Best exhaust for nice deep tone without a lot of drone?
Discussion in 'Performance and Tuning' started by Hunter4x4, May 21, 2018.
  1. May 21, 2018 at 8:57 AM
    Hunter4x4
    Hunter4x4 [OP] New Member
    Hunter
    2017 Tundra SR5 Double Cab
    What would be the best exhaust for my 2017 Tundra double cab 5.7L 4x4? Don’t want it to loud but want it to be louder than stock. Also I would really like duals coming straight out of the rear. But not opposed to other options within price range! What all do you guys have? And what prices? Cat back? Or what?
  2. May 21, 2018 at 9:07 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    blizz86, AKJ78, 1UPPER and 7 others like this.
  3. May 21, 2018 at 9:12 AM
    15whtrd
    15whtrd Mr. Blonde
    MIM and Hunter4x4[OP] like this.
  4. May 21, 2018 at 9:42 AM
    the07tundra
    the07tundra New Member
    Cannon
    2007 White Tundra
    35" Toyo A/T tires, Black Rhino Gunmetal wheels, 2" bilstein lift kit and 2" ready lift leveling kit, recon headlights, leer canopy, custom 3" piping with 40 series flow master muffler.
    I did a fully custom magnaflow 40 series cat back for $400 dual straight out the rear. No drone. Pretty loud though.
    Hunter4x4[OP] likes this.
  5. May 21, 2018 at 9:57 AM
    FossilHunter
    FossilHunter New Member
    2017 Tundra TRD 4x4 Double Cab
    Maybe a dumb question, but does anyone simply swap out louder sounding mufflers instead of replacing the entire system?
    mudslinger79 likes this.
  6. May 21, 2018 at 10:00 AM
    Garvin74
    Garvin74 New Member
    2017 Tundra CM SR5
    I have the bamufflers budget bolt on system. Un bolt the stock muffler bolt up the bamuffler. 30 minutes and your done. Uses stock tail pipe so no dual exhuast. Sounds awesome. Barely louder then stock when cruising, not really pushing the pedal. Once you give her some gas she comes alive. No drone with the resonator installed. Call Keith at dirty deeds. Custom made exhuast designed for tundras.
  7. May 21, 2018 at 10:06 AM
    15whtrd
    15whtrd Mr. Blonde
    It’s not a dumb question, plenty of guys just cut out the old muffler and have a different muffler welded up. Much cheaper but kind of hit and miss unless you talk to someone with that specific muffler, to know hoe it’s going to sound. If it drones maybe you could buy the resonator off of Keith to make your own custom system. I just went ahead and spent the coin on the BAMmuffler 6 inch. I couldn’t be happier.
    LKROOZR and Hunter4x4[OP] like this.
  8. May 21, 2018 at 10:37 AM
    RickC
    RickC NOT a new member
    Rick
    Knoxville TN
    2017 CrewMax Platinum 4x4 5.7
    SCS Wheels, Line-X, WeatherTech, UnderCover Flex bed cover
    I did Magnaflow cat back with duals that exit behind the rear tires. No drone, and relatively quiet until you get on it.
    Les7311 and Hunter4x4[OP] like this.
  9. May 21, 2018 at 10:44 AM
    wwinslett
    wwinslett New Member
    Will
    Birmingham AL
    2016 Tundra CM Magnetic Grey
    6112's Toytec Shackles Method NV on Ridge Grapplers 295/70/18
    Did some looking on the website the other day, can you drop a link to this kit?
  10. May 21, 2018 at 11:47 AM
    Rica25
    Ricardo
    Tulare
    I have the 8 inch from Ba/ Dirty deeds and could not be happier
  11. May 21, 2018 at 11:48 AM
    Hunter4x4
    Hunter
    Same here would really appreciate some links
  12. May 21, 2018 at 11:49 AM
    Hunter4x4
    Hunter
    How much was this system? Any pics of it?
  13. May 21, 2018 at 11:50 AM
    Hunter4x4
    Hunter
    Was thinking of doing the same. But just Incase it’s to loud I would like to be able to bolt back on my stock system.
  14. May 21, 2018 at 11:50 AM
    mudslinger79
    mudslinger79 New Member
    Christopher
    Williamsburg, Va
    2006 Double Cab, Phantom Grey Pearl
    Leveled. 16x8 Pacer 164 wrapped in 295-75-16 General AT2. Flowmaster exhaust. K&N Cold air intake.
    I just put a single in/single out 40 series Flowmaster on my first gen Tundra. Sounds great!!
  15. May 21, 2018 at 11:53 AM
    Hunter4x4
    Hunter
    How do you like it? That’s kinda the route I guess I’m looking to take.
  16. May 21, 2018 at 11:54 AM
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    Well, I heard BAMufflers is great. However I did not use them, I had a friend cut out the muffler and install dual straight pipes (2.5 inch). It is not quiet and there is lots of drone. I have had it like this for maybe a year now and have grown tired of everyone jerking their head to see "WTH is going on" when my truck is started. I think I am going to get a Flowmaster 40 dual in/dual out welded in.
