and/or stones.
    Booney likes this.
  2. May 23, 2021 at 7:06 AM
    #92
    70 FJ40
    70 FJ40 New Member
    Max
    '16 Tundra SR5 TRD 4X4 Double Cab
    I had to remove my mud flaps to put on the fender flares. No great loss in my opinion.
  3. May 29, 2021 at 8:18 AM
    #93
    Pillslinger
    Pillslinger New Member
    Rollin
    SWMO
    2018 Cement TRD CrewMax
    Bed light kit Jerry can mount Badge overlays (removed 2021) Pin stripe / TRD decal / pillar vinyl removal Raised tailgate lettering Center console badge/tray/divider Interior/exterior LED upgrade VLED footwells TVD Vinyl TRD Offroad wheels Icon 17x8 rebound titanium Bubbas Garage grab handles WeatherTech floor mats (Eagle Klaw added) Rough country front shackles (removed 2021) DD SS3 yellow fogs MESO map light replacement Softopper MESO Chrome delete
    I put these on a few weeks ago. Really like the simple lines. Gave me just enough coverage. Installation was a bit touchy but not difficult. And yes, I got ppf down first :)
  4. May 29, 2021 at 9:58 AM
    #94
    paulbk
    paulbk New Member
    Did you use any additional fender flare trim like @70 FJ40? Or is just what was included with the flares? Also what ppf did u end of using??
  5. May 29, 2021 at 10:09 AM
    #95
    Pillslinger
    Rollin
    SWMO
    The included rubber trim was sufficient for my installation. I found that if I over tightened some of the mounting screws the flares would buckle and pull away from the body. So I literally went through and tightened all the screws while watching my gaps the whole time. As for the ppf this was plenty
    https://www.amazon.com/dp/B076CWZWX2&extra=relprodfromurl
    If you can find a smaller roll I think I only ended up using about 30 feet or so. If not you'll have plenty left over to do your door edges.
  6. May 31, 2021 at 8:58 PM
    #96
    junior
    junior Member
    Zach
    Santa Cruz, CA
    2016 Tundra TRD Off Road
    Black Rhino Rapid 17" 35x12.5 Mickey Thompson Baja Boss Fox Performance Elite 2.5 DSC at 3" with Coachbuilder 1/4" shim on driver side JBA UCAs Fox Performance Elite 2.5 DSC rear shocks Dobinsons HD Leaf Springs Firestone Airbags + Daystar Cradles Prinsu Cab Rack 2024 Four Wheel Camper Project M Camper Mods: Goal Zero Yeti 4000 house battery 200w solar IceCo fridge Truma Propane Heater
    Looks great! :thumbsup:
  7. May 31, 2021 at 11:51 PM
    #97
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    2020 Tundra Limited TRD Off-Road
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    Yeah, I have +25 wheels as well. I just don't know if one would provide more coverage than the other. I just spent hours washing my truck today after a 6 hour trail ride yesterday and when I got home from the car wash I already had splatter on the side from just pulling out of the freaking car wash. I don't know if flares would help any more than the mudflaps, which apparently don't do anything. Maybe some of those RokBlokz flaps or something a little wider than the stock ones. Or maybe I just deal with it until I get out of the land of perpetual rain and back to SoCal where it won't matter as much.
  8. Jun 1, 2021 at 1:59 AM
    #98
    Tires will kick up more than just wet stuff. Rocks, dirt, sand, etc. I think flares, if wider than the tires, will be the most protection from tire sling. It's basically like going back to factory settings with the wheels/tires fully inside the wheel well.
    Again, just my opinion.
  9. Jun 3, 2021 at 2:52 PM
    #99
    iamsmokey
    iamsmokey Smokey the Tundra
    Oahu, HI
    2018 Cement SR5 Off-Road 4x4 Crewmax
    Hey if it isn't too much trouble, Would you be able to take a picture so I could see how far the tires stick out past these flares? AWESOME TRUCK!!!!!
    junior[QUOTED] likes this.
  10. Jun 4, 2021 at 12:09 PM
    #100
    junior
    junior Member
    Zach
    Santa Cruz, CA
    Hopefully this helps ya, my driveway is sloped so the rear tire is a bit angled upward. Wheels are Black Rhino Grange +12 offset with 295/70/18 ridge grapplers
    iamsmokey[QUOTED] and TunBrun like this.
  11. Jul 14, 2021 at 6:45 PM
    #101
    paulbk
    paulbk New Member
    I finally got my skinny flares installed!
    I purchased them for $150 shipped from eBay!
    Fitment was not perfect, but the use of washers underneath the mounting screws helped “fill-in” some the gaps caused while tightening.
    The flares and rubber trim that were included are sitting flush against my fenders and I’m am pleased with the results.
    good luck to those considering installing these!
