Best differential fluid to use
Discussion in 'General Tundra Discussion' started by Oregon 1 Toyo, May 9, 2018.
  1. Jan 10, 2020 at 4:37 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    No real difference that I can tell. Think I changed the fluid around the 3k mile mark after my first real tow. 36k on the truck now no issues.
  2. Jan 11, 2020 at 5:42 AM
    Jeffro22
    Jeffro22 New Member
    2013 platinum crewmax 4x4
    The super tech gear at Walmart actually rates really well.
    synthetic 75-90 is around $7 a qt and has friction modifier already added
  3. Jan 11, 2020 at 6:01 AM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    You don't need friction modifier/limited slip additive on Tundras unless you got an aftermarket LSD.
    Tiamat likes this.
  4. Feb 29, 2020 at 8:18 AM
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    My 2019 Tundra manual says the oil should be 75w85, not 75w90.
  5. Feb 29, 2020 at 1:27 PM
    Jeffro22
    Jeffro22 New Member
    I think that it is such a minor difference that either one is fine. Some good info over @ bitog. I used 75-90 and didn’t think twice
    lonedrake likes this.
  6. Mar 1, 2020 at 11:14 AM
    Oregon 1 Toyo
    Oregon 1 Toyo [OP] New Member
    2014 Tundra sr5 double cab 4x4
    Sounds like 75-90 is a little better if you tow a lot, thats what I run in my 14 dc mobil 1 full synthetic.
  7. Mar 2, 2020 at 6:39 PM
    Tiamat
    Tiamat New Member
    2015 tundra crewmax xp
    Did you notice any difference in truck ride
  8. Mar 2, 2020 at 7:34 PM
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    Not really, I have amsoil in my diffs and engine for piece of mind.
    Brownsfanhere likes this.
  9. Dec 2, 2020 at 3:12 PM
    naumanator
    naumanator New Member
    Salt Lake City, Utah
    2017 Silver TRD Off-Road Double Cab
    Is it bad for our non-limited slip differential to use limited slip differential oil?
  10. Dec 2, 2020 at 4:18 PM
    Hi06silver
    Hi06silver Fat. Thumbs.
    Ryan
    2006 DC 4x4 Waltrip
    5 inch TC Lift. Icon 2.5 Ext. travel coilovers- Icon Resi- shocks w/Firestrone air-ride 285/75/17 Toyo OC Ext. FN Overlander wheels Retrofit Projectors Kenwood H/U Natika Back-up camera
  11. Dec 2, 2020 at 7:07 PM
    lewi3069
    lewi3069 New Member
    2017 Crew Max 4x4 Sunset Bronze
    I use Amsoil in my entire truck. Except for the transmission (for now have replacement fluid. Need time to swap it.) and the transfer case since they don't have comparable fluid. I can also get Amsoil at cost for whoever wants some.
  12. Mar 18, 2021 at 12:22 PM
    Merkaba
    Merkaba New Member
    2009 Black Tundra Rock Warrior
    thats fine and just as good if not better.
    limited slip additives are just improving lubrication and that’s good regardless of diff not being LS.
  13. Mar 18, 2021 at 12:46 PM
    Ronin73
    Ronin73 New Member
    Warranty, man. After that, yeah, maybe. The manual calls fro 75w85. It does not say or equivalent or any other language like that.
  14. Mar 18, 2021 at 1:07 PM
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
    Im using Motul synthetic on my diffs, quite inexpensive vs my other choice (Redline) and probably just as good.
  15. Mar 18, 2021 at 1:33 PM
    TX210Tundra
    TX210Tundra New Member
    2008 RCSB 5.7 2WD "Sport" / 2022 Limited Hybrid
    2008 - SOS 2/4 Lowering Kit : Firestone Bags : Bilstein Sports at 4 corners : TRD Pro Grill : TRD Pro 18in BBS Forged : Grip Pro LSD : Mike's "ByeNanny" : ARH LT 1 3/4 : ARH Cats : 3" X-Pipe: 3" Dual Borla XR1's / 3" Vibrant Resonators: 3" Tail pipes: DIY SABM: TRD Intake : AFE T/B Spacer : TRD Accelerator : LED Interior/Exterior : Atoto Pro HU : Cerwin Vega 10in Slim : AVS Visors : Sequoia Leather Seats : TRD shift Knob - OVTuned "Spicy 91 Torque Tune" 2022 Limited Crewmax Sonic Red Hybrid - TRD Filters : EGR Window Visors : Cheer Dring Android Adapter : RC Bed Cover : RC 1.75 Level Kit : Undercover Swing Case
    Amsoil here for my Fundra, I went a tad thicker due to our heat.
    Ellis42sbgtf likes this.
  16. Mar 18, 2021 at 1:38 PM
    Ellis42sbgtf
    Ellis42sbgtf New Member
    Kyle
    Houghton, MI
    2018 Crewmax TRD Sport 4x4
    Hey that's awesome! I saw Project Farm do an oil comparison and Amsoil was the winner. I just got my Tundra and would like to use the best
    i.e. I'm interested
    coldcanuk and TX210Tundra like this.
  17. Mar 18, 2021 at 3:43 PM
    chugs
    chugs New Member
    Ciao
    Central Cali
    2007 Tundra Blue Streaker
    WFD473 likes this.
