Best coilover setup for me?
Discussion in 'Suspension' started by Mountun Goat, Feb 23, 2018.
  1. Feb 23, 2018 at 3:07 PM
    Kwikfish
    Kwikfish Get your poop in a group!
    Tri cities,WA
    16 CM SSM
    I heard rumor of a ICON GB but i think it was juat wishful thinking lol
  2. Feb 23, 2018 at 3:09 PM
    Not my truck. #Betsy4Life
    He has Icon UCA’s and 35”
  3. Feb 23, 2018 at 6:12 PM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    In the $1000 price range the FBG are the best performance and value, imo.
    I had FBG fronts and they felt great. I ran a 700lb spring - I would recommend 650 unless you're loading up your front end with an aftermarket bumper or similar. All of the options you listed should be pretty great though.
    Mountun Goat[OP] likes this.
  4. Feb 23, 2018 at 8:07 PM
    Mountun Goat
    Mountun Goat [OP] She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Thanks for the thoughts everyone. I’ve never lifted any truck before so it’s hard for me to even judge an entry level setup. I want whatever I get to be far better than stock. I mean if I could I’d do a full long travel tube chassis but wouldn’t we all haha. I’m just a noob and want to not regret my choice one bit.
    [DELETED], 831Tun and T-Rex266 like this.
  5. Mar 5, 2018 at 6:44 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Ok so did a bit more research. Reached out to some local shops around home here in Canada. There is no way I can afford anything major. With the Canadian dollar so low it’ll cost me my right nut for anything with external bypasses. Plus now that I know how much I would have to spend, I have re-evaluated putting $5-6k worth of suspension on a ten year old truck with 280000 miles on it. This leaves me with Old Man Emu. Which honestly was my first plan way back before I joined the site and got all horny over the fancy setups.
    Thanks to everyone for the advice. After rethinking my strategy here’s my absolute needs in a suspension:
    Lift: I want to stuff 35s on the truck for trail clearance.
    Flex: I want to be able to flex the truck over rocks n what not, I will do a sway bar delete in the future. This also will be addressed with uca’s at some point.
    Due to the price of kits in Canadia I’m hoping to do this OME 2.5” lift without UCA’s off the bat. Is this safe?
    Also at 2.5” is it smart to install a diff drop bracket?
    Thanks everyone for their input. I’ve learned a lot so far. :confused::hattip:
  6. Apr 3, 2018 at 1:42 AM
    Like a PRO
    Like a PRO New Member
    Rodney
    Slidell Louisiana
    2016 lifted 4×4 SR5
    6 inch Rough Country lift fuel 20×9on 35s , TRD Pro Grill TRD Pro exhaust dual Extang 2.0 tonneau cover
  7. Apr 3, 2018 at 8:08 AM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    So sick. I would one hundred percent do it if cashroll let it. I’m ballin on a budget for sure :spending:
    I ordered old man emu with spc uca’s and Dakar leafs...
    chphilo and blue16 like this.
  8. May 28, 2018 at 7:34 AM
    aztundraguy
    aztundraguy New Member
    2017 Tundra CM TRD Offroad
    6112/5160,Icon Billet UAC,Diff Drop,Billet .250 shim Lean Correction, CB Bump Stop Extensions, 275/70r18 w/ 18x9 +12 offset
    Couldn’t better happier with this setup Fox 0-3” coilovers
  9. Aug 12, 2018 at 8:15 AM
    Grant.B.
    Grant.B. New Member
    Grant
    2014 White crewmax 1794 Edition 4x4
    is this better or nore comfortable than the stock set up
  10. Aug 12, 2018 at 8:54 AM
    aztundraguy
    Stock setup rides like a Cadillac imo. I’m sure any good coilovers set rides about the same. But absolutely notice a huge difference with these on road and off
  11. Aug 12, 2018 at 1:30 PM
    Grant.B.
    Grant.B. New Member
    Grant
    Do you notice and good or bad difference on road
  12. Aug 12, 2018 at 6:03 PM
    Like a PRO
    Rodney
    Slidell Louisiana
    2016 lifted 4×4 SR5
    2.5 RR + BDS UCA rides like a dream
    Mountun Goat[OP] and equin like this.
  13. Aug 13, 2018 at 10:10 AM
    Civiceg94
    Civiceg94 New Member
    NYC
    2007 Toyota Tundra Crewmax 5.7 Limited
    Horn baffle delete Fox 2.5 DSC Setup DAP TUNED RW WHEELS 285/75/17 AT3 LTX
    I order this same coilover. I got a couple questions. Did you end up adjusting them ? If not then how much lift did they give you at stock setting ?
    aztundraguy[QUOTED] likes this.
  14. Aug 30, 2018 at 6:25 AM
    aztundraguy
    I did adjust them, for every inch the compression collar moves down it’s a 1/2” of lift. But keep it mind the more you compress the shock you lose down travel. Being the 0-3” Fox is longer At zero compression you won’t need to add as much or any preload to achieve lift your looking for. Passenger side I went .250” and driver I went 1.250”. Being I had a 1/2” Toyota lean for correction.
  15. Aug 30, 2018 at 6:28 AM
    aztundraguy
    They come out of the box at 1 inch of compression, I adjusted to .250 pass and 1.250” at driver.
    295/70/18 Toyo MT’s and 3/4” rear Shackles
  16. Sep 19, 2018 at 11:18 PM
    MDHinSD
    MDHinSD New Member
    Michael
    SoCal SD North County
    2017 Black Tundra CrewMax 4X4 TRD
    Blackout Grill
    I like this idea... I have a stock 2017 TRD. Do you think I could use the existing Bilstein shocks with the
    ARB OME 2.33″ Front Lift 740lb. Coils? I want to level her out ...
  17. Sep 20, 2018 at 4:40 AM
    chphilo
    chphilo Tundra addict
    Western PA
    Congrats. You will like this set-up.
    I considered adjustable coilovers also, but with winter chemicals they use around here, nothing is safe. I would be hurting, I thought, if one of these expensive coilovers get rusted. With OME set-up, you could get new shocks with less $$ than you would have to pay for rebuilding these shocks. Of course, you could rebuild them yourself, but I knew my limits.
  18. Sep 20, 2018 at 4:44 AM
    chphilo
    Western PA
    You are correct. Their coils are 740. Shortest one is 612. Medium length (which I have) is 614. The longest one (for heavy bumper application) is 613.
    Unfortunately, you can't use other set-up with OME coils.
  19. Sep 20, 2018 at 6:38 PM
    #49
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    I do love it! I’ve been into some pretty rough off-roading this summer since the lift. Just love it. Totally new truck. I took my front sway bar out for flex as well. I have the arb bumper so I went with 613 springs. Was pretty stiff at first but now that I broke it in I like it a lot.