  12. Jul 14, 2021 at 8:18 PM
    #102
    junior
    junior Member
    Zach
    Santa Cruz, CA
    Looks great to me :thumbsup:Washers with the screws is a great idea! I noticed they drive in too far on some when I did mine and it would very slightly cause a gap like you mentioned
  13. Apr 29, 2022 at 7:49 AM
    #103
    Ekelleyco
    Ekelleyco New Member
    CT
    2014 blue tundra SR5
    Has anyone painted these flares? I really like the sleek look. Based on the reviews I’m going to order and test fit to make sure I can get them snug, then pull them and get them painted somewhere. Hopefully……
    Anyone tried this?
  14. Apr 29, 2022 at 9:08 AM
    #104
    junior
    junior Member
    Zach
    Santa Cruz, CA
    They aren't smooth and have a texture similar to the lower center of the front bumper, so that would potentially make painting more difficult.
  15. Apr 29, 2022 at 9:29 AM
    #105
    What about color matched Line-X?
  16. Apr 29, 2022 at 12:48 PM
    #106
    Ekelleyco
    CT
    ahh okay I see. I don’t plan on painting them myself. Is this something a shop would have trouble with? I (clearly) don’t know much about automotive painting.
  17. Apr 29, 2022 at 12:49 PM
    #107
    Ekelleyco
    CT
    line-x hmmm intriguing. I wouldn’t mind that considering they would likely take a pounding anyways with the new rims and tires
    Tundra234[QUOTED] likes this.
  18. Jul 21, 2022 at 9:59 PM
    #108
    SFTundra
    SFTundra New Member
    Jimmy
    I had a question, so you guys said to to ppf if you do fender flares. I’m abit confused on where do you ppf? Do you ppf the fender flares or the surrounding area?
    Also from the looks of previous discussion, the eBay extreme fender flares are basically eag right?
  19. Jul 22, 2022 at 12:36 AM
    #109
    You put the PPF where the flares upper edge will contact your paint. It's an ablative layer to prevent this.
  20. Jul 22, 2022 at 4:55 AM
    #110
    Pillslinger
    Rollin
    SWMO
    Yes, the ebay flares are basically the eag flares.
  21. Sep 6, 2023 at 9:23 PM
    #111
    Deeberz
    Deeberz New Member
    Dave
    2020 Limited CM Cement Gang
    Bilstein 6112/5100 on the 1.9” setting, sumo springs
    Hi mountainpete. The eBay link seems to be dead now, but I love the look of these flares. Do you remember if this was the same seller/flare? Sorry for the long link… newbie here and not sure how to shorten it.
    https://www.ebay.com/itm/233900508626?fits=Year%3A2020%7CEngine+-+Liter_Display%3A5.7L%7CTrim%3ATRD+Off-Road+Crew+Cab+Pickup+4-Door%7CModel%3ATundra%7CMake%3AToyota%7CSubmodel%3ATRD+Off-Road%7CEngine%3A5.7L+5663CC+345Cu.+In.+V8+GAS+DOHC+Naturally+Aspirated
  22. Sep 7, 2023 at 4:08 AM
    #112
    Pillslinger
    Rollin
    SWMO
    Same seller. Not the same flare. They were also made/sold by another company (name?) it was discussed earlier in this thread I'd have to look it up.
    Edit: I believe it was EAG
  23. Sep 7, 2023 at 10:17 AM
    #113
    Deeberz
    Deeberz New Member
    Dave
    Got it. I saw some EAG but a quick google search wasn't returning the look I saw. I think it's the EAG Styleline flare for a Tundra that I'm looking for. When I google with 'styleline' in there, it comes up with a Walmart link: https://www.walmart.com/ip/EAG-Fend...Styline-Series-Fit-for-14-20-Tundra/620247383
    Do those look like a match?
    Pillslinger[QUOTED] likes this.
  24. Sep 8, 2023 at 4:27 AM
    #114
    Pillslinger
    Rollin
    SWMO
    Those look right. Good find!
    Edit: 'out of stock' :( but you've got a product name at least.
  25. Jun 17, 2024 at 11:37 PM
    #115
    SpankyLarue
    SpankyLarue New Member
    Any one able to find these flares.Seems everyone out of stock.I scraped left rear and need to replace it. Can’t find any contact info for EAG either???
    Pillslinger likes this.
  26. Jun 18, 2024 at 4:38 AM
    #116
    Pillslinger
    Rollin
    SWMO
    Here is the Facebook page from the eBay seller that I bought mine from. They may be able to get you contact info for EAG.
    Ya, these things seem to have basically vanished.
  27. Jun 22, 2024 at 6:44 AM
    #117
    SpankyLarue
    Thanks Pillslinger.I’ll check it out and report back to viewers. I know several people are looking for them. Might have starting trading amongst are selfs.. haha.
  28. Jun 23, 2024 at 11:58 AM
    #118
    therealjonwick
    therealjonwick New Member
    JR
    2019 OR
    What flares are those?? Thanks!
  29. Jun 23, 2024 at 3:39 PM
    #119
    therealjonwick
    JR
    2019 OR
    Any way to find these flares anymore? Seems they do not exist.