  18. Mar 18, 2021 at 4:10 PM
    lewi3069
    lewi3069 New Member
    Send me a PM
  19. Mar 18, 2021 at 4:17 PM
    #49
    AZBoatHauler
    So.Arizona
  20. Apr 20, 2021 at 8:10 PM
    #50
    yoshi82
    yoshi82 New Member
    DAVID
    HOUSTON
    2014 Silver Tundra SR5
    3in ToYtech lift on Tundra and 2.5in in the rear. Tow Mirrors. Toyota grill, and Front bumber. New 6in antenna. Repainted the stepping boards
    how many quartz does it take?
    So 75w85 is recommended for 2014 5.7 Tundra, i believe is time to changed mine especially because i tow a RV Trailer so need to get my tuck ready for summer. So any one has videos on how to do it? Well im guessing just unscrew the top then the bottom and drain. Re-tight the screws back on and fill it up? Any ideas?
  21. Apr 21, 2021 at 2:04 AM
    #51
    Ellis42sbgtf
    Kyle
    Houghton, MI
    3.8 Quarts but it can vary. There's some good videos on youtube. You got the process. I think 36 ft/lb torque when tightening.
    yoshi82[QUOTED] likes this.
  22. Apr 21, 2021 at 3:26 AM
    #52
    Tiamat
    Tiamat New Member
    Its about Fuel mileage. Run 75w90 from amsoil and don't look back a.
  23. Apr 21, 2021 at 3:40 AM
    #53
    Piki
    Piki New Member
    2017 Tundra crewmax 1794 TRD
  24. Apr 22, 2021 at 9:14 AM
    #54
    yoshi82
    yoshi82 New Member
    DAVID
    HOUSTON
    @Tiamat 75W90, will this only work on 4WD or does it matter? I have SR5 Automatic Tundra 5.7L, wondering but i think it does not. First time going to do it this weekend so just trying to get some answers
  25. Jun 26, 2021 at 2:46 PM
    #55
    AnthonyC
    AnthonyC TAKE IT EASY WHILE YOU"RE GOING FAST
    Anthony
    Virginia Beach, VA
    2010 Tundra SR5 TRD DOUBLE CAB
    TRD DUAL EXHAUST, FIRESTONE AIR BAGS
    Has anyone found their differential oil to be the color of cardboard? Or coffee with a fair amount of milk in it?
  26. Jun 26, 2021 at 4:05 PM
    #56
    TX210Tundra
    Sounds like water got inside the housing, good thing your changing it.
    2mchfun likes this.
  27. Jun 26, 2021 at 4:48 PM
    #57
    AnthonyC
    Anthony
    Virginia Beach, VA
    Well I think I waited way too long. I heard this whining noise, sounded like it was coming from under the drivers seat. I pulled the transfer case, disassembled it and found the planetary and the output shaft to be scared lightly. The inside of the planetary there is no race to replace. The planetary alone was almost the cost of a new T case. So I put a brand new one in. I’m a little frustrated right now because of the noise. I’ll find it, I will find it! Thank you for the reply, I agree with you, water. I bought the truck with 8,900 miles on it from a Toyota dealer in Frederick, MD in 2013. I lived in PA at the time. The family that had it had a boat. That answers the questions about the water
    TX210Tundra likes this.
  28. Jul 2, 2021 at 8:18 AM
    #58
    AnthonyC
    Anthony
    Virginia Beach, VA
    Hello all. I found the whining culprit
    The gear oil is contaminated with water and rust. The axle bearings have double row of roller bearings.
    I just dropped off the axles and new bearings at a local machine shop in Chesapeake, VA. I’m told they’re good at what they do. I have a lot of cleaning to do. I’m just chilling today, tomorrow I pull the gear assembly and start cleaning the housing up. I found a lot of grit in the housing. After pricing used rear end assemblies, I went with a brand new gear assembly. I’m going to extend the vent for the read end housing up to the bottom of the truck bed. The OEM vent sits right on top of the housing. When I bought this Tundra back in 2013 it had 8,889 miles on it. The salesman told me that the previous owner pulled a boat with it. That should have been a red flag. Backing a boat down the ramp and getting it deep enough into the water never dawned on me. Also never think to drain the oil in the rear. I certainly checked the oil levels in the rears and transfer case. Why would I drain the oil on an 8,000 mile pickup? Now I know why I should have.
    WVI, YardBird, 2mchfun and 1 other person like this.
  29. Jul 2, 2021 at 8:24 AM
    #59
    AnthonyC
    Anthony
    Virginia Beach, VA
    Also I’d like to let everyone know the Toyota Dealer here in Virginia Beach wanted $2,200 plus tax for the gear assembly.
    Lakeland Toyota in Lakeland,FL was $500.00 cheaper with the shipping, and they don’t collect taxes from out of state customers.
    Matala and 2mchfun like this.
  30. Jul 2, 2021 at 8:57 AM
    #60
    TX210Tundra
    Nice but not nice, glad your taking care of her correctly to put you on pace for many trouble free miles.
    I would have had an itch to install LSD as one of those "While I'm in there" lol
    AnthonyC likes this.