  17. May 21, 2018 at 11:56 AM
    Hunter4x4
    Hunter
    How much is that flowmaster?
  18. May 21, 2018 at 12:08 PM
    Hunter4x4
    Hunter
    What about the flowmaster 44 series? Any experience with this?
  19. May 21, 2018 at 12:50 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
  20. May 21, 2018 at 1:18 PM
    Tundrastu
    Tundrastu New Member
    Stuart
    Kentucky
    2016 Tundra Platinum Crewmax
    HID retrofit headlights from Lightwerkz, Morimoto LED fog lamps from Lightwerkz. JL audio upgrade from Tech12Volts, Powdercoated factory black wheels local, ESP rear storage trays under seat, bed cover by BakFlip, bed liner, console safe, LED light bar by Back Country. Weathertech floor liners and ventshades. TRD rear sway bar. TRD Pro exhaust, TRD Skid plate, Fortin EvoOne Remote start from Anderson Electronics.
    I bought into the TRD performance exhaust. I watched some videos and reviews and decided to order it. Bolts right up to factory and includes all the hardware needed. Can install in an hour or two max, faster if you have a lift.
    I am an old man now, and don't want to light up the neighborhood as i drive through, I just wanted something a little beefier in the sound department while keeping things as stock as possible.
    These don't come out the back they exit out of each side, but the sound increase was noticeable immediately. I get comments alot about it sounding pretty good without being too loud.
    A little pricey in my opinion, especially when compared to other aftermarket options, but it works. I'm happy I guess that's all that matters.
    4Runner likes this.
  21. May 21, 2018 at 3:10 PM
    Triton19X2
    Triton19X2 New Member
    2021 Silver 1794 Crewmax 4X4
    My CM '07 came from the factory with Borla that exited out the back and I loved the sound when you got on it but not much noise down the hwy. If I ever decide to put duels on I will at least look at Borla again
  22. May 21, 2018 at 3:27 PM
    Hunter4x4
    Hunter
    Yeah my son has a Scion tC and his buddy spend $650 on TRD exhaust and my sons cheap Catback sounded better and was $300 dollars cheaper. Which in no way is close to a tundra but still I won’t buy TRD for the price of them unfortunately.
    I talked to my local muffler shop they said that with what I’m looking for a Flow Master 44 series would be perfect. Nice growl without drone and duals straight out the back. My options are open though! I appreciate the input everyone is giving for sure!!
  23. May 21, 2018 at 3:34 PM
    Erichudgins
    Erichudgins New Member
    Eric
    Murfreesboro, TN
    2017 Super white Limited DC
    https://www.tundras.com/threads/the-un-limited-build.25949/
    I bought the afe cat back and its exactly that. Deep and mellow. No drone no rasp. Just smooth. It is single exit but totally worth the money. Even got free shipping.
  24. May 21, 2018 at 4:13 PM
    TRDPROSean
    TRDPROSean New Member
    Hattiesburg, MS
    2017 CM TRD PRO
    275/70r18 Nitto Ridge Grapplers, TRD rear bar and intake, Coachbuilder +2 shackles, Corsa 14916 exhaust, UWS lo pro toolbox, Craven Speed stubby, tint
    I love my Corsa. Absolutely zero drone while driving at any speed.
    blizz86 likes this.
  25. May 21, 2018 at 4:25 PM
    ToyotaTundraMike
    2015 Tundra
    BAMuffler 7” here, couldn’t be happier.
    LKROOZR likes this.
  26. May 21, 2018 at 4:41 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    My buddy has a Ba muffler on his tundra and it sounds better my flowmaster imo
  27. May 21, 2018 at 5:07 PM
    Diverguy
    Diverguy Breathes under water
    Leon
    PA, USA
    2018 Tundra Limited TRD Offroad-Inferno
    Windows tinted, window visors. Bedrug, led bedlights, Nfab nerf step bars, Lund toneau cover, Evo One remote start, BAMufflers 8"
    BAmufflers 8" system....now that my windows are down, I love it even more! No drone at all at highway speed. Really roars a nice throaty tone when your right foot goes down!
  28. May 21, 2018 at 5:16 PM
    Cfincke
    San Antonio
    I have the dirtydeeds TRD replacementsystem with dumps before the rear axle. I went with the 20x5 mufflers and it is veey quiet with a deeper tone and no drone. I did the 20x5 only because I was going to be getting a travel trailer and did not want an overly loud and droning exhaust while towing. If I did not have the travel trailer i would have gone with the 16x5 or 12x5.
    Give Keith a call and he can build you what ever you want for an exhaust.
  29. May 22, 2018 at 9:23 AM
    kenomouth64
    Tetrus
    The Flowmaster 40 is $100 on Amazon. I think this will be the best option for me. However I will start towing more often, so I might go with a Flowmaster 50, to quiet down the long tows.
    The Flowmaster 44 is $102
    https://www.amazon.com/Flowmaster-9525454-Super-Muffler-Aggressive/dp/B000F9HODC
    https://www.flowmastermufflers.com/street-mufflers/8425454-25ind-25outd-super-44-409s/
    Berdine likes this.
