Best (cheapest) spare for 35x12.5R20 tire setup?
Discussion in 'Wheels & Tires' started by rt_tundra_co, Dec 14, 2018.
  1. Dec 14, 2018 at 9:04 AM
    rt_tundra_co
    rt_tundra_co [OP] I'll get tired of tweaking this truck...never
    '15 SR5 CM TRD
    Magnaflow cat-back exhaust Leer Topper, color matched to truck Thule Aeroblade roof rack on topper FABTECH 4” Suspension Lift Decked Storage, 2 drawer SPYDER LED headlights and taillights kits Hertz HDP5 5 Channel Class D Amplifier 2 x 10” subwoofer boxed behind rear seat Door speaker upgrades by Elite Auto Sound Colorado Springs Lock’er Down EXxtreme Console Safe LD2043EX Lock’er Down rear seat 3 x safes Lock’er Down gun magnet 80 LED in-grill light bar Baja Designs LED ditch lights TRD Pro grill Rotiform SIX-OR 20x9 wheels 35x12.5R20 Toyota Open Country R/T tires TheSource sPOD power control hub with in-cab installed accessory switches Firestone Ride Rite air suspension system with Air Command remote, on board compressor and rear bumper air port SDHQ rock sliders
    Fellas, I have 20" Rotoforms with Toyo Open Country R/T 35x12.5R20 tires on the main 4 but have the stock P275/55R18 on the spare. A near 5" delta from my mains. So I'm looking for some advice, some probably painfully obvious but want opinions none-the-less:
    1. Should I replace the tire on the spare rim to match the diameter of the main tires at 35"?
    2. Recommendation on where to look for the best (cheapest) option for getting a new tire?
    3. Other issues to think about or situations to avoid? I don't have any issues with having to run a spare with the same diameter on the mains but on a 2" smaller rim but maybe there is something to think about there...?
    According to tiresize.com i should be looking for generally 3 different tire sizes:
    1. 35x12.5R18
    2. 285/75/R18
    3. 305/70R18
    I get a bit worried about putting anything too wide on the stock spare rim.
    In some light searching most tires in this class are $300+ and it looks like moving down to a 17" rim would present cheaper options for tires. Should I consider a steel rim/tire combo in the 17" range and just sell off the current spare setup?
    Thanks!
  2. Dec 14, 2018 at 9:15 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Offer up
  3. Dec 14, 2018 at 9:21 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    What lift do you have? Your stock spare steelie might not fit anymore.
    Bear likes this.
  4. Dec 15, 2018 at 1:38 AM
    rt_tundra_co
    '15 SR5 CM TRD
    I haven't actually nailed that down yet. It's a suspension FABTECH lift in the 4" range. Previous owner had it done at Les Schwab in town and I need to get my butt over there and have them dig it up in their records. I hadn't considered this.
    joonbug[QUOTED] likes this.
  5. Dec 15, 2018 at 4:18 AM
    Need to do same, so many tire shops here in town (used ones) gonna find me a good one plus cheap wheel, also gonna have to cut brackets where stock goes cause new used spare won't fit
  6. Dec 15, 2018 at 5:13 AM
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    For this reason I carry 2 jacks!!! My OEM spare will ONLY fit on the rear axle now. Due to the Lift, the new knuckles will not allow the old wheel size to clear.
    Hoping I never have to change out a front tire. Lol. It would require a 2 tire swap.
  7. Dec 15, 2018 at 6:18 AM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    I’ve been thinking about it because I want to have 35’s all around on a 17” wheel and my plan is to buy 5 wheels and tires and rotate the spare in so I don’t waste money buying a spare that never gets used. Buy the same 5th wheel and find a used tire shop that has good deals on a good used tire. I like uniformity, don’t want to use a spare that looks different from the other wheels.
  8. Dec 15, 2018 at 8:21 AM
    Tundra4us
    Tundra4us New Member
    "D"
    This is my dilemma right now too. My stock spare is useless due to lift. I am running Grid GD5 wheel in 20x9, +15 and Toyo AT2 35/12.5x20.
    A) Buy 1 more matching wheel and tire ( honestly I dont think I would do the 5 wheel rotation )
    B) look for a cheap new or used non matching wheel of either rim size 17, 18, 20 to make a spare. Dont care if its same, its for temp/emergency use.
    C) Change Wheels completely, I have been thinking I want to do SCS wheels and still run 35" tire.
  9. Dec 15, 2018 at 7:09 PM
    rt_tundra_co
    '15 SR5 CM TRD
    Used tire shop - why didn't I think of that? That's where I'm headed next week.
  10. Dec 15, 2018 at 7:10 PM
    Look for a decent one with the most tread u can find, some places might have a same size wheel as you do too
  11. Dec 16, 2018 at 2:20 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Haven’t found any steelies with the Toyota bolt pattern let alone a +18 offset to fit with lift.
